09-08-2012, 12:06 AM
#16
Old thread bump....will these coils work on the 90-95 4runners?
09-11-2012, 09:01 AM
#17
Question on old thread.
I'm searching around for prices to have someone install my Bilstein 5100's and FJ coils to replace my stock X-REAS setup due to signs of failure. Dealer wants like $2000 for replacement system, CRAZY... I'm not looking to level out ride or lift it, just want quality ride and similar to factory height.
So my question is that I plan to keep the Bilstein's at stock height for the front. With installing FJ coils as they're a little taller and stiffer, should I gain a little height because of this even with Bilstein's at stock setting for front? For the rear I've heard that you may gain about 1'', but looks more like about .5 if that. My concern is that there is already a factory rake and gaining .5 in the rear and nothing in the front will give more rake and I don't want that...
So as I sit here an scratch my .... I'm pondering what to do with the front adjustments? Any thoughts out there? It's a v6 4wd, so not as heavy in the front and I'm paying for labor. So if I don't like it I'll have to pay again to have it adjusted and another alignment.
Thanks for any help! :-)
Titanium 2005 4Runner Limited v6 4wd; X-REAS removed @ 115,000 miles & 5100's set to .85" w/FJ coils installed all around.
09-11-2012, 04:05 PM
#18
See this thread for more specifics on lift height. Expect around 1" front and .5" rear. If you like the rake stick with that, or use the second notch (.85" lift) for a more leveled look.
http://www.toyota-4runner.org/suspen...e-fj-swap.html
2003 Limited V8 - sold - Build Thread | JL Audio amp/sub | Icon stage 2 | 1/2" Body Lift | 265/70/18 Nitto TG G2's | 18" Limited wheels | Spidertrax | Clazzio's
2016 Trail Premium - Bilstein 5100 | Airlift 1000 | 285/70/17 Cooper AT3 4S | XenonDepot HID | RAV4 Blindspot Mirrors | Kicker Subaru Tweeter Upgrade | Lock'er Down Console Safe | Sprint Booster
09-15-2012, 08:53 PM
#19
Originally Posted by ARK_SWAMP_RIDER
Thank you ARK_SWAMP_RIDER. This is very helpful.
09-16-2012, 01:40 AM
#20
Originally Posted by TRBenj
Its physically possible, but not something I want to do. By extending the XREAS shock with a longer spring, it will potentially increase ride harshness, while decreasing the life of the shock.
Im going to try a top out spacer instead, in hopes of gaining lift while retaining the stock ride quality. I have no plans to add weight to the front, so Im content with the slightly increased load carrying in the rear only.
I installed FJ coils with my XREAS system and loved the improvement. It was firmer, but definitely not harsh. It felt less bouncy, better off-road, and ended my bottoming out over the speed bumps at work. The XREAS shocks are short and droop is definitely limited when you increase your ride height... especially the rear. I drove it for about 1.5 years and just upgraded to the Toytec Ultimate. My setup was...
Front: FJ coils on XREAS shocks with a 1/2" thick Toytec spacer. I ended up with 2" lift (1" from the spacer and 1" from the coils)
Rear: FJ coils with XREAS shocks. I settled out at 5/8" lift.
Doozi's 2006 Sport Edition V6 4WD - Titanium Metallic - purchased 09-13-10
Dobinson's F: C59-302/GS59-220, R: C59-677V/GS59-575 / LR UCA's / Medic links / LT285/70R17 DuraTracs on Countersteer Type-X wheels / WeatherTech DigitalFits and Window Visors / Rear Diff Breather Mod / J.A.'s Fog Light Mod / Centric Premium rotors w/ Akebono Pro-Act Ultra Premium pads / LED interior lights / HIDs (4500k lows) / Man-A-Fre engine+tranny skids / RCI MetalWorks T-case skid / B.A.M.F LCA skids / CBI front/rear, Sherpa Equipment Company roof rack, WKOR sliders welded on, Panhard Correction Kit... Lovin' it!
09-25-2012, 01:37 AM
#21
Yes. Combine them with a ball joint spacer out front and you're set. Refer to my build for more info.
~It's nice to see this thread, 5 years later and people still like the idea. Makes me smile knowing it helps.
02-20-2013, 12:17 PM
#22
Another datapoint
While some people have claimed to only get 1/2" out of the rear FJ coils when installed on their 4Runner, I definitely saw 1" and that never settled over the next 100k miles I ran the set up I described above (stock 4x4 V8 front springs with 2" Daystar spacer and 4x4 FJ rear coils).
At 143k miles, it was time to replace the shocks though, and I wanted to include my new datapoint. I finally ditched the XREAS in favor of the Bilstein 5100's, and wanted to ditch the front Daystar spacer but still remain at the same amount of lift (2" front, 1" rear). I ended up setting the front Bilsteins to the 1.75 notch (3rd notch from the bottom) and replaced the stock 4x4 V8 front coils with the fronts from the same 4x4 FJ that I got the rears from (mothballed in the garage for 5+ years). No pics of the 2 sets of springs side by side, but the FJ coils appeared to be the same thickness but very slightly taller (<1/4"). This was consistent with reports of (4x4) FJ coils providing a slight lift on even 4x4 V8 4Runners.
The 1.75 setting seemed like a no-brainer based on other peoples results here, my debate was which springs to pair them to. Turns out I made the right move with the FJ coils, as I ended up with essentially the same stance as I had originally (2"/1") and am very happy. Measurements and pics to follow.
Of course, handling is worlds better with the Bilsteins all around as compared to the blown XREAS. The front end is a little firmer and body roll is vastly reduced, not sure whether the shocks or slightly firmer FJ springs are to thank for that (likely both, with the Bilsteins getting much of the credit).
I still have a clunk coming from the front over smaller, higher frequency bumps and rough pavement, which I was hoping was due to the old shocks... I will be replacing the front stabilizer bar's bushings and endlinks next to try and eliminate it completely.
Hopefully this post is helpful to some... trying to get lift info with certain components can be somewhat challenging, as people forget that other variables come into play on their results- what configuration their truck is (4wd vs. 2wd, V6 vs. V8, front end weight- bumpers, etc) as well as what configuration their donor parts came from (2wd vs. 4wd FJ). (I still dont run any front weight, by the way- other than some new roof racks and Tundra wheels my set up is the same as pictured above, circa 2007).
'07 4WD Sport V8
Wanted to Trade: My Sport hood <--- Click here
08-23-2016, 09:32 PM
#23
fj swap
Hey maybe I'm crazy but I bought 08 trail team coils from an FJ owner and got absolutely nothing out of it same exact height as before the swap?
08-23-2016, 10:03 PM
#24
Thats prettyweird. But how many milez were on the fj coils. Is it possible you bought tired coils?
09-18-2016, 11:31 AM
#25
I got about an inch of rear lift
using new FJ TT coils and OME trim spacers. Up front its trd tacoma coils. Everything mounted on 5100s.
10-06-2016, 02:31 AM
#26
That is just the answer I was looking for! I heard someone say in a Yotatech thread that FJ Cruiser coils would work on 2nd gen 4runners but I was't sure if they just made a typo and meant FJ80 coils. Thanks for the clarification!
1993 4Runner 3VZE 5speed 4x4 - Mods= K&N air filter, Aisin manual hubs, 32" BFG All-Terrains, LED panel reverse lights.
http://badges.fuelly.com/images/smallsig-us/430552.png
11-01-2016, 02:48 AM
#27
My next mod will be a 2" front spacer to level the truck
My Dear,
you said My next mod will be a 2" front spacer to level the truck
please don't do it , Many sites and manufactures fool people to make money out of them they are thousand so do not be number 2001 , you will face noise and harsh,, but the best professional way is to add thick rubber coil insulators at same time for each spring 2 rubber insulator one top and one bottom of each spring, the result is to gain 2 inch more and isolate the noise and more comfortable feeling.
A few people here have installed FJ Cruiser coils in the rear of their 4Runner to gain about an inch of lift:
2003+ 4runner 5.5" inch lift w xreas - Toyota 4Runner Forum - Largest 4Runner Forum mber=2
http://www.toyota-4runner.org/showth...threadid=22357
The problem is that good info has been tough to come by. These members used the FJ springs in combination with other spacer lifts, so the amount of lift that could be attributed to the springs alone was unclear. Also, both 4Runners in question were 2WD, so I was curious if I would see similar results on my 4x4.
The fact that one member reported a stiffer ride also intrigued me- was it possible that a 4Runner could gain 1" of lift AND some load carrying capacity by making the switch? Stock 4WD FJ springs are readily available for cheap over on the FJ cruiser forums (I paid less than $100 for all 4), so this had the makings of a cheap experiment.
Here is a side-by-side comparison of the rear springs (FJ coils on the left, 4Runner coils on the right):
Observations: The FJ coil is 1/4" taller. Also notice the extra coil over the height of the spring. What may not be obvious is the difference in coil thickness- the FJ coil is 1/32" thicker (19/32" vs. 9/16") according to my antique dial calipers.
Results:
Height with 265/70/17 Firestone Destinations
Before/After
L: 36.0"/37.125"
R: 36.5"/37.5"
Measurements were taken on level ground, at the centerline of the wheel, from the ground to the bottom of the fender flare. No changes were made to the load inside the truck during the install (load was very light and evenly distributed). Tire pressure was a constant 38 psi in both rear tires before and after.
Overall I gained about 1" of lift. The ride (unloaded) seems a *little* firmer, but not very noticeable. I expect the springs to handle weight in the rear better, especially when towing.
***It should be noted that I installed an Air Lift 1000 kit in the rear at the same time I put the new springs in. All "after" measurements were taken with 5 psi in the bags, which is the minimum recommended pressure. They should not have had any effect on the change in height.
My next mod will be a 2" front spacer to level the truck. I will compare the 4Runner vs. FJ front springs at that time. Depending on how they differ, the 4WD FJ front coils may be a good option for someone looking for a mild lift on a 4Runner- possibly dependant on whether the 4Runner is 2WD vs. 4WD, or V6 vs V8.
