Old 07-21-2022, 06:26 AM #1
SR5-Joe SR5-Joe is offline
SR5-Joe is on a distinguished road
What to do after off roading
I looked but I’ll admit I am not very good at searching so I apologize if it’s covered some place.
Living in the north east. I am getting more into 4 wheeling with my 4Runner.
I don’t know if there is anything other than just washing it. Is there anything else that I should consider doing
SR5-Joe is offline   Reply With QuoteReply With Quote
Old 07-21-2022, 10:10 AM #2
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Where in the north east? Toyota takeover at rausch creek next weekend hosted by Northeast Toyota crawlers if youre interested.
Post wheeling is usually re organize the gear and crawl under the truck to check for loose bolts or anything looks damaged.
After that it usually time to sart planning the next trip out!
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 07-21-2022, 01:57 PM #3
I am in the Pittsburgh area. I’ll be out of the area this and next weekend. Total bummer. I’ve been there and it’s great
Old 07-21-2022, 05:24 PM #4
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Yeah, check for any damage. I have chronic annoying skid plate bolt issues and need to find a solution for the darn bolt once it is not 115F in my garage! (the skid plate rattles a bit offroad). I have rethreaded and what not but the bolt keeps falling off.
But of course you are looking for more significant issues just as a precaution after rock crawling or moving at speed over rough terrain.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 07-21-2022, 09:58 PM #5
Luckily ( knock on wood) I don’t have that problem. It’s got to be annoying.
I do look underneath for obvious damage. I am new to this so other than scrapes on the skid plates, or something dripping is there anything in particular you are looking for?
Old 07-21-2022, 10:44 PM #6
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Veteran off roader native to the Arkansas Ozarks national forest area. Been off roading for ten years SOLO in my runner, original owner. Here is my procedure. Simple yet affective. Get you a welder paint marker. After confirming proper torques, witness mark all the nuts and bolts related to your suspension. Witness mark all 8 lower control arm alignment tabs. Witness mark position of jambo nuts on tie rod end links. Now you can visually check before and after each excursion within a minute or two. When you have an issue you'll see it right away and get on top of that sh!t preventing wear and tear making your runner last forever and getting to know your b!tch intimately. Checking alignment is now a matter of seconds also. This also prevents alignment shops and mechanics from f_cking you if you don't diy. For recovery all I've ever needed was a heavy duty come along and a bottle jack to get out of all the situations I've been in, solo. Obviously have a tool kit for trail emergencies. Pay special attention to your CV axels and dust seals after each excursion also for excessive play or leaks, and check boot condition. This is the most likely point of failure over time off roading. I actually keep an extra set for the trail. Have fun and get crazy with it!!
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 07-22-2022, 06:48 AM #7
That’s a good idea marking everything. Thanks!
Old 07-26-2022, 07:48 PM #8
Shock Surplus Shock Surplus is offline
Shock Surplus is on a distinguished road
Basic checks, making sure wheels are still torqued, tire pressure isn't leaking at all. I also clean my air filter since my port is pretty exposed as of right now.
Shock Surplus is offline   Reply With QuoteReply With Quote
Old 07-31-2022, 03:00 AM #9
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
1. loose skidplate bolts (like others mentioned)
2. alignment and go over suspension bolts (pen marked).
3. carwash.
4. air filter.
5. buy vehicle upgrades or camping gear for things that annoyed me on the previous trip.
Old 08-05-2022, 07:38 AM #10
3. carwash.
4. air filter.
5 is both the best and worst part. What I want/ what it costs.
Old 08-19-2022, 08:40 AM #11
NoTreadLeft NoTreadLeft is offline
NoTreadLeft is on a distinguished road
I check fluid levels out of habit to make sure everything is where I expect it to be. If you have any DIY wiring I would also check that... I've had some Land Rover wiring move around and catch fire before so that sticks in my memory and I am always looking for wiring that has moved around, especially under the hood.
NoTreadLeft is offline   Reply With QuoteReply With Quote
Old 08-21-2022, 07:29 PM #12
Muskrat14's Avatar
Muskrat14 Muskrat14 is offline
Real Name: Dave
Muskrat14 will become famous soon enough
Muskrat14's Avatar
Real Name: Dave
I put the lawn sprinkler u der it and move it around ever 20 minutes. Then it’s immediately off to the self serve car wash for an under body pressure wash.
Then reinstall running boards.
Check for damage or loose hardware and front end components.
Great idea marking all the nuts n bolts underneath.
Muskrat14 is offline   Reply With QuoteReply With Quote
4runner , don’t , iphone , washing , wheeling
What gen is the best for off-roading? Kire4Runner Off-Roading 229 03-28-2023 12:32 PM
Took my 4th gen off-roading MrHall Off-Roading 0 06-16-2014 11:02 AM
Off Roading in CT 7/23 ksneubec Gallery 8 02-26-2011 09:56 AM
Off-Roading creativeman313 3rd gen T4Rs 47 02-18-2009 12:45 PM
Off roading on LI Kramer420 Northeast 2 03-26-2006 07:36 PM
