Old 01-09-2011, 01:59 AM #16
JB.'s Avatar
JB. JB. is offline
JB. will become famous soon enough
JB. JB. is offline
JB.'s Avatar
Originally Posted by Joshua8200 View Post
Yeah, I'm looking for an explanation of this line. I find it hard to believe that a set of SAE S Class chains would not be OK on the front tires. I mean if chains are made that will fit FWD cars...surely chains can be fit tight enough on a 4Runner.
I've always been satisfied with the "too much important stuff up front with questionable clearance" explanation, but who knows.
As for the clearance,
My tires are stock width ATs and 1"taller. Clearances are: upper control arm 1.5", top of steering knuckle 1.1", down a short ways on the knuckle there is a bump, that clearance is barely more than 1/2" although it appears the bump would be below the hoop of properly fitted chains as long as they were kept tight.
If I could fit them, I'd be more comfortable running chains in front than cables. A little loosening with chains would give a very audible but probably harmless warning. With thrown cables, the audible warning could easily coincide with big trouble.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
JB. is offline   Reply With QuoteReply With Quote
Old 01-12-2011, 07:14 PM #17
Will_4R's Avatar
Will_4R Will_4R is offline
Will_4R is on a distinguished road
Will_4R's Avatar
Fitment is the main issue. Even with stock tire size I would get occasional rubbing in certain situations. I run chains somewhat regularly in the back, and I wish I could run them on all fours but don't. I have tried fitting my chains (S-class diamond link) on the front in the garage to see how they fit, and it was way to close for comfort. I still have the occoasional rub with my current set-up (2.5 in lift and 265/70-17s).
2003, Sport, V6, 4WD
Overland Warehouse/Radflo 2.0 suspension, SPC upper control arms
2016 Trail Edition w/KDSS
Icon Stage 2 suspension, BFG T/A KO2 285/70/17, C4Fab sliders
Will_4R is offline   Reply With QuoteReply With Quote
Old 01-13-2011, 11:13 PM #18
Joshua8200 Joshua8200 is offline
Joshua8200 is on a distinguished road
Many thanks, I really appreciate your information! So you'd get rubbing with S-Class Diamond Chains when they were on the back? Do you know the brand/model? I have been looking at this style of chains also.
Joshua8200 is offline   Reply With QuoteReply With Quote
Old 01-14-2011, 01:34 PM #19
Will_4R's Avatar
Will_4R's Avatar
I have never had any rubbing in back, with or without chains. The rubbing is in front (without chains), and only while braking with the wheels turned, like coming into a corner at speed. Although I wouldn't be driving that way with chains, it is an indication of how little room there is up there. I do find that offroading in winter the wheels get flexed and there is tire spinning in slippery situations, so it isn't always easy to drive slowly and carefully.
My chains are the SSC Whitestar Alloys.
Old 11-05-2015, 06:19 PM #20
funken funken is offline
funken is on a distinguished road
Anymore thoughts on chains on the front (2004, 265/65/17 stock)? I am looking for the strongest, grippiest chain I can fit without doing damage. I plan on using them off-road only going about 5 mph.
funken is offline   Reply With QuoteReply With Quote
Old 08-30-2021, 06:08 PM #21
draganov3006 draganov3006 is offline
draganov3006 is on a distinguished road
Hey, any final solution/s to this issue?
So far people mentioned spacers to the front wheels - prefer not to go this route.
draganov3006 is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 08:46 PM #22
80proof's Avatar
80proof 80proof is offline
80proof is on a distinguished road
80proof's Avatar
The best thing to do in the snow is air down. I regulary snow wheel in 4'+ and the best thing you can do is air down, way down. Without beadlocks 6psi is a safe number as long as you aren't bouncing around in the ditches. the bigger the contact patch, the more traction and flotation you have.
80proof is offline   Reply With QuoteReply With Quote
Old 11-08-2021, 11:33 PM #23
Chipmunkyota Chipmunkyota is offline
Chipmunkyota is on a distinguished road
You could try low profile chains sized down one size for tight fit if fronts must be run. Don’t drive then on pavement, might pop off!
Chipmunkyota is offline   Reply With QuoteReply With Quote
Old 11-09-2021, 07:18 PM #24
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
I always assumed that since the vast majority of 4x4s now use independent front suspension and swing axles, that was the reason manufacturers state chains cannot be used on the front. But the correct argument that front wheel drive vehicles are chained up in front belies that claim.
I sometimes wonder if it is more of a disclaimer by the manufacturers to avoid a lawsuit if someone inexperienced in chain installation tears up the front end simply because they didn’t install adjusters with their chains and chains fell off into the inside of the tire at speed and ripped up CV boots, brake lines and other mayhem.
In the old days I chained up the front end of my 1970 Ford F250 4x4 because of the engine weight. That’s what everyone who lived in my tiny mountain hamlet did. If roads were bad enough to require all wheels chained, the roads were already closed anyway.
I have a set of NAPA heavy duty V bar truck chains for my 4Runner that I originally purchased for my 2002 Tacoma TRD. To date they’ve never been used, even though I regularly ran deep snow off road and on.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Brand New SCC Super Z LT Snow Chains airbur Classifieds - buy & sell (no commercial ads please) 1 05-22-2008 07:08 PM
Revo's or Destination AT's DTro Engines / Suspension / Wheels / Tires / Audio / Accessories 87 06-24-2007 07:12 PM
18" vs. 17" wheels Atomic 4Runner 4th Gen T4Rs 22 06-25-2006 02:33 PM
20inch Chrome Wheels With Tires, Like New, Great Price! The Razor Classifieds - buy & sell (no commercial ads please) 0 05-28-2005 04:07 PM
Wheels! What things to consider when shopping... Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 3 01-03-2004 04:05 PM
