Old 01-20-2020, 05:52 AM #1
SoFary's Avatar
SoFary SoFary is offline
SoFary is on a distinguished road
SoFary's Avatar
Composite decking or simple deck from the wood?
Trying to figure out what is better to use while making my outside deck, some people are saying that they made a deck from the wood, and it is nice, but it is hard to clean and they chose composite decking and vice versa. My wife wants composite decking, but I want to be sure what is better.
SoFary is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 02:03 PM #2
Bumbo's Avatar
Bumbo Bumbo is online now
Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold
Bumbo's Avatar
As much as I like real wood I would probably buy composite deck if I had to build one for myself with the intention of keeping it long term.
As beautiful as real wood is, itís much higher maintenance and doesnít seem to hold up as well over time if you donít spend the money to maintain it. With wood you have to consider termites, sealant/weatherproofing, warpingÖ less you maintain, the faster is weathers and degrades over time.
Lot less to worry about with a composite deck, but it usually cost more upfront too.
Bumbo is online now   Reply With QuoteReply With Quote
Old 01-20-2020, 02:16 PM #3
spartacus's Avatar
spartacus has a spectacular aura about spartacus has a spectacular aura about spartacus has a spectacular aura about
spartacus's Avatar
If you don't want to refinish and seal every two years at the minimum' go with trex or other composite.
Old 01-20-2020, 07:53 PM #4
KWSRStorm's Avatar
KWSRStorm KWSRStorm is offline
KWSRStorm will become famous soon enough KWSRStorm will become famous soon enough
KWSRStorm's Avatar
+1 for trex. Dont need to maintain it aside from washing it. The biggest downside is it can get pretty hot in direct sunlight. Just wear sandals vs going barefoot on hot sunny days.
Also the t channel mounting system makes for a really clean install
Sent from my SM-G973U using Tapatalk
Build Thread
KWSRStorm is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 10:14 PM #5
Gunslinger-13's Avatar
Gunslinger-13 Gunslinger-13 is offline
Gunslinger-13 will become famous soon enough Gunslinger-13 will become famous soon enough
Arrow
I designed, sold and built decks in one capacity or another in Colorado (tough climate) for about a decade.
Do this:
1) Wrap the top of the joists in Grace Vycor tape. This tape is non water permeable and will keep moisture from getting into the top of the joists and rotting them over time. It self seals around screws.
2) Use a 1" steel stand off spacer at all the post bases in between the posts and caissons. This will inhibit moisture sitting on tp of casinos from getting into the bottom of the posts and rotting them from bottom up.
3) Use SDS screws in lieu of nails at all of the hangers and every attachment point possible; some areas you must use nails, but use SDS screws wherever you can.
4) Opt for the slightly more expensive kiln dried and pressure treated lumber- lumber yards have rediculously moist wood. Kiln drying slowly releases the excess moisture and gets the moisture content acceptable.
5) IF using wood- Use a high grade finish stain on your cedar top planks. Do not stain or paint the underside. Benjamin Moore Arborcoat is a good medium/high quality stain. Sikkens stains are the best, but a premium price.
Be prepared to clean and stain with HIgH quality stain every 2 years for maximum life cycle.
6). Use 6" Posts in lieu of 4".
7) Whatever substrate you're installing the ledger board to (Unless it's a free float deck and you have a brick home- which shouldn't be ledgered 99% of the time unless you have an unfinished basement and access to framing/structure to ledger beneath brick) make sure that it is properly flashed up under the siding, out over/on top of the joists and counter flashed on top and bottom to prevent water intrusion.
8) Use a minimum of 5 stringers on stairs, unless it is 3 stairs or less; then 3-4 stringers is sufficient.
9) Simpson brackets and strong ties/hurricane clips.
Iíd recommend using timber tech composite over trex , their top tier pro collection.
10) check your souls. Use caissons to local code or go with helical piers if you have expansive souls or fresh backfill/ compacted soils in a development less than 7 years old.
And Iíd recommend using composite over wood for sure. Just donít use cheap composite.
Use a pre fabricated fortress iron railing. The composite railings leave a lot to be desired.
Feel free to PM me if you have any questions.
Have fun!
Gunslinger-13 is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 10:32 PM #6
Hepar's Avatar
Hepar Hepar is offline
Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough
Hepar's Avatar
Was curious if the bots have still been around. Got my answer.
2001 4Runner 4WD Sport Package, Millennium silver, 110,000 miles, 2nd gen TRD Supercharger, Toytec BOSS coilovers, 890 OME rear springs, Bilstein 5125 rear shocks, custom Baldlands front bumper, PIAA 520 driving lights and fogs, 4x Innovation Sliders (welded on!), 18" Magnaflow muffler, JDM corners, 65" Thule bars, 20% tint, 16x8 FJ80 wheels on 265/75-16 Duratracs, Husky mats w/ cargo, rear diff breather mod, 3M clear bra, remote start, Pioneer AVIC-8200NEX
Hepar is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 11:14 PM #7
Damn, they finally got me...
Old 01-22-2020, 12:46 PM #8
johndoll's Avatar
johndoll johndoll is offline
johndoll is on a distinguished road
johndoll's Avatar
There are so many advantages to choose composite decking. Composite decking is usually made of wood fibres and plastic materials. Its high quality, no-finishing-work necessity and non-slipperiness make it a great alternative to the classical timber boards. Composite decking is eco-friendly as it is made of recycled wood and plastic. And on top of that it cleans so easy. I used qualitative dino composite decking when I made reparations in our house. I am very satisfied by the quality and the price.
johndoll is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 05:51 AM #9
SoFary's Avatar
SoFary's Avatar
Not the answer I was looking for, but thanks anyway.
Old 02-13-2020, 05:54 AM #10
SoFary's Avatar
SoFary's Avatar
I choose composite decking, but my wife said no sex for 2 weeks. She wanted wood decking. If you know what I mean.
Old 02-18-2020, 01:27 PM #11
repo repo is offline
repo will become famous soon enough repo will become famous soon enough
Do this:
I’d recommend using timber tech composite over trex , their top tier pro collection.
And I’d recommend using composite over wood for sure. Just don’t use cheap composite.
Have fun!
This is solid advice. I did all this stuff after going down an OCD rabbit hole of deck construction and IRC code research when I built mine. I have a patio now which I much prefer.
You should give the IRC Deck Guide a skim read at the least. https://awc.org/pdf/codes-standards/...Guide-1804.pdf
The deck boards should be the least thought about thing. Make sure you have proper footings, post bases, 6x6 posts, proper notched post connections, proper fasteners (Simpson SDS mentioned above). Try to avoid that bright green cheap lumber and get the micronized treated stuff that's less corrosive. I treated end cuts with Black Flag wood preserver for good measure, and used Vycor on the top of double joists as described above. I'll tell you one thing, flash the hell out of the ledger board. I did Grace Vycor > ledger board (attached with Ledgerloks) > more Vycor over the ledger > solid Z flashing > Vycor lapped over that > housewrap lapped over the Vycor.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 03:27 PM #12
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a jewel in the rough T4R2014 is a jewel in the rough T4R2014 is a jewel in the rough T4R2014 is a jewel in the rough
T4R2014's Avatar
This bot is actually really funny
Old 02-26-2020, 10:21 PM #13
JROTN JROTN is offline
JROTN is on a distinguished road
decking
We used Azek pvc decking and trim when we built our house, love it no staining and holds up well, put ketchup mustard and crisco on a sample piece for two weeks and it washed right off with no signs of stains. I know of two other decks in our area made of it and they also love it. we wash it with simple green and a pressure washer once a year and done. Have more time to play with toys and drink some beer while sitting on the porch
PS the trim boards we painted with Sherwin williams paint and it is holding up just fine 5 yrs. later.
JROTN is offline   Reply With QuoteReply With Quote
composite , deck , decking , wife , wood
length of wood pb&j 3rd gen T4Rs 7 12-04-2016 11:47 PM
WTT: Double deck from 06 SE for single deck. KPZVR4 Want to Buy/Trade 0 12-17-2015 02:51 AM
Got Wood?? Mick1 5th gen T4Rs 0 09-23-2014 10:28 PM
Ft. Leonard Wood steve73 Ozarks 0 08-12-2012 08:43 PM
Not out of the wood yet mid9pitstop Maintenance/Detailing 0 06-06-2009 04:51 PM
