12-12-2018, 02:17 PM
Real Name: 3 Bears
Real Name: 3 Bears
mig welder
My daughter in law wants to buy my son a mig welder. She asked me if he would be happy with a 110 volt. I don't weld.
But from what I have been told, a 110 has more versatility meaning you can take it more places because it s 110.
220 is limited because you have to have 220 available.
I do know that 220 can weld thicker metal. In that fact I think the 220 would be better .
So what should she get him ?
Opinions please
12-12-2018, 02:21 PM
Real Name: Keith
Real Name: Keith
110v will be fine for most everything he’ll probably do.
12-12-2018, 02:36 PM
Real Name: Jeremy
Real Name: Jeremy
agreed..bought a hobart 140 several years back, for reference they're actually 115 volt. Anyway, I've found it to be more than capable..not sure if he's new to welding or not, but that's a good rig to learn on..just my .02 cents.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
12-12-2018, 02:37 PM
Real Name: Korey
Real Name: Korey
If it's going to stay in the "shop", I would go with 240v . Not only will it have more power, it will have a longer duty cycle.
Some people say 110/220, I prefer 120/240.
2017 Cement TRD Pro
12-12-2018, 02:45 PM
Real Name: Leon
Real Name: Leon
Another option is a dual voltage welder. I like my Millermatic 211, which can do either 120 or 240V. I've never had to use the 240V, but it's nice to know it's there if you need it.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
Real Name: Matt
Real Name: Matt
I have a Lincoln 140 and its been perfect for the home garage
1998 Tacoma extra cab 5 speed Sold!
1998 4runner auto Build in Progress
Follow Me on Instagram
12-12-2018, 02:58 PM
I have a Miller 140 knockoff. The difference came from the cable feeding the ground clamp and the lack of autoset (wouldn't use that anyway). It works great, and has been solid on everything up to 1/4" with .30 wire. I've welded thicker, but you need to chamfer the material and sometimes make two to three passes to get things solid enough to trust. For home use, it hasn't failed me.
12-12-2018, 03:01 PM
That’s what I went with, Hobart 210mvp. The main question is how thick of metal will be welded. 3/16 is right on the edge of being too thick for 110 imo.. Another thing I’ve heard/read is if you get a bigger breaker/wires to a 110 outlet it will perform better than say a regular 10/15 amp breaker to a regular 110 house outlet..
12-12-2018, 03:02 PM
Either the Lincoln or Hobart 140 will be fine for him. As long as he isn’t welding frames, both at about $550 should be fine for all future work.
12-12-2018, 03:27 PM
Real Name: Steve
Real Name: Steve
120v Should be just fine. I have a Lincoln 135 plus and it works great.
12-12-2018, 06:13 PM
Moderator
Real Name: The Chosen One
Moderator
Moving to OT where more people may find this useful.
'89 4Runner SR5 - stock
12-12-2018, 06:58 PM
Real Name: Tony (no surprise)
I've been eye-balling the Hobart 190, also 220v. Have heard only excellent things about Hobart...
2000 Limited, E-locker
Maintenance/Build Thread
12-12-2018, 07:23 PM
Real Name: Robert');DROP TABLE Students;
I bought a Hobart 140 on black friday and used it with flux core to weld my sliders together. I haven't had a chance to paint them and weld them to the frame yet, but I'm hoping it'll be up to the task. I'm really happy with it so far, especially for $405.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
12-12-2018, 08:34 PM
Real Name: Mark
Real Name: Mark
Opinions please
A 240v will do a bead on thick metal in a single pass. 120v change the process and do it with three passes or one pass and a cap pass, depends on how much you bevel the metal your welding. 240v duty cycle is nice, 120v duty cycle works
well in most cases, puddle will get smaller and smaller the closer it gets to time for a break.
Get one that is capable of using gas.
12-12-2018, 09:21 PM
It's not a big if it doesn't use gas..LOL
