I thought this was quite hilarious, why would you recall a valve cover gasket from 1997?
I don't imagine any other manufacturer doing that.
Even if it was 'good' back then, it'd probably be bad by now -- Even on the 4runner!
GM recalling 1.4M cars; oil leaks can cause engine fires
Over time, a valve cover gasket can degrade, allowing oil to seep out. Under hard braking, oil drops can fall onto the exhaust manifold and catch fire. Flames can spread to a plastic spark plug wire channel and the rest of the engine.
GM says it has reports of 19 minor injuries in fires caused by the cars. In 2008, a GM spokeswoman said the cars were responsible for 267 fires, including at least 17 that burned structures.
