Thread Tools Rating: Thread Rating: 3 votes, 3.33 average. Display Modes
Old 01-21-2020, 02:04 PM #31
darkie3495's Avatar
darkie3495 darkie3495 is offline
Moderator
darkie3495 will become famous soon enough
Moderator
darkie3495's Avatar
Originally Posted by mesooohoppy View Post
awesome! you seem to really have committed!
Yeah....I spent a full uspsa season loading on a single stage. vowed never again. ha
how do you like that annealze (sp?) annealer? i need to buy one and i dont want to shell out 500 bones for a giraud if i dont need too.
It works well. You spend a little more time on the set up but worth the investment. just make sure you pick up a bottle of tempilaq - takes the guess work out of the process.
Kevin's 2008 4x4 Build Thread
Perkins Performance | Shrockworks | Demello | BudBuilt | ICON | Warn | Overland Warehouse | Goodyear | Lightforce | Spidertrax | Powertank | Complete LED Conversion
darkie3495 is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 01:49 PM #32
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
hope all is well with everyone! despite being busy with other projects and my full time job, i managed to do something ive wanted to do for a while. i drew, printed, and shot some 3d printed 9mm projectiles out of my ar9 that i just got back up and running again.
they still need tweaking, but they did seal up against the rifling and stabilize. once i get the size and profile finalized i will be putting metal weights in the center to try and get them to weigh more. right now they are just shy of 14 grains. if you want to see pics check out @booozyhoperators on IG (3 o's).
i also finished my ar10 build and now i need to buy a mighty armory 308 sizing die as i absolutely hate the hornady sizing die i have; the expander ball is way too hard on my machine. its been a very warm winter where i am at with very little snow, so i have been tacking advantage of that.
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 02:53 PM #33
darkie3495's Avatar
Moderator
Moderator
darkie3495's Avatar
Interesting concept. curious to see how they hold up with a little more powder and what bullet design you come up with to stabilize.
I have the might armory decapping die and they are awesome!!
Old 02-18-2020, 04:43 PM #34
i basically re drew a gallant 125gr round nose coated projectile. its close but its not a perfect match of the gallant bullet. i recovered 2 projectiles and you can tell they sealed against the rifling, they also stabilized okay. i shot them through a chrono, but i was having issues with the thing and didnt get good readings.
right now the biggest issue is trying to get some mass inside these projectiles. i might give lead a shot or see if i can find some 25 acp projectiles to up the weight. its sort of counter intuitive to stuff a bullet into a 3d printed bullet, but i guess that is whats needed to get it done. someone suggested stuffing the prints with tungsten, but i was told i will likely run into some sort of legal issue (armor piercing stuff?). its also incredibly expensive compared to lead. i think im going to give lead a shot first; although i need to finalize my ogive and bullet OAL profile first before i move on.
IG: mesooohoppy
Old 02-23-2020, 05:55 PM #35
Hotsky Hotsky is offline
Hotsky is on a distinguished road
I roll my own. Use Lee classic turret press.
Hotsky is offline   Reply With QuoteReply With Quote
Old 02-29-2020, 05:02 PM #36
xyzzy xyzzy is offline
xyzzy will become famous soon enough
Been reloading off and on for 30 years. RCBS gear.
I've worked up some good (in my guns) big game hunting loads for .270 Wthby, .300 Wthby, .340 Wthby (my all-time favorite), & .375 H&H using Barnes bullets. The price of factory Weatherby ammo has approached $5 per round last time I looked, so 3-5 boxes of 20 for validating sight-in, plinking, and hunting for a season could get expensive. I used to live in Fairbanks, AK so I hunted caribou and moose annually, and bear occasionally, hence the heavy metal preferences.
For prairie dog shooting, I found some really accurate (for my guns) factory ammo for my .17HMR, .223, and .22-250, and using a single stage setup like I own to prepare hundreds of rounds of each of these would be too tedious.
xyzzy is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 03:56 PM #37
Hope all has been well with everyone during these odd times. i am deemed 'essential' so im still at work, otherwise id be at home cranking out a bunch of rounds.
i did how ever manage to load up some 73gr hornady eld match and some 75gr BTHP projectiles in 223/556. now the snow is here and i cant get to my 100+yd shooting spot. my ar10 had to be sent to a smith due to ejection issues, now thats on its way back i guess ill load a little for that as well so when the snow clears ill have plenty of accuracy testing to do.
i put off the 9mm 3d printed bullet thing for a while because i couldnt figure out how to make them heavier without a metal insert. which IMO, is counter productive to 3d printing bullets in the first place. i re drew a new profile last night and will shoot some again as soon as the snow melts in the shorter shooting stalls. you can buy plastic infused tugnsten, but its like 200-300 bucks for a roll and i am still not sure if it would be heavy enough to create enough mass to cycle the bolt.
Hope ya'll are staying safe and getting caught up on the loading!
IG: mesooohoppy
Old 04-07-2020, 04:36 PM #38
ran ran is offline
ran is on a distinguished road
ran ran is offline
I used to, back in the day. .38/357, 5.56AR, and buy junk 12 gauge and reload by hand buckshot. fun times, 1980's
_______________________
2007 SE V6 Titanium 265/70-17 Cooper T-3/4-S
ran is offline   Reply With QuoteReply With Quote
300blk , load , machine , moa , primer
