Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 11-18-2002, 05:08 PM #1
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
Basic article about DIFFERENTIALS, LSD, LOCKERS...
Hey all,
If you guys are ever wondering about :
"What is an open differential?"
"What is a limited-slip differential (LSD)?"
"What is a locker?"
Thanks.
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 11-20-2002, 09:56 AM #2
Thai's Avatar
Thai's Avatar
Here is another basic article
Limited Slip Differentials
by Jim Kerr
Putting the power to the ground is always a challenge for drivers stuck in a snow bank, climbing a loose and slippery hill, or just trying for maximum performance from their high-powered sports vehicle. A limited slip differential may be the answer to help get that vehicle moving.
The General Motors Versatrak axle has clutches similar to a limited slip differential but uses gerotor oil pumps to apply the clutches when axle speed differs from the differential carrier (housing) speed.
Several different types of limited slip differentials are offered from the vehicle manufacturers. Cone type, clutch type, viscous, locker, Torsen, and even electronic are all terms you may encounter when looking at differentials. All of them have the same purpose: transfer the torque from the wheel that is spinning to the wheel on the other side of the vehicle that may have more traction.
There are advantages of using an "open" or non-limited slip differential. They are cheaper to build, they are lighter, they allow the vehicle to turn a corner easily, and they keep the vehicle stable when accelerating on ice because only one wheel spins. Some designs of limited slip differentials act like an open differential during cornering, but other designs keep both drive wheels coupled for maximum traction. When this happens, it is easy for one wheel to slide on a corner and the vehicle becomes unstable.
The most common limited slip differentials found in performance cars and trucks are of the cone or clutch type. Used in the rear differential, these units have a cone or a series of clutch plates connected to the side gears in the differential. The axle shafts are splined into the side gears, and when one wheel slips, the rotating side gear causes the cone or clutch plates to lock or apply. By locking one axle to the differential, the other axle is forced to turn. Many cone or clutch type differentials use preload springs to help keep some tension on the unit at all times. A special oil additive is often required in these types of differentials to prevent the clutches or cones from grabbing or chattering as they apply. Using regular gear oil can cause noise and rough operation that can damage parts.
Locking type differentials are used on some trucks. There are two popular types of locking differentials: the Eaton locker and the Detroit locker. The Detroit locker is a heavy-duty unit found in some 3/4 and 1 ton trucks. It provides positive engagement of both axles while driving. The easiest way of describing it is to say it operates like a ratchet wrench: teeth on the side gears are engaged by "dogs" that prevent the gears and axles from spinning. Detroit locker operation is accompanied by clunks, snaps, and bangs as the gears unlock and lock again after turning a corner. This is disconcerting, but normal.
Eaton locking differentials use small spring loaded weights that spin when one of the axles spins. The weights fly out and catch on a locking dog. This causes a cam plate located behind one side gear to turn and force the clutch plates together, causing both axles to turn at the same speed. Put too much torque through the clutch plates, and the teeth sheer off one of the plates and the differential then operates like an open unit. For this reason, the Eaton locker is designed for low speed operation and slow acceleration. If you want acceleration performance, you would be better to use a cone or clutch type unit. Locker type differentials use regular gear oils. Do not use limited slip additives or the clutches will not work properly.
The Torsen differential uses a combination of gears to split the torque between the axles rather than apply clutches.
The Torsen unit is a performance type of differential. Rather than using clutches, the Torsen design uses parallel helix gears to keep the torque balanced to each drive wheel. It acts like an open differential while cornering (unless you accelerate), and sends power to both rear wheels at any speed or slip condition. The Honda S2000 uses a factory installed Torsen differential, and other manufacturers ranging from Hummer to Toyota have used them in performance models. There are several aftermarket units available.
Viscous limited slip differentials use the properties of silicone fluid to apply torque to both drive wheels. When one wheel starts to spin, it causes half of the housing holding the silicone fluid to spin. When the fluid is forced to spin, it gets thick and transfers the motion to the other half of the housing. This takes place smoothly and quickly, and because it still allows some slip, it is suitable for front wheel drive vehicles too. The silicone housing in Viscous limited slip differentials is a sealed unit, so the differential uses regular gear oil for rear wheel drive applications, or transaxle oil for front wheel drive units.
The manufacturers are starting to build differentials that use oil pumps to apply clutch plates (GM's VersaTrak) or computer-controlled electromagnets to apply clutches (Acura's MDX). Limited slip differentials can offer superior traction, better hill climbing ability, and quicker acceleration. Given the slippery road conditions in Canada during a major portion of the year, I would recommend selecting a limited slip differential option whenever possible if getting another vehicle.
2023 Lexus GX
Lets Go Brandon!
Old 01-11-2003, 12:10 AM #3
Thai's Avatar
Thai's Avatar
Another good article about 4wd systems:
Four-Wheel Drive: Do you have it, know it, need it?
Enjoy!
2023 Lexus GX
Lets Go Brandon!
Old 04-28-2005, 07:23 PM #4
Thai's Avatar
Thai's Avatar
Very nice article on differentials and lockers:
http://www.safari4x4.com.au/80scool/...ffs/diffs.html
2023 Lexus GX
Lets Go Brandon!
Old 11-08-2007, 05:19 PM #5
gotmud?13's Avatar
gotmud?13 gotmud?13 is offline
Banned
gotmud?13 is on a distinguished road
Banned
gotmud?13's Avatar
thai, you are truly a 4wheelin philanthropist. im guessing that someone pays you to do what you do. if not, then even more gratitude from me. im just a sponge right now, soaking up all that is told, and trying to help people like you do. thank you very much, and as neil young once said,
Keep On Rockin In The Free World
Jake Engel
gotmud?13 is offline   Reply With QuoteReply With Quote
Old 11-25-2007, 02:18 AM #6
magnumfan's Avatar
magnumfan magnumfan is offline
magnumfan is on a distinguished road
magnumfan's Avatar
Smile Center Differential in the 4th Gen T4R
Just sufing the net tonight I found this.
http://www.torsen.com/files/Torsen%2...al%20Sheet.pdf
this is the Diff system in the 4th Gen T4R
2006 V6 4x4 White Limited. BFG M/Ts for play and road tires for daily commute
4 Wheel Drive, it helps you go, but does not help you stop....
<a href="http://www.danasoft.com"><img src="http://www.danasoft.com/vipersig.jpg" border="0"></a><p><div style="font-family:Arial,sans-serif;font-size:11px;">Sign by Danasoft - <a href="http://www.danasoft.com">Myspace Layouts and Signs</a></p></div>
magnumfan is offline   Reply With QuoteReply With Quote
Old 04-02-2008, 03:45 PM #7
Spaceman Spaceman is offline
Spaceman is an unknown quantity at this point
ADD
Can anyone explain what the ADD feature is??
It's on P-173 in my book but, I they really don't explain it in enough detail to understand it.
2008 T4R SR5 V6 4WD
LT275/70R17 GY Wrangler SA, >>1" lift.
Total Lift = 2.5/2.5
Clearance now 10.5"
Setup to tow behind motorhome.
Spaceman is offline   Reply With QuoteReply With Quote
Old 04-02-2008, 04:26 PM #8
dingo's Avatar
dingo dingo is offline
dingo is on a distinguished road
dingo's Avatar
No luck with the link, Thai. I'm getting the good old 404.
2007 Sport Edition 4WD V6 Shadow Mica/RSCA and side airbags/Wheel locks/Valor exhaust tip/Front skid plate - 33k miles and counting.
2005 SR5 4WD V6 Titanium Silver/Third row seats/Wheel locks/Valor exhaust tip/Front skid plate - 95k miles and counting.
dingo is offline   Reply With QuoteReply With Quote
Old 06-22-2011, 03:47 PM #9
SjamesT4R's Avatar
SjamesT4R SjamesT4R is offline
SjamesT4R is on a distinguished road
SjamesT4R's Avatar
Originally Posted by Thai View Post
Hey all,
"What is a locker?"
Here is a good beginner article:
Boss News
Thanks.
that article is in german i think
95 Toyota 4runner SR5 3.0 Rebuilt Heads -Toy
Lc Coils-Rear.. BJ Spacers-Front.. 20" Extended brake line in rear and Skyjacker shocks..
305/70R16 Dunlop Mud Rovers Crome Steelies W/ Spidertrax wheelspacers
SjamesT4R is offline   Reply With QuoteReply With Quote
Old 10-01-2011, 03:57 PM #10
Badtoys Badtoys is offline
Badtoys is on a distinguished road
Hey all,
"What is a locker?"
Hboss.net
Thanks.
The Link is dead. Can you please re-post
Thanks
Badtoys is offline   Reply With QuoteReply With Quote
Old 09-02-2014, 04:23 PM #11
beyond beyond is offline
beyond is on a distinguished road
Thanks
updates???
beyond is offline   Reply With QuoteReply With Quote
Old 05-26-2016, 08:54 AM #12
MisplacedTexan's Avatar
MisplacedTexan MisplacedTexan is offline
MisplacedTexan is on a distinguished road
@Thai Hate to necro this thing, but the link
hboss.net
Thanks.
is actually a redirect to all kinds of spam....
MisplacedTexan is offline   Reply With QuoteReply With Quote
Old 05-21-2017, 06:06 PM #13
ed.mathias ed.mathias is offline
ed.mathias is on a distinguished road
Helpful overview, thanks.
ed.mathias is offline   Reply With QuoteReply With Quote
Old 09-01-2017, 11:46 AM #14
KnobbyLife's Avatar
KnobbyLife KnobbyLife is offline
Real Name: Jared
KnobbyLife is on a distinguished road
KnobbyLife's Avatar
Real Name: Jared
Agreed.
My question is if one plans to do light trails to "overland" style offroading, does a rear diff locker make sense..
I currently run LSD... And which one would be the most "straight forward" to install at home... Just curious
Life's short.. so enjoy the hell out of it!
KnobbyLife is offline   Reply With QuoteReply With Quote
IFS + Front Locker Article...informative! Thai Off-Roading 29 01-28-2024 02:56 AM
Differentials - Auto LSD question stockrunner Off-Roading 5 02-14-2011 11:29 AM
LSD confussion JuanSJO 3rd gen T4Rs 3 04-22-2008 03:58 PM
All types of Differentials and Lockers Explained JP4RNR 4th Gen T4Rs 1 06-19-2007 09:48 PM
