01-02-2011, 12:51 AM
No snow chains on all four wheels?
I've been unable to find a satifactory explanation as to why you cannot properly install chains on the front wheels of a 2005 4Runner.
I recently came across the rarest of situations that required chains on my 4x4 SR5 4Runner. Actually...I was able to get up the hill simply in 4wd. I did not fair as well on the descent, but was able to make it into a driveway (just not the right driveway). Two other vehicles coming down ended up in ditches. The tow truck ended up in the ditch too, but was able to fight their way out.
I ended up borrowing some cables, and used them without any problems on the hills for the last few days. I put the cables on all 4 wheels in order to drive up and down these beastly steep and icy hills to access a vacation cabin.
Did I get lucky that I didn't mess anything up by putting cables on the front wheels? Would chains have messed something up? Are cables OK on the front, but not chains because of clearance issues?
Here's a picture of the carnage:
Note the tire skid marks in the foreground of the picture are from the tow truck sliding around when they turned around.
01-02-2011, 01:04 AM
More views of the fun:
I was able to stay on the road once I started sliding. When I came to a stop, I was perpendicular to the road. I busted up the ice and pulled into the driveway pictured.
Luckily I was out of the road, when this the Explorer started sliding.
You can also see, the ditch on the right side of the picture looks kind of chewed up. That's the ditch the tow truck ended up in (they didn't chain up either). The tow truck driver managed to back the truck down the ditch by riding the edge and taking out and using the saplings lining the ditch for traction. At the bottom of the hill, he changed his underwear and took a smoke break before declaring that anyone stuck on that hill was just going to have to be there for awhile.
Looking down from about 1/2 up:
01-02-2011, 01:18 AM
Real Name: Chris
Real Name: Chris
In stupidity, ive seen numerous people put chains on the non-drive wheels , but in some situations ive seen 4X4's with front chains or rears. I understand cuz it helps heavier vehicles like 3/4+ ton trucks and large SUV's stop in snow/ice , but get stud's and you wont regret it!! Where was this?
2007 SE V8
HID's, interior LED mod, sweet floor mats, awesome tunes and some more stuff...
...more stuff
01-02-2011, 01:54 AM
This is near Gatlinburg, TN. The road pictured is paved but not maintained (except for about 25lb of salt put out by a gentleman that lives at the top year round and some shovel work my brother and I did). I highly doubt NC or TN allow you to run on studs...
01-02-2011, 03:52 AM
Did you use downhill assist? If there was ever a legitimate use for it, that was it.
Front clearance is very tight and, between brake lines and steering components, you wouldn't want any stray cables or chains getting loose up there. Put your hand over the top of the tire and feel down the other sidewall past where it starts to curve in again towards the wheel. You'll feel what I mean.
I've considered tight clearance cables for the fronts but never used them. I'd say keep the speed way down compared to having them on rears only. That would give you a chance to recover from anything coming loose -- and cables can come off if you ever have to spin them.
They do make expensive gizmos that don't use the innner side of the tire.
Good chains on the rears takes care of most everything but, with rears only and when it's that bad, it's advisable to take a close look at terrain and steering lines for coming down. The smallest patch of good traction can keep you headed in the right direction. I'll bet that was nearly impossible to even walk on. I have a foldable hiking staff in my truck at all times for, among other things, stuff like that.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
01-02-2011, 08:38 AM
Yes...and it was working very hard. I'd like to say my driving ability kept me on the road...though maybe the DAC is what allowed me to maintain enough control to stay out of the ditches.
Many a butt was busted slipping and sliding on at hill, even trying to walk on the softer snow. I had ski poles to help out, but a set of crampons would have been better.
01-02-2011, 11:09 PM
Moderator
Real Name: The Chosen One
Moderator
What makes you think you can't ??
'89 4Runner SR5 - stock
01-03-2011, 03:07 AM
From the '05 manual.
"Do not use tire
chains on the front tires."
2005 Limited V8
5th gen SR5 springs
Hanna sliders
01-03-2011, 10:51 AM
"Do not use tire
Yeah, I'm looking for an explanation of this line. I find it hard to believe that a set of SAE S Class chains would not be OK on the front tires. I mean if chains are made that will fit FWD cars...surely chains can be fit tight enough on a 4Runner.
01-03-2011, 11:57 AM
I think they write this in the manual because on newer cars, there isn't that much space in the front wheel house. And to avoid damages, they give that advice.
greetz, Tom
OFFROAD JUNGLIST
1991 4Runner V6, 4" Trailmasterlift, 295/75R16 BFG AT
01-03-2011, 01:25 PM
I've been up in the mountains above Gatlinburg many times. Every time hoping to get a large snow fall to see what it would be like. But in the back of my mind, I would have been very nervous had it happened.
So after you put the chains on all (4) wheels you didn't have any problems at all going up and down?
01-03-2011, 02:15 PM
Because the distance between the inside of the tire and the front upper control arm is too close. If you add wheels spacers, get skinnier tires, or get wheels with less backspacing then you could run chains in the front without issue. The manual just doesn't advise it because they know people can't be trusted to make decisions like that.
Studs are for ice or just a couple inches of snow. More than a few inches and the studs won't dig down deep enough to hit the pavement so they won't do you much good on an unplowed road.
Putting chains on the front works better than having them on the rear (for any kind of front-engine 4x4 vehicle). The weight of the motor gives you better traction on the front tires and you'll have much more steering control. And yes, it's hilarious when people put their chains on the wrong drive wheels on a 2wd. I would highly recommend not using cables because they are junk and you'll waste money. When you really need them, they'll break or just fall off.
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
01-08-2011, 03:31 PM
Are you absolutely positive of this? The specifications for SAE class S chains needs only 0.59in of clearance. I haven't gotten out a ruler to measure the clearances, but I surely don't see anything that would be anywhere near that close. Even the other classes of chains need very little clearance (1.5in at the high end). Snow chains - Wikipedia, the free encyclopedia
It is my hypothesis that Toyota lists only putting them on the rear tires because the standard 4Runner is RWD, and 4x4 is optional. The recommendation in the manual is made universally for 4Runners with standard equipment and does not account for 4x4 models.
I asked at the dealership and spoke to a service technician. He hypothesized that it was because of clearance issues but did not know of the SAE class specifications and clearance classes.
01-08-2011, 03:34 PM
No problems whatsoever. I could literally stop and go on the hill, even when it was icy, at will.
01-08-2011, 03:49 PM
No, I'm not sure about your particular truck because that depends on a few things... tire size (width), A/T or M/T, and wheel backspacing. I was just saying that if you in fact can't run chains on the front, that would be why (the clearance between the tire and the UCA). Chains loosen up and flop around as you use them, and sometimes have to be tightened a few times as you drive on them. As a rule of thumb, I wouldn't run chains up there unless you have at least an inch of clearance.
