Old 07-29-2008, 08:50 AM #1
TopRunner TopRunner is offline
TopRunner is an unknown quantity at this point
Bead locks
CLICK HERE to see the wheels
I saw a set of these "Rock a thon" bead lock rims and thought the looked the teets but then read up on them and learned that not only are they not DOT approved but the are heavy.
I checked out a couple of faux bead locks but then I thought "why bother".
Maybe some one will find a way to interperate the law and make these Rock a thon's street leagal.
TopRunner is offline   Reply With QuoteReply With Quote
Old 07-29-2008, 10:29 AM #2
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
There are a few street legal beadlocks available, but I can't think of the manufacturers names.
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 07-29-2008, 01:27 PM #3
OK, did a bit more reading and research on the bead lock. There are more myths and rumors on these wheels than anything else I have researched on the web thus far.
Basicly you need to check your state laws and make sure the alough 2-piece wheels and check anything else concerning wheels.
Next is the wheel itself, there are 2 kinds. One is cut and welded so it can recieve the lock ring. The other is cast with the intent of being a bead locking wheel.
The welded wheels might be hard to balance. Also because they were altered from there original form means that whatever DOT test they past before alteration, is now nul and void.
I am still interested and will likley do a lot more research. I recomend the same for anyone else that might be in the market.
Old 07-29-2008, 02:00 PM #4
Bowtie3's Avatar
Bowtie3 Bowtie3 is offline
Bowtie3 is an unknown quantity at this point
Bowtie3's Avatar
The only Beadlock wheels that are DOT is Stauns I think....The best beadlock wheels are ones made from one piece aluminum...Walker Evens, Trail Gear. Beadlocks are hard to balance because the bolts that hold them together are not consistent(equal weight, length.etc) Most shops will not balance beadlocks.
For Toyota beadlocks I would go with Trail gear. PM me for price.
http://desertfab.com/
http://www.arizonatoyz.com/
Bowtie3 is offline   Reply With QuoteReply With Quote
Old 07-31-2008, 08:45 PM #5
Good Times's Avatar
Good Times Good Times is offline
Good Times is on a distinguished road
Good Times's Avatar
I am currently running a custom beadlock setup from OMF performance. The wheels were originally a stock 2000+ Tundra (16x7 alum wheel) and was modified to 16x8.25ish after the beadlock was added. (I wanted to widen the wheel so it worked out perfectly).
As you can see it's a very clean setup and works great. To date I have had zero problems and have not heard of anyone experiencing any issues with the OMF beadlocks.
Balancing has been all done at Discount Tire / America's Tire with zero problems (In several shops in CA and NV). Even with the 315/75/16 Goodyear MTR's balancing has not been an issue. I have been told by the shops that they won't be able to balance them perfectly due to the tires but to date I've been fortunate. I also have some rock domes which I thought would make it harder to balance but this has not been an issue.
As for legalities, to date, no CHP or any law enforcement officer or BAR has questioned my wheels. I know of no code in the vehicle code for my state (CA) that states beadlocks are illegal. So until someone proves me otherwise I'll continue to use them.
Btw, for the average abuser, I'd say beadlocks are an overkill. Until you start popping lots of beads on your wheels it probably is not worth the $$.
Side note which is important:
None of the tire shops will install tires on a beadlock wheels. This means that you will have to buy the tires from them and install it yourself. The reason is due to the liability for the improper installation. Shops do not want to be liable so they force the customers to install the tires on their own prior to balancing. So what I've done so far is to bring my beadlock wheel and just install the tire at their shop in the parking lot. Once the tire is installed and all of the bolts are properly set in place, all they have to do is inflate and balance. Can't get any easier than that for them.
Good luck
Good Times is offline   Reply With QuoteReply With Quote
Wheel Question - Bead Lock & Hub-Centric ArcticEd 5th gen T4Rs 9 07-29-2010 10:03 PM
wheel locks :) rx900 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 12-20-2007 10:59 PM
Power Locks on 98 issue???? NIK0 3rd gen T4Rs 5 06-02-2006 10:22 AM
Locks Wont Open!!! Help!!! maluninja Problems & Warranty Issues 3 09-21-2004 11:56 PM
Wheel Locks?? sire Engines / Suspension / Wheels / Tires / Audio / Accessories 2 05-16-2004 06:34 PM
