Old 11-21-2022, 01:41 PM #1
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
Need advice on propane regulator
So I have a propane firepit that I use for cold weather camping. Uses a 20lb propane tank. I’ve noticed that when the temp is very cold (mid teens-mid 20s) the fire pit will begin to die down and the flames will become almost non existent. Pouring warm water on the regulator will instantly fix the issue till it gets cold again. Will replacing the stock regulator on the firepit with an adjustable one solve my issue?
I’ve used propane to heat plane engines in much colder temps, sometimes into the negatives, and it’s worked great. Don’t understand why this firepit is struggling other than it being the regulator.
Attached is a picture of the regulator on my firepit
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 11-21-2022, 08:12 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Try some of these tips.
Does cold weather affect propane regulators? - TimesMojo
2004 Limited V8
Old 11-25-2022, 04:25 PM #3
Justthemechanic Justthemechanic is offline
Justthemechanic is on a distinguished road
I have a Little Red Campfire and it has an adjustable regulator. It seems I am always adjusting it to keep the fire constant. An adjustable regulator should take care of your issue.
93 SR5, 3.0, 5 speed, OME 2” lift, BudBuilt skid plates and crossmember, Rocky Road Outfitters sliders, Spartan rear locker.
Justthemechanic is offline   Reply With QuoteReply With Quote
Old 11-25-2022, 08:20 PM #4
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
Propane is extremely cold, something like -50º. Even if it’s over 100º out, if propane escapes you can get frostbite if your hand or exposed skin comes in contact. During my working years, I spent years running a propane powered forklift (Toyota - yeah!) and protocol was to wear heavy, elbow length rubber gloves while fueling. Miserable in summer where I worked in a large borax processing plant near Death Valley.
That said, I use my outdoor barbecue even during subzero temperatures. Often, even during warm weather, I have observed my barbecue reluctant to light or have a low flame. For some reason that I haven’t researched, but the manual of my barbecue says occasionally happens, opening the valve quickly causes this phenomena. Closing the valve and opening it slowly will get things back to normal again.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 02-27-2023, 06:06 AM #5
kemobetter's Avatar
kemobetter kemobetter is offline
kemobetter is on a distinguished road
kemobetter's Avatar
Yes, frosty weather is my main problem when using propane regulators. I solve this problem by covering the regulator with a warm cloth. Use your old jacket. Btw, it would be nice to clean this accumulated soot more often. And the same precautions are also suitable for taking care of propane tank gauges. Propane level sensors may be inaccurate if there is a lot of garbage and dust. Also, some models are sensitive to low temperatures. It would be better if you look at this list of quality regulators https://daddycookingtips.com/best-propane-tank-gauges. It's better to choose high-quality ones to quickly notice a lack of propane or a leak.
kemobetter is offline   Reply With QuoteReply With Quote
cold , firepit , issue , propane , regulator
Where to store propane BE4Runner 3rd gen T4Rs 16 02-10-2016 09:25 AM
85 1st gen runs on propane 94Runner4 Classic T4Rs 3 05-02-2012 08:52 AM
Propane conversion ?s Iroke17 Classic T4Rs 14 04-21-2012 03:01 PM
adding propane anyone??? shootmymime 3rd gen T4Rs 3 05-14-2008 11:16 AM
Propane conversion Tree 3rd gen T4Rs 0 02-13-2006 02:22 PM
