Thread Tools Rating: Thread Rating: 3 votes, 3.33 average. Display Modes
Old 02-01-2024, 05:46 PM #46
3ToyGuy 3ToyGuy is offline
Real Name: Patrick
3ToyGuy is on a distinguished road
Real Name: Patrick
I would say the alternator is a good bet for being bad. When you put a fully charged battery in and drove it around, the car was then running off the battery, not the alternator like it should. The dead battery afterwards is the key.
Alternatively, no pun intended, is the alternator plug in properly? Is the heavy wire over to the battery connected properly? Is it a short, like it should be? In other words, is the heavy wire in good shape? The connectors at both ends in good shape? Is the alternator's ground in good shape? The fuses involved properly shorted, no open fuses?
Are the battery terminals in good shape? No corrosion, connected tightly but not over tightened? Is the battery's ground connection in good shape? Nice and clean at both ends, no corrosion?
Hi humidity under the hood, like when the car is covered in snow, can corrode all sorts of connections. All the involved connections should be checked, ensure they're all clean.
Finally, is the alternator drive belt in good shape? Nice and tight, no cracks, etc?
All just the few thoughts I had...
Pat☺
3ToyGuy is offline   Reply With QuoteReply With Quote
Old 02-03-2024, 05:21 PM #47
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Alternator replacement in the Accord is finally done. Out came the OEM unit and in went a remanufactured Denso unit. The car runs and sounds significantly smoother than before, so thatís a huge plus. No more battery light on thankfully!
Mileage: 134,497
Old 02-15-2024, 12:12 PM #48
JoeT4R's Avatar
JoeT4R's Avatar
The Honda has been running flawlessly. Gassed up at Costco this morning and calculated my mileage, 21 miles per gallon for a tank that lasted me 12 days.
Old 03-30-2024, 08:12 PM #49
JoeT4R's Avatar
JoeT4R's Avatar
Todayís endeavors included an engine oil change, transmission fluid flush and fill and a brake fluid bleed.
My bestie works at the Honda dealer so after closing time today I was able to go up there and have him throw it on the lift. Oil change was a quick and easy process. The transmission fluid though was in rough shape. Iím pretty sure it had never been serviced before, the fluid was dark dark dark when it first drained and the metal flakes on the drain plug magnet were not pretty.
We did the drain and fill of the transmission three separate times and in between we would get the car up to speed and shift through the gears to cycle the fluid throughout the torque converter. By the third drain the fluid was looking cherry red. It also shifts noticeably smoother but nothing significant though.
When it came to bleeding the brakes the process was easy enough and straightforward. Gravity bleeding with a vacuum pump. The fluid in the master cylinder was black and when it was bleeding through the valve you could see all the dirty particles going through clear hose. All four corners were bled without issue. No noticeable change in braking performance though. Which I guess is good?
All in all the Honda is doing alright. There are certain things that need to get done in the not so distant future like rear brake pads and rotors, power steering pump, engine oil pump and very possibly a steering rack if it begins to seep bad enough. Otherwise the car is in great driving condition and ďpasses the multipoint vehicle inspectionĒ that techs perform at the dealer. So Iím happy with that.
Old 04-05-2024, 04:58 AM #50
JoeT4R's Avatar
JoeT4R's Avatar
Some Skyline Drive action 2007 Honda Accord 3.0L V6
4runner , head , honda , thing , things
Mats Honda Accord, CRV and Crosstour ochoa1801 For Sale: Non-T4R Items 0 07-28-2016 01:34 PM
Honda accord seats papawhellie Classic T4Rs 3 08-01-2013 09:28 PM
Crap Brakes (Honda Accord) Bigrupp General Discussions 3 11-10-2010 10:28 PM
'98-'02 Honda Accord 2-dr accessories MikesToy Classifieds - buy & sell (no commercial ads please) 1 10-20-2009 08:01 PM
2008 Honda Accord peter78 Off Topic 4 08-26-2007 11:19 AM
