11-03-2019, 09:45 PM
#3061
Cool thread. I actually customize pistols for a living.
Here some I just did.
11-05-2019, 01:36 AM
#3062
Nice stipple work, very clean and sharp!
11-08-2019, 08:51 PM
#3063
Just completed my first ever AR build
16” overall length barrel
Hopefully it shoots as nice as it looks
2006 limited v8 4wd
Toytec/ebiach 3” coilover lift with 1/2” top plate spacers, Jba high caster UCA’s, blistein 5100 rear shocks with toytec superflex hd springs, Cooper st max 255/80/17 with mb 352 in 17x9 -12 mm offset, auxbeam light bar in front bumper, custom retrofit headlights, SS brake lines, 5th gen brakes, custom rear storage box
11-10-2019, 09:48 AM
#3064
Originally Posted by Mclark202
If you can’t walk into your safe, you might be doing it wrong....
Man is ready for a war!!! God bless, lol.
11-10-2019, 02:26 PM
#3065
Real Name: Eddie
Real Name: Eddie
I immediately thought of this scene (great movie IMO) when I saw your pic.
Eddie
2001 T4R SR5 - 180k miles and counting.
11-10-2019, 06:03 PM
#3066
My 2 9mm SBRs.
2018 T4R TRD ORP
11-16-2019, 11:41 PM
#3067
10mm is awesome. Ive had one for decades....finally it is coming back around. Just a short note...your giving every advantage of the 10mm up with the short barrel your using. Others are much better if your going short...need 5 or more for the 10mm to really shine.
He who Shi% fast does not Shi% for long!!
BILSTEIN CUSTOMER SERVICE SUCKS MUNG COVERED BALLS!!!
11-17-2019, 12:57 AM
#3068
Console Vault mod using ammo can!
Been meaning to post this for a while.
I picked up a console vault and my first reaction was !! WTF !!
There is a 'notch' in the vault metal for the storage console accessory panel. This panel had a coin holder, and the audio 'aux' input jack.
So I got me an ammo can and went to work.
I cut down the ammo can and placed it with more than enough notch coverage, then made sure the placement was correct before marking where to drill mounting holes in the bottom. I had to remove the entire center console to accomplish this.
I also needed to trim the existing storage bin 'plastic', but this does not matter because the entire vault just bolts into the storage space anyway. I added extra washers to avoid crushing the bottom of the plastic storage bin.
My 4R had a 'blank' button in the center console, so I just reloaded the blank with the 'Aux' jack. I was able to trim the 'blank' filler to fill in the slight gap due to the aux jack size difference (not pictured). I was surprised it fit so well.
11-17-2019, 01:56 PM
#3069
Shot my 1st ever Deer yesterday late afternoon with a Federal 62gr Fusion out of my Windham AR15 Carbine. I guess it was a 50 to 75yd shot. The Deer jumped up in the air and landed DRT.
Tele-checked it, field dressed it, brought it over to one of the CWD testing sites last night. Dropped it off at the processor this morning. I figure putting meat in freezer allows me a buffer to look for a bigger buck.
I still have another Doe Tag and an Any Deer Tag to use.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
11-18-2019, 09:20 PM
#3070
[QUOTE=Friggin Idiot;3354106]It's always a good day when the SBR you assembled runs smooth and makes lots of little holes without a single issue on first use. Only had to adjust the sights a little. (Most of the holes outside of 10/head were DA sight acquisition pistol drills at 30ft.)
Attachment 343784
//SuperTroopers
"Been on all morning!"
"What about that little fella'?"
"That little guy right there, don't worry about that little guy."
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
11-18-2019, 09:24 PM
#3071
Originally Posted by a47chuck
The latest is my Saint AR Pistol. Got a couple of "Scary" black rifles. And yes ... according to my birth city ... San Francisco (Still won't call it "Frisco"), I am a "Domestic Terrorist". Shit Heads!
I didn't expect much from GSG .22 1911 clone, but the damn thing shoots amazingly well and digests whatever ammo I feed it (contrary to about every other 1911 I've owned). Great practice gun, points like second nature, cheap... love it!
11-19-2019, 01:16 AM
#3072
11-19-2019, 01:20 AM
#3073
What are the top two carbines about? thanks
11-19-2019, 02:27 PM
#3074
Official T4R "Firearms" thread
Reising Model 60 and Smith & Wesson Light Rifle. The Reising is in 45 ACP and the S&W 9mm. Both WW2 era carbines.
11-19-2019, 04:11 PM
#3075
that large S&W magazine thru me. At least I was right on the .45 mag. thanks
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
