Closed Thread
Old 03-30-2020, 09:06 PM #1
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Plumbing - Whole-house repipe
Hey, all. I live in a 1960 home on a well with a mix of piping, mostly galvanized. I’m planning to have a complete repipe performed, including all supply and drain lines. Adding a softener, too. Going with Pex supply and PVC drain pipes.
This is an investment in my future well-being, as my plumbing frequently presents problems needing repaired and I’m weary of it. So I’m wondering, has anyone out there had this done to your home? If so, did it go well? Any tips? I plan to have this done by a very reputable company, no interest in cutting corners.
Thanks.
thennen is offline
Old 04-03-2020, 10:08 PM #2
thennen's Avatar
thennen's Avatar
Apparently I’m alone in this adventure.
thennen is offline
Old 04-04-2020, 01:38 AM #3
ran ran is offline
ran is on a distinguished road
ran ran is offline
Maybe no one has pulled all that sheetrock off to get the their pipes. good luck with it.
___________________
2007 SE V6 Titanium
ran is offline
Old 04-04-2020, 04:03 AM #4
VB.TRD.Pro's Avatar
VB.TRD.Pro VB.TRD.Pro is offline
VB.TRD.Pro will become famous soon enough VB.TRD.Pro will become famous soon enough
VB.TRD.Pro's Avatar
Can't say we've ever done what you're doing with replacing legacy piping in the entire home but we have owned multiple properties with different types of piping. By far Pex-A (uponor) has been the least problematic. Copper is okay but can be noisier plus you can't run RO water through it because it'll leach and eventually develop pinhole leaks. Pex-A is much more flexible and can be contorted to do many things copper can't come close to doing so it'll save some $ in labor.
If you plan on working on the plumbing after the fact, in my opinion Pex-A is more flexible and fool proof compared to the B variety but requires a special tool. The one made by Milwaukee is the best one out when I last checked a year ago because it also rotates which evenly dilates the pipe to fit around the fittings. It will eventually shrink back to its original diameter and that force is what provides the clamping force so it's hard to screw that up. PEX B is a crimp system, more commonly available at big box stores but more potential for errors and leaks if not done correctly. All of the pro plumbers I know always use Uponor products. There are many videos on YouTube that may help you get familiarized with the two to form your own conclusions.
For softeners we've always run 3M softeners based on the Clack WS heads. 3M costs a little more compared to the build your own kits which some will tell you are there same which is mostly true. Parts are plentiful for Clack based systems but I'm a 3M fanboy and all of their products are certified with scientific data and stats easily accessible for review. No fluff or snake oil marketing. What sets them apart is everytime I've had questions about their products, I call them direct and will get one of their product engineers on the line who know the product inside and out; not some level 1 call center person who may be referencing a script. When you need detailed technical info, you can get it with one call in a matter of 5 minutes.
Don't know the size of your home or family but we tend to pay a little more to buy the larger commercial grade units to cut down on the regen cycles. We've purchased two 2 cubic feet 3m-wts200 units over the past 4 years for two different properties and they're rock solid. We've been on city water 15 gpg hardness and now about 7gpg. We get about 3-3.5 weeks between regen cycles with about 100 gallons of water usage per day. I can load the salt tank with 120 lbs and be good for 12-16 months. If anything, get your water tested for hardness level and see if there are any other treatments or unique media needed since you are on well water.
Good luck with the project. Even with PEX it's not an easy job. Sheetrock repair is easy if that's what you've got with a house built in the 1960s. If plaster, might get a little messy. Would love to hear the results so keep us posted.
2021 Lexus GX460 Premium Plus + Sport Design Pkg
2019 VooDoo Blue 4Runner TRD Pro
2016 Nissan GT-R Black Edition
Old 04-06-2020, 02:06 PM #5
thennen's Avatar
thennen's Avatar
___________________
2007 SE V6 Titanium
That'll only need to come off in a couple of spots. My two bathrooms share plumbing, which helps reduce the needed drywall work.
thennen is offline
Old 04-06-2020, 02:27 PM #6
thennen's Avatar
thennen's Avatar
Thanks for the valuable input.
I'm having this job done, and it will be Pex. In fact, just had the failed pressure tank replaced Friday and relocated from the crawlspace to the first floor (the first step of the project). Thrilled about that - I replaced the pressure tank maybe 15 years ago, and doing any plumbing work in the crawl space is a PITA. What I didn't notice last time: previous owner had run the incoming line from the well to the softener (maybe 30 feet), then 30 feet back to the pressure tank, then to the house. Before I bought the house, that softener had been removed, so there were just pipes that recently developed a leak and rusted out my furnace. Had the furnace replaced a month ago.
I'll ask the plumbing company about 3M softeners. I'll pay more for better quality every time if I can afford it. Plus, the ability to contact a sentient human being for help carries value by itself.
My home is 1600 square feet, bath and a half, family of 5. Never measured water usage.
thennen is offline
Old 04-06-2020, 06:42 PM #7
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Can't say mine was remodeled before we moved in. The only thing left cast iron is underneath. Since my house is pier and beam foundation its pretty easy to get under there.
Pipe has seen better days but no where near leaking yet.
But the plan is to go PVC in the near future. Better to fix it now before it does become and emergency.
2018 TRD OFF ROAD
My Build
Old 04-06-2020, 07:50 PM #8
thennen's Avatar
thennen's Avatar
Funny - I’m not getting notifications of replies to this thread. I need to keep checking. Wonder why?
thennen is offline
Old 04-20-2020, 02:00 PM #9
AZ07Runner's Avatar
AZ07Runner AZ07Runner is offline
AZ07Runner is on a distinguished road
AZ07Runner's Avatar
I had my whole house replumbed a few years ago with Pex. Also did the under-slab sewer as well since it was in bad shape.
The company I used did not recommend using the shark-bite connectors, but the ones that require the crimping six times. Uponor is the company, I believe. More reliable and a little more expensive. but I wanted this done once and done right. Three years, no leaks.
07 Limited V8 Titanium Metallic
Bilstein 5100s x4, Fronts set on 0 with OME 885s, Sway-A-Way 1.5 rear coils, JBA UCAs, '12 Trail wheels, Cooper AT3s 265/70/17, Mobil1 0W40, Amsoil Severe Gear 75W90 and SS ATF.
(Previous truck: 1993 Toyota DLX, V6, 4x4, Xcab, 5 speed, Pewter Pearl - owned from day 1)
http://www.toyota-4runner.org/4th-ge...ml#post2069269
Old 04-20-2020, 02:14 PM #10
thennen's Avatar
thennen's Avatar
Thanks for this. I have to say, I didn't know about the two different connectors, or rather, that one was preferred over the other. So far I've only had the pressure tank done - it's now in the house rather than the crawl space. I think they're using the crimp fittings, but I'll definitely bring this up when they move forward with the rest of the job. I'm not interested in saving a few bucks on such a major job.
Thanks again.
thennen is offline
Old 04-21-2020, 06:22 PM #11
AZ07Runner's Avatar
AZ07Runner's Avatar
I was just thinking about the tool used for the fitting and installation and it is an expansion tool rather than crimping. The tool is required to be used six times in the end of the pipe before the fitting is attached. Due to the expansion/contraction properties of the pex, it shrinks back down onto the fitting, making a water tight seal. I watched my plumber do this multiple times. I'd look at a bunch of YouTube videos to see what I mean.
Old 04-26-2020, 07:31 PM #12
DanielEstep DanielEstep is offline
DanielEstep is on a distinguished road
Hey Guys! I am very glad to read this interesting discussion about this topic. Thanks all
Old 11-17-2020, 02:51 PM #13
thennen's Avatar
thennen's Avatar
Looks like a bot visited...
Anyway, the job is all done. Every supply and drain line in the house has been replaced with PEX and PVC, respectively, including cold-weather faucets outside and a softener. Completed last week. Quite expensive (for me) but the peace of mind is worth it. Took them 4 days (2 guys).
Every job has a surprise, and this was no exception. When they pulled the toilets, they informed me that water had been getting past the wax ring (full bath) and foam ring (half bath - apparently these are junk). So I had the top layer of wood in both bathrooms rotting in that vicinity. Had to cut out the bad wood and replace, then put vinyl plank down (pretty solid stuff). Had to wait until they left at 5pm on two consecutive days before I could start, and had to have it finished before they arrived the next day. This meant I was there until 1:30am on the first day, 9:30pm day 2.
I was surprised at how clean some of the galvanized was when they cut it out, considering the hardness of the well I'm on (20 gpg). The vertical pipes had some artery-clogging going on though, and the pressure/flow at the faucets is significantly improved. Drain pipes were cast and pretty solid, but they get flaky on the inside after so many years, and snag stuff (like the baby wipes my youngest has occasionally tossed down, we believe). So now that's all smooth PVC.
Family stayed in a hotel for the duration. Except for the floor repairs, the job went pretty much as expected and as described. I have some drywall repair to do, but really not much - two 3x4-foot sections. Considering the numerous repairs I've had to do and have paid for over the years, and the above-mentioned peace of mind, knowing that there aren't any water surprises hiding out is very calming. If you're stressing over your old plumbing like I was, I heartily recommend getting this done.
thennen is offline
Old 06-12-2024, 10:29 PM #14
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
Closing this SPAM magnet of a thread.
Message a Mod if you need it reopened.
'89 4Runner SR5 - stock
fourwd1 is offline
Closed Thread
drain , home , i’m , plumbing , supply
Need to replace my Xreas. What happens if I remove just the plumbing and >>> Jeff T 4th Gen T4Rs 8 11-05-2014 08:41 PM
3,0 charcoal canister plumbing 2oldtoys Classic T4Rs 6 01-08-2011 07:21 PM
Heater plumbing '95 T4R 3.0 AZ_John Classic T4Rs 0 07-28-2010 02:33 PM
muffler? or muff AND repipe? 4rnr4me Engines / Suspension / Wheels / Tires / Audio / Accessories 4 12-13-2007 04:32 PM
Seems like Stony Brook College has plumbing problems mole177 Off Topic 3 02-23-2006 04:35 PM
