Old 04-06-2017, 11:24 AM #1
renau001 renau001 is offline
renau001 will become famous soon enough renau001 will become famous soon enough
2008 highlander oil leak, should I try to fix?
Have a 2008 highlander sport, 2wd with 106,640 miles. Just completed an oil change and noticed some oil residue on the passenger side axle CV boot and steering rod boot as well as up on the engine on the rear passenger side above the oil pan. Seems to be minor, no observed drip and nothing on the garage floor, but I cannot identify the leak source. Any thoughts on where it might be coming from, and whether or not I should try to get it fixed or just live with it? See attached pics, sorry they're upside down.
Thanks in advance!
2008 highlander oil leak, should I try to fix?-img_0592-jpg  2008 highlander oil leak, should I try to fix?-img_0593-jpg  2008 highlander oil leak, should I try to fix?-img_0594-jpg  2008 highlander oil leak, should I try to fix?-img_0596-jpg
2016 Trail Edition Premium w/ KDSS. LT265/70R17 BFG KO2s, Ceramic Pro, TSO pro grille, sliding cargo tray, WeatherTech floor liners, '10-'13 trail running boards.
Nobody cares about your vehicle as much you do. DIY Maintenance Quick Reference
renau001 is offline   Reply With QuoteReply With Quote
Old 04-13-2017, 11:09 PM #2
messeduprex's Avatar
messeduprex messeduprex is offline
messeduprex is on a distinguished road
easiest way to locate the leak is clean the area with liberal amounts of brake clean. then drive it for a few days and re-check. it all depends where the leak is coming from to know if its worth it. timing chain cover-the motor most likely has to come out, valve covers-tedious but are cheap.
messeduprex is offline   Reply With QuoteReply With Quote
Old 04-14-2017, 12:59 AM #3
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Probably the Timing Cover, we see them now and then.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Steering Leak? 2008 SE Swanny69 4th Gen T4Rs 1 02-18-2015 08:42 PM
2008 Highlander Custom Antenna Mounts gstai All Other Vehicles 0 06-16-2014 12:20 AM
2008 Highlander...fuel economy & tow capacity? sbbamafan All Other Vehicles 16 01-30-2008 09:10 AM
2008 Highlander JosephD05 Comparisons & Reviews 6 01-24-2008 09:31 PM
2008 Highlander qs933 All Other Vehicles 47 08-24-2007 12:44 AM
