Old 03-23-2015, 11:04 AM #1
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
Repairing Broken Plastic Heater Core Pipe
Some auto mfgs. elected to use plastic for the heater core pipes that run from the heater core thru the firewall.
Working an issue with one of my older Asian SUVs. Had to pull heater hoses off the plastic heater core pipes. One held up; the other broke, but much of it is still intact. I could bypass the heater, but that ain't fun in the winter.
I plan on using a Dayco plastic hose connecter - 1/2" on one end ; 5/8" on the other to patch broken plastic heater core pipe. The 1/2" side of the Dayco connector fits somewhat snugly in the broken plastic heater core pipe. I have to be careful just how far I insert this patch piece in order to not impede coolant flow. The patch piece is straight and the broken plastic heater core pipe is elbowed
Dorman Products - 47081
I need to seal this connection and am thinking about using a JB Weld product. I've gone thru their web site and see they have products for plastics, but am not real sure which will withstand heated coolant(temp and chemical composition). At homedepot.com I see KwikWeld and a lot of talk about how it would be perfect for my situation, but to my knowledge, KwikWeld is just a faster curing version of basic JBWeld which is not suitable for plastic.
Perhaps there's a better product to use for this situation or someone here knows of a suitable JB plastic product that fits this situation. Hoping to get it right first time.
Thoughts appreciated. Thanks for your time.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 03-24-2015, 02:01 PM #2
Decided to call JB Weld. Here's what they recommended:
HighHeat | Temperature Resistant Epoxy Putty
Old 04-13-2015, 12:14 AM #3
None of the JB Weld Putty's worked. Would not stick.
This did the trick:
Plastic Bonder Syringe | J-B Weld
Heater Core shawnstcyr 3rd gen T4Rs 12 08-19-2015 03:54 PM
Repairing cracked plastic Valkyrie 3rd gen T4Rs 3 05-08-2014 10:06 PM
Heater Core? or something else? stirewaltjm 3rd gen T4Rs 2 10-14-2011 02:51 PM
possible heater core smarks76 3rd gen T4Rs 0 10-29-2010 08:57 PM
Need Advice on Repairing Broken Skid Plate Bolts rjaudi 3rd gen T4Rs 2 06-05-2010 03:31 AM
