Old 08-24-2009, 01:37 PM #1
jmauld jmauld is offline
jmauld is an unknown quantity at this point
3"/2" lift questions
I'm considering getting a spacer kit to lift my 04. Are there any issues with suspension geometry by doing this lift with spacers? I know it will need an alignment, but beyond that?
Jason
'04 4Runner V8 LTD.
jmauld is offline   Reply With QuoteReply With Quote
Old 08-24-2009, 01:40 PM #2
03L4RUNNER's Avatar
03L4RUNNER 03L4RUNNER is offline
03L4RUNNER is on a distinguished road
03L4RUNNER's Avatar
NOne that i know of, Ive been running Cornfed 3/2 for over two years now and its holding up well
2003 Limited 4WD V6
OME W/Toytec Topout, LR UCA's, 255/80R17 BFG KM2's, Defiant LB, Viair OBA W/Mack Horn, Tundra Split Spokes, Wet Okoles, 5% Tint, K&N CAI, and various other additions
03L4RUNNER is offline   Reply With QuoteReply With Quote
Old 08-24-2009, 01:43 PM #3
Also. I use the truck to yow a race car. Do any of you hav experience towing about 5000lbs with it lifted?
Jason
'04 4Runner V8 LTD.
Old 08-24-2009, 01:48 PM #4
03L4RUNNER's Avatar
03L4RUNNER's Avatar
Just to confirm, you do not have the Limited Air ride system in the back correct?
The tow shouldn't be a problem. I've towed many loads of lumber/boats/4 wheelers and had no problem
2003 Limited 4WD V6
Old 08-24-2009, 02:31 PM #5
bt216's Avatar
bt216 bt216 is offline
bt216 is an unknown quantity at this point
bt216's Avatar
I tow as well, I would reccommend OME springs with a 1-1.5" rear spacer in the back in addition to keep the factory stance.
December '08 T4ROTM
http://www.toyota-4runner.org/showth...threadid=43414
2004 Limited 4WD V8
bt216 is offline   Reply With QuoteReply With Quote
Old 08-24-2009, 03:41 PM #6
richyrich307's Avatar
richyrich307 richyrich307 is offline
richyrich307 is an unknown quantity at this point
I would consider the OME springs as well. However if you go with the OME springs there really will not be a need for the spacers. Since you cant buy just the front spacers I dont know if that would be your best route. If it was me I would just spend a little more and get the OME rear springs and shocks as well as the front OME springs and shocks. Around $780 for the whole OME setup. Its even cheaper if you go with the bilstein shock. You could also stay with your current shocks and just buy the spings from OME. This would run you around 320. I would take a longer stiffer spring over a spacer any day.
richyrich307 is offline   Reply With QuoteReply With Quote
Old 08-24-2009, 03:59 PM #7
What are the spring rates between the Stock springs and the OME springs?
Jason
'04 4Runner V8 LTD.
Old 08-24-2009, 04:08 PM #8
bt216's Avatar
bt216's Avatar
OME have different spring rates options.
You can buy just the front or rear spacers from burtmanindusties.com.
The rear OME springs are are ~2", therefore if you want to raise the front and rear equally you will need a ~1" rear spacer on top of your OME spings. I would also suggest the bilstein 5100's
December '08 T4ROTM
2004 Limited 4WD V8
Old 08-24-2009, 04:16 PM #9
I need to know what the spring rates are. My wife uses the 4Runner as a daily driver, so I can't throw a set of stiff springs on there without having an idea of how they're going to feel.
That's the biggest appeal of the spacers, the spring rate remains the same, or at least relatively close.
Jason
'04 4Runner V8 LTD.
Old 08-24-2009, 04:25 PM #10
bt216's Avatar
bt216's Avatar
here is the info you need...
http://www.toyteclifts.com/index.php...mart&Itemid=72
December '08 T4ROTM
2004 Limited 4WD V8
Old 08-24-2009, 04:33 PM #11
Im sure bt216 is probably right about buying the front and rear spacers seperatly from burtman. The OME spring rates go light to med for the rear and for the front it goes light, heavy, extra heavy as per Allpro offroad. If your serious about towing allpro make a 3.5" taller rear spring that is 20% stiffer than stock. However I am not sure what you would do with the front, as the 3" spacer from burtman is not nearly tall enough to provided a level front and rear when matched with the allpro 3.5" rear spring. Give Terry a call at allprooffroad.com. He is very Knowledgeable on all aspects of toyota suspension. He is a great guy too.
Old 09-16-2009, 01:15 PM #12
Just an update, I think I've changed directions a little.
I'm currently thinking about going with Bilstein 5100s in the front, Bilstein HDs in the rear and FJ springs all around. Once we need tires again, I should be able to lift the front with the Bilsteins and then use a small spacer in the rear, so that I can run a taller tire.
Any holes in that plan?
Since Bilstein doesn't list an application for the 5100 on the 4Runner, is this the correct part no: F4-BE5-C475-H0 It's the listing for the FJ.
Jason
'04 4Runner V8 LTD.
Old 09-16-2009, 01:26 PM #13
The part number for the FJ and the 4runner are probably the same as most of the suspension is interchangable. Im sure that you already know but the shock alone will not get you any lift in the front. You will need a taller spring or spacers in the front as well as the rear.
Old 09-16-2009, 01:32 PM #14
This makes it sounds like you do get some adjustment out of the 5100 strut.
The 5100 Series (Ride Height Adjustable) shocks feature multiple snap-ring grooves on the body of the shock to accommodate different spring seat positions, allowing height adjustments from 0" to 2.5", depending on the application. By raising the spring seat position, the factory rake can be altered to achieve a level front to rear ride height while accommodating up to 33" diameter tires.
Is the extended length of this strut the same as the stock struts?
Jason
'04 4Runner V8 LTD.
