Old 08-01-2021, 07:25 PM #1
bjornbjorn bjornbjorn is offline
bjornbjorn is on a distinguished road
Driving down steep fsr
I am new to off roading, I have a 5th generation 4runner. What is the best way to travel down a steep fsr without having to burn out the brakes? Any suggestions would be much appreciated.
The road is relatively smooth, it was just graveled to smooth out the pot holes but it's steep
bjornbjorn is offline   Reply With QuoteReply With Quote
Old 08-01-2021, 08:25 PM #2
biratley biratley is online now
biratley will become famous soon enough biratley will become famous soon enough
Use the manual shift option and drop
Her down a gear or 2
Sent from my iPhone using Tapatalk Pro
biratley is online now   Reply With QuoteReply With Quote
Old 08-01-2021, 08:25 PM #3
Sp00ner's Avatar
Sp00ner Sp00ner is offline
Sp00ner will become famous soon enough Sp00ner will become famous soon enough
Sp00ner's Avatar
Keep the gears down on the transmission, if it's REALLY steep you can use 4LO, but I cant imagine that on a graded road.
RCI Sliders & TRD Integration, Transmission and Transfer Case Skids
Eibach TRD Pro Lift, 285/70/17 KO2s
TRD Intake, ARB Breathers
Pioneer 8500NEX
Sp00ner is offline   Reply With QuoteReply With Quote
Old 10-11-2021, 02:53 AM #4
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Like spooner said. If it's extremely steep go 4 lo and use your DAC. You won't even need to touch your breaks. In fact that disengages DAC as soon as you touch the brake.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 10-12-2021, 02:48 AM #5
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
In the Rockies, there are dirt roads where second-third gear in low range is the ticket.
For trails, the gearing is not low enough so if the spot is not terrible (then crawl control is perfect), there is nothing you can do but first gear low + brakes.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 10-16-2021, 11:55 PM #6
Sp00ner's Avatar
Sp00ner's Avatar
I've honestly become more and more fond of crawl control as I've used it more and more. I used it a few times on some steep sketchy wet clay downhills at the offroad park a couple weeks ago and then did the same without it, it was a pretty incredible difference.
I just wish the process to engage it and dial it in was less clunky. I love having button on the upper center 'console' but in this case it feels like both the wrong place and the wrong 'method' to engage and set. The way it engages doesn't help either.
Pioneer 8500NEX
Old 10-18-2021, 07:11 PM #7
beingnotdoing beingnotdoing is offline
beingnotdoing is on a distinguished road
I have a 3rd gen, so no fancy downhill assist for me. Use 2nd and then low gear to slow you down. When that isn't enough, drop into 4lo and that reduction in gear ratios will slow you down, as well.
I used every trick I had to get down a steep grade with switchbacks this last weekend in the Washington and Jefferson National Forest. I put the transfer case into 4lo, put the transmission into low, and used my brakes as sparingly as possible, but as much as necessary. I also stopped half way down for about five minutes to let the brakes cool off. I'd rather take it slow than realize I'm experiencing brake fade halfway down a dangerous-as-hell decline.
beingnotdoing is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 02:06 PM #8
YEAHYEAHHH YEAHYEAHHH is offline
YEAHYEAHHH is on a distinguished road
Does DAC work in snowy conditions?
YEAHYEAHHH is offline   Reply With QuoteReply With Quote
Old 01-18-2022, 03:34 PM #9
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
I do not recommend DAC in snow, ice or muddy conditions. The system relies on good traction, otherwise it gets really confused. Use engine braking in low range 1st or 2nd instead.
techno is offline   Reply With QuoteReply With Quote
Old 08-22-2022, 11:00 PM #10
Muskrat14's Avatar
Muskrat14 Muskrat14 is offline
Real Name: Dave
Muskrat14 will become famous soon enough
Muskrat14's Avatar
Real Name: Dave
I’ve used Crawl Control a few times on steep down hills w loose rock. I thought it did well.
I’ve also used it a bunch on flat trails that would require a lot of gas brake. It’s a nice brake from pedaling on a long trail here n there.
Muskrat14 is offline   Reply With QuoteReply With Quote
appreciated , fsr , road , smooth , steep
Steep hill climbing nissanh Off Topic 0 12-09-2015 08:01 PM
Technique for driving up STEEP slippery incline Marcocopuffs Off-Roading 10 12-17-2014 09:50 AM
5.29 gears too steep for 33s? sam24th Classic T4Rs 17 10-23-2013 10:14 AM
'95 Spilled oil on steep incline?? ryanbigcheese Classic T4Rs 0 06-29-2013 01:56 PM
Steep Grades VolFF 4th Gen T4Rs 7 07-28-2007 11:14 PM
