Old 09-28-2021, 04:07 PM #16
Kandor's Avatar
Kandor Kandor is offline
Kandor will become famous soon enough
Kandor's Avatar
^^400 ft fall with driver and dog thrown from the vehicle. Very lucky there were no fatalities. Lots of people out there with their new 4x4's going places that exceed their skill set.
2007 Limited V8 - Sold
2023 TRD ORP
Kandor is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 04:26 PM #17
Mr_Bingley Mr_Bingley is offline
Mr_Bingley will become famous soon enough
Wow. That road looks amazing but well in excess of my limits.
Mr_Bingley is offline   Reply With QuoteReply With Quote
Old 10-05-2021, 02:49 AM #18
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Originally Posted by spartacus View Post
It was not the capability of the Bronco but a mistake by the drivers, who took the wrong turn and went up the one way. Tried to turn around and rolled off the cliff. They wère lucky they wère at the bottom. It's impressive that the Bronco took severe damage but saved the woman and the dog in the vehicle.
Woman and dog injured after rolling off Black Bear Pass
Huh? Wow. I missed that.
I am not sure if they still do it but the pass used to be drivable uphill once a year during a special event.
Old 10-07-2021, 10:58 PM #19
Jimmy_D's Avatar
Jimmy_D Jimmy_D is offline
Jimmy_D is on a distinguished road
Jimmy_D's Avatar
I've done it twice going up with the Rotary Club in Telluride. I assume they still do it annually but I haven't checked in a long time. It's definitely different going up and you tend to miss the great views that you get heading down.
Jim
Jimmy_D is offline   Reply With QuoteReply With Quote
Old 10-17-2021, 12:08 AM #20
Sp00ner's Avatar
Sp00ner Sp00ner is offline
Sp00ner will become famous soon enough Sp00ner will become famous soon enough
Sp00ner's Avatar
I feel like it would be a lot less intimidating going up?
RCI Sliders & TRD Integration, Transmission and Transfer Case Skids
Eibach TRD Pro Lift, 285/70/17 KO2s
TRD Intake, ARB Breathers
Pioneer 8500NEX
Sp00ner is offline   Reply With QuoteReply With Quote
Old 10-18-2021, 10:56 AM #21
Jimmy_D's Avatar
Jimmy_D's Avatar
Most of the folks I've been off-road with are far more uncomfortable going down than up. I took a group on 'Behind The Rocks' in Moab one time and most, if not all, of them had a great deal of experience. It spooked a number of them since most of the extreme obstacles are going down on that particular trail. On one of the runs I did headed up Black Bear there were a couple of H-1 Hummers and it was a bit disconcerting being behind them and watching them crawl up on the uphill side slightly to avoid having their downhill tires drop off the edge. Other than that one instance going up Black Bear wasn't bad at all.
Jim
Old 10-27-2021, 01:51 PM #22
Flyer Flyer is offline
Flyer will become famous soon enough
I have done it a few times but I would not do it in any vehicle without solid axles. The funny thing is that when I got my first Jeep in 2012, that is where I went. It scared the heck out of me but it was too damn late to turn around (you literally can't turn and backing up (without 4x4 in reverse) is near impossible too. So I said what the heck and asked my friend to get out of the Jeep for her safety. I walked the stairs twice and picked my line. I went down it solo and made my friend walk it down. That was a bit scary for sure. After that, it was a bit less scary each time but I still would not do it in a truck or an IFS vehicle. Many do...just not me.
2005 V8 4Runner 4X4 SR5, FJ TRD Bilstein Suspension, KO2s
2020 Mercedes GLE450
2014 Wrangler Rubicon, Synergy suspension + 35 MTRs + way too many mods
Flyer is offline   Reply With QuoteReply With Quote
Old 10-28-2021, 01:40 PM #23
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Originally Posted by Flyer View Post
... and backing up (without 4x4 in reverse) is near impossible too.
Curious, what 4wd vehicle doesn't have 4x4 in reverse?
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 10-28-2021, 02:08 PM #24
Not sure if there technically are or if that is even possible, but there seems to be a ton more DS binding when in reverse (in 4Lo) since you can hardly go back and up in a straight line on those trails. Forget about lockers in those tight spots too. Of course, it is too scary/stupid on those steeps to take it out of 4Lo. So the only way is forward in those cases. The stairs was especially scary for me since I was such a newbie, and the only place I ever considered backing up.
Old 10-28-2021, 02:38 PM #25
Real Name: Ron
Real Name: Ron
I'm with you that backing up on steep slopes can be intimidating, and without good spotting it can be hard to keep to a workable line. That being said, the drive train itself doesn't care which direction you are going, and shouldn't bind up one way more than the other.
Old 10-31-2021, 09:34 PM #26
Shepherd214 Shepherd214 is offline
Shepherd214 is on a distinguished road
Guess you've all seen this one.
Shepherd214 is offline   Reply With QuoteReply With Quote
Old 11-01-2021, 12:19 AM #27
MAST4R's Avatar
MAST4R's Avatar
Not a 4x4 technically, but Subarus have big trouble reversing over a rough spot. Ask me how I know
Outbacks, Foresters, and XVs have all done Black Bear, so there is that.
In fact, BB is a bizarre trail, I am sure that a Subaru is less scary over the tippy spots than an IFS 4x4. I did many trails there in my OB, on upgraded brakes, and lots faster than Wranglers and Toyotas in both directions, but drew a line on BB. Others do it but I thought it is just not right even if doable.
Old 11-01-2021, 09:28 PM #28
What some don't realize is that after a rain (or during even) Black Bear and several passes there, become really really slippery. There are stretches of slippery soil that are not everywhere but can catch the unwary off-guard. I'll never run Black Bear in those conditions. I have been caught out in a downpour once. It was hard enough to start causing rockslides. I was near the end of Engineer Pass intending to come back via Cinnamon Pass. Instead, I went to Lake City and took the LONG way home on the highway, and almost got caught by a rockfall there.
Old 11-07-2021, 06:55 AM #29
Jimmy_D's Avatar
Jimmy_D's Avatar
I had a buddy meet me in Telluride one time (we were both in FJ's). We were there to do the Rotary Club's annual Black Bear Pass run going up. When he was going to head back to Dallas we decided to go over Imogene Pass to Ouray and he was going to take off from there. There was another friend visiting who was riding with me. We did Imogene and had lunch in Ouray. It was pouring rain the whole time. I decided to take Mineral Creek/California Pass/Hurricane Pass/Corkscrew Pass/Ophir Pass back to Telluride. When I got to Corkscrew it was really spooky heading down. There were serious slides in a number of spots across the trail that we had to go over, and the severe off-camber nature of crossing those slides was more than a bit unnerving. I found out a few days later that around the same time we were doing that run someone in a rented jeep who was right where Hurricane Pass drops down and Corkscrew Pass takes off was killed by a large boulder that had dislodged and crashed through the roof. Lesson learned about doing runs in that area in a heavy downpour.
Jim
Old 11-07-2021, 03:01 PM #30
Close call! Off-road slides can be fatal. Yeah, I actually almost got hit by a rockslide on the highway. I knew there wold be slides on Corkscrew, American, and even Engineer. So we got on the highway and took the long way back. The water/rocks suddenly flowed over the top of the cliff like a waterfall. It missed me by 50-60 ft as I passed it a few seconds before it hit the road, but the truck that was going the other way had a trailer and the trailer's rear portion got hit and it pushed them almost all the way off the road. We stopped and he managed to get the trailer straight and wanted to hightail it out. We did too. After that, I developed a habit of looking up at the cliffs for water flow.
4runner , ago , easy , trail , vehicle
Easy to explore in Big Bear EddieV4runnin So Cal 2 12-07-2018 05:04 PM
"Easy ROute" Antenna Cable for Tacoma Whip Mod BamaDrewski 3rd gen T4Rs 4 08-12-2018 07:44 PM
"Easy trail" calico run mwray8909 So Cal 5 09-27-2017 12:39 PM
Want an easy way to get a 3" front lift ??? Dragsterpilot 3rd gen T4Rs 13 11-17-2014 03:26 PM
