Old 02-07-2015, 02:45 PM #1
JayceeP's Avatar
JayceeP JayceeP is offline
JayceeP is on a distinguished road
JayceeP's Avatar
How do I repair cement garage floor?
Hey everyone,
What is the easiest way to repair the entrance of my garage? The builder obviously did a shitty job laying he concrete and it's been flaking over the last couple of winters. I'm sure driving over it doesn't help either.
Are there any quick cement repair kits for a job like this?
How do I repair cement garage floor?-image-jpg
2012 Shoreline Blue LE 4WD w/ 3rd Row.
JayceeP is offline   Reply With QuoteReply With Quote
Old 02-07-2015, 02:46 PM #2
JayceeP's Avatar
JayceeP's Avatar
Another shot:
Old 02-07-2015, 02:49 PM #3
Range Range is offline
Range is on a distinguished road
Do a search on Home Depot for garage sealers. Its a light grey coating that makes your garage floor very smooth and shiny and easy to clean.
Range is offline   Reply With QuoteReply With Quote
Old 02-07-2015, 02:51 PM #4
JayceeP's Avatar
JayceeP's Avatar
The portion that extends beyond the garage door has a rough/textured finish with fine ridges. Would I want that part to be polished/smooth, or is it just an aesthetic thing?
Old 02-07-2015, 02:57 PM #5
It's both in my opinion. I really liked having it in my old house because it looked good, it was easy to clean and you could always just reapply in areas if at any time you dropped something heavy and it chipped. As far as the area you're talking about I've never done anything to it and it never gotten so bad it needed to be fixed. I think the aesthetics are what's bothering you so maybe a uniorm look would help.
Old 02-07-2015, 03:01 PM #6
JayceeP's Avatar
JayceeP's Avatar
I'm just worried about it crumbling more. As you can see, in th first picture, the gap between the cement and asphalt and wobbly so to speak as a result of stones breaking away from the concrete base. I just don't know how much more it will go. Thanks for your help.
Old 02-08-2015, 10:46 AM #7
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
I was recommended a product called "Tilt Finish by Mapei" for fixing a couple chips in my sidewalk last summer, might work well to fill in the surface of your pad as well. I'd look at some sort of sealant for the whole pad afterwards to keep it from happening again/getting worse. I used a white glue-like product that came in a 5 gallon pail to seal my pad, clean it really well, apply with a roller kind of stuff.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 02-09-2015, 09:03 AM #8
NoDak's Avatar
NoDak NoDak is offline
Real Name: JR
NoDak is on a distinguished road
NoDak's Avatar
Real Name: JR
in winter you will get that a lot. the minute pores will freeze and crack over the winters to the point it will need to be redone.
the melting/freezing will get worse unless you seal it. I am having the same issue but with the addition of the foundation settling at different rates inside and outside the garage.
dreading the cost of redoing all of this or going the cheap route and doing some mud jacking under the foundation.
80 PhoenixLJ/84 CelicaGT/84 & 87 Cressida/89 Toy Truck 2wd/91 Cressida x 2/93 Paseo/96 Protege/98 4Rv6/04 4R Sport v8/06 Taco AC v6/07 Sonata SE v6/09 Rav4 v6/10 Legacy 3.6R/12 Taco DC v6/09 Avenger SXT/09 Corolla XLE/14 4R LE/14 Rav4 XLE/15 Camry XSE/16 Taco DC v6 Sport/16 Highlander XLE/18 Tundra Plat/18 Santa Fe Ult
2014 4R LE Classic Silver Build Thread
E5-Exhaust Tip / MF-Mudflaps / R6-Running Boards / 2Q-All Weather Mats / 3P-Paint Protection Film
NoDak is offline   Reply With QuoteReply With Quote
Old 02-09-2015, 10:35 AM #9
TOY2G TOY2G is offline
Real Name: Nathan
TOY2G will become famous soon enough
Real Name: Nathan
I'm just going to put this right here for you... Does not really help the OP.
Foam Jacking by Concrete Jack | Concrete Jack Foundation Repair & Concrete Lifting
TOY2G is offline   Reply With QuoteReply With Quote
Old 02-10-2015, 08:41 AM #10
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
GO to Lowes, get some epoxy made for this, mask you a line right across the door opening and just do the damaged part. No real masonry fix besides chipping it out and re doing it.
1engineer is offline   Reply With QuoteReply With Quote
Old 02-10-2015, 09:45 AM #11
Omar RVA's Avatar
Omar RVA Omar RVA is offline
Real Name: Omar
Omar RVA is on a distinguished road
Omar RVA's Avatar
Real Name: Omar
This.
I'm going to piggy back on 1E a bit here. If this was a bridge deck, we would saw cut <1" (depth) around the damage, chip it out, use a structural epoxy on the edges and fill with high strength, rapid set concrete. You'd do well enough to use something like this on the damaged areas, and if it makes you feel better, run some epoxy or sealant (look here) along the edge where the asphalt meets your garage's concrete. Make sure you pressure wash it all first to clean out any salts, oils and debris. Since you have a lot of spalling, sealing the edges of the patches may not be realistic, but it would help with the longevity of the patches.
If you're wondering, it looks like the concrete spalled because they (the builder) dumped water on that "ramp" area to keep it more workable and get the fines to float up so they could get you that textured finish. At the end of the day, you can't "fix" bad concrete (only long term fix is to cut out and replace), so you may have to maintain the surface repairs every few years in the future.
OA
Current - 2020 Ram 2500 Power Wagon
Sold:
2016 Tacoma DCSB TRD Sport V6 4x4 6MT!
2010 Limited Classic Silver - JBL, No Nav, Shrockworks Trail Rocker Trim, otherwise bone stock
Last edited by Omar RVA; 02-10-2015 at 11:46 AM. Reason: Added some clarity to my response
Omar RVA is offline   Reply With QuoteReply With Quote
Old 02-10-2015, 09:47 AM #12
1engineer's Avatar
Moderator
Real Name: Greg
Moderator
1engineer's Avatar
Real Name: Greg
Originally Posted by Omar RVA View Post
This.
I'm going to piggy back on 1E a bit here. If this was a bridge deck, we would saw cut <1" around the damage, chip it out, use a structural epoxy on the edges and fill with high strength, rapid set concrete. You'd do well enough to use something like this on the damaged areas, and if it makes you feel better, run some epoxy or sealant (look here) along the edge where the asphalt meets your garage's concrete. Make sure you pressure wash it all first to clean out any salts, oils and debris.
OA
This^^^
You design the target, I'll design the weapons lol.
Old 02-10-2015, 06:25 PM #13
JayceeP's Avatar
JayceeP's Avatar
This.
OA
Thanks guys, that's awesome. I'll look this up!
Old 02-12-2015, 02:39 PM #14
paddlenbike's Avatar
paddlenbike paddlenbike is offline
paddlenbike will become famous soon enough
As others have pointed out, that's called spalling and if you want to prevent further damage you can do something as simple as using a self-leveling concrete repair product from a company like sakrete. I had the same problem with my driveway and my repair has been holding fine for 4+ years with no additional spalling taking place.
2000 4Runner 4WD - lifted, e-locked, TRD supercharged 5-speed | MY BUILD THREAD
paddlenbike is offline   Reply With QuoteReply With Quote
Garage floor stain/droplets awdjunkies 4th Gen T4Rs 10 12-03-2014 05:05 PM
Garage Floor ran Off Topic 2 06-30-2011 12:42 AM
Garage floor Paint ran 4th Gen T4Rs 6 01-19-2008 09:33 PM
Coating for New Garage Floor claydoctor 4th Gen T4Rs 4 07-11-2006 09:51 PM
garage floor - Rustoleum Epoxy? drake3 Off Topic 3 06-22-2006 03:53 PM
