10-13-2014, 07:44 PM
#1711
Real Name: Al
Real Name: Al
so for the past weeks.. I have been to the range 4 times and put about 500 rounds through the bcm.. and needless to say, I'm pleased with the results.. I had one issue where the casing was stuck but other than that.. is been flawless..
these past 2 weeks, I have been to the range more times than I have in the 1st 6 months of this year..
99' 4runner Sr5 4wd
Goodyear | Piaa | Hella | Smittybit | BAMF |
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
10-15-2014, 03:43 PM
#1712
Moderator
Moderator
Originally Posted by LandCruiser
The fit and finish is surprisingly great, they just didn't stake the gas key--which left me with some work to do before shooting it.
The RA308 is over 1 grand more and looks the part, but both will group about 3.5-4" at 300 yards, which is pretty damn nice.
Cool. looking forward to seeing the RA308 after the cerekote job.
Originally Posted by NoHair
Bada$$. Did you shoot from that position while driving?
Kevin's 2008 4x4 Build Thread
Perkins Performance | Shrockworks | Demello | BudBuilt | ICON | Warn | Overland Warehouse | Goodyear | Lightforce | Spidertrax | Powertank | Complete LED Conversion
10-15-2014, 04:21 PM
#1713
Maybe.....
Bunny through FLIR.
10-15-2014, 04:39 PM
#1714
Moderator
Moderator
@ NoHair
Awesome. I need to make it down to Oregon more often. nothing that fun up here in Seattle.
10-17-2014, 04:43 AM
#1715
Real Name: Sparky
Real Name: Sparky
Can't sleep, so I built this from spare parts.
10-20-2014, 06:00 PM
#1716
Keeping an eye on these fine ARs you guys are putting together ! Been awhile for me but I'm getting back into shooting . Have taken alot of you guys idea's for my AR . Great jobs by all !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
10-23-2014, 01:18 AM
#1717
Real Name: Al
Real Name: Al
so this weekend.. me and my boys are going to the hills for some fun..
my question is though..
has anyone ran steel case ammo through there ar? cause, they have spam cans of .223 at wally world for $119..
I figure, for plinking it wouldn't be idea.. I rather save my brass case for carbine class.. cause at $4 dollars and some change for 20 rounds.. is alot cheaper than buying brass.. and on top of that, if my ar can't run steel case ammo.. there is some serious issues there.
99' 4runner Sr5 4wd
10-23-2014, 11:55 AM
#1718
i haven't done it personally, as I do not own an AR, that said..
ive read a LOT about it, and I see no reason why it would be an issue. the steel in the rifle is much harder than the steel case. there are many guns out there that have shot many thousands of steel cased ammo, and are still functioning just fine.
for the amount you would be using, and at the cycle rate, even IF there was some accelerated wear, it would be so insignificant you wouldn't ever know about it.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
10-23-2014, 12:13 PM
#1719
Real Name: Sparky
Real Name: Sparky
Steel cases (which are a mix of steel and copper jacket) will wear out your barrel faster. Lucky gunner did a test.
This isn't a huge issue for pistols, rifles are a different animal due to the much greater forces involved.
http://www.luckygunner.com/labs/bras...el-cased-ammo/
10-23-2014, 12:16 PM
#1720
I guess I'll share some of my collection.
'07 sr5 4x4 4.0
10-23-2014, 12:29 PM
#1721
how can barrel wear be caused by the CASE? that would be a projectile issue.
chamber, and extractor wear I can see being possible, but barrel? not seeing it.
10-23-2014, 12:48 PM
#1722
Real Name: Sparky
Real Name: Sparky
Commie ammo is steel case, often with lacquer, and the jacket is a mix of steel and copper.
Steel case is a misnomer, or at least an inadequate descriptor.
10-23-2014, 03:14 PM
#1723
Real Name: Josh
Real Name: Josh
I've shuffled some rifles around and consolidated on these 2 as my only AR's. Top one is a BCM SOCOM M4 rifle, bottom one is an LMT Defender upper on a lower I built using a RRA receiver and BCM and Daniel Defense internals.
10-23-2014, 05:24 PM
#1724
Originally Posted by darkie3495
Throwback Thursday
Please tell me you have some information posted somewhere about that drawer.
I've been wanting to buy/ build something like this an this is just the inspiration I need. Show me the way!
10-23-2014, 07:02 PM
#1725
@ NoHair
Don't get me started about Here in NY... you'll get locked up if you get caught carving what looks like a handgun out of ivory soap.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
