04-27-2019, 12:02 PM
Compressors?
I keep forgetting to air down offroad and subsequently bounce myself silly. It's time I found myself a decent compressor. What compressor have people been using to pump up those tires?
I'm not a hard core crawler so the compressor probably won't receive real hard use.
04-27-2019, 12:54 PM
04-27-2019, 02:47 PM
Originally Posted by Wedgy
Nice units but way overkill for me.
04-28-2019, 12:25 AM
Originally Posted by Hopeless Diamond
Yes, something like this one for me, with only an occasional need for one. Thanks.
04-28-2019, 01:05 AM
I really like this:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
However, since I am running P-metric tires on the 4R, I am not airing down.
04-28-2019, 01:39 AM
Real Name: Jerod
Real Name: Jerod
Originally Posted by MAST4R
I have this one as well. Pair it with some simple, cheap tire deflaters and it's pretty simple.
04-28-2019, 12:26 PM
Real Name: Derek
Real Name: Derek
Another vote for the mv-50.
Check out Pepboys...they had them for $50.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
04-28-2019, 12:58 PM
If you're airing down to 15 from 35 x 4 tires, you'll Need at the Very least this:
https://www.amazon.com/VIAIR-30033-3...e%2C214&sr=1-2
Not even at this price point do you get 100% duty cycle (33% on 300 P) so you'll need to keep an eye so to speak on the temps. Mind has not overheated when airing up 4 tires (265/75/16) from 15-35 yet still takes some patience cooling off a bit between the 3-4th tire. Takes 4 mins per tire from 15-35.
This one is 100% duty cycle: https://www.amazon.com/dp/B000X9EGFS/ref=emc_b_5_t
Luck and enjoy the runner.
2001 Limited 4WD - 349+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Reason: details
04-28-2019, 03:23 PM
Moderator
Real Name: The Chosen One
Moderator
Moving this from 3rd gen to OT where more people can benefit from this.
'89 4Runner SR5 - stock
04-28-2019, 03:51 PM
I have the smittybuilt one, the one with more capacity. I think it was $165. Works amazing though. Inflates my tires super quick.
Last summer I blew up 14 inter-tubes for a river float without a break in between them and it was fine the entire time. Highly recommend
04-28-2019, 06:25 PM
There is also the Hong Kong Freight model that looks a lot like the Viair 400P and is probably made in the same factory at $62 and you can get the 25% off coupon that will bring it down below $50
12Volt 150 PSI Compact Air Compressor
400P Portable Compressor | VIAIR
04-29-2019, 12:18 AM
Found one of these on my local Craigslist, nearly new is the claim, and for 40.00.
04-29-2019, 12:19 AM
What's the deal with this?
04-29-2019, 12:32 AM
It has worked well for me and it is cheap. It has been years so I do not remember details, but it had better characteristics than the competition in that price range when I bought it. Some are really weak units.
