Thread Tools Rating: Thread Rating: 3 votes, 3.33 average. Display Modes
Old 02-01-2024, 05:46 PM #46
3ToyGuy 3ToyGuy is offline
Real Name: Patrick
3ToyGuy is on a distinguished road
Real Name: Patrick
I would say the alternator is a good bet for being bad. When you put a fully charged battery in and drove it around, the car was then running off the battery, not the alternator like it should. The dead battery afterwards is the key.
Alternatively, no pun intended, is the alternator plug in properly? Is the heavy wire over to the battery connected properly? Is it a short, like it should be? In other words, is the heavy wire in good shape? The connectors at both ends in good shape? Is the alternator's ground in good shape? The fuses involved properly shorted, no open fuses?
Are the battery terminals in good shape? No corrosion, connected tightly but not over tightened? Is the battery's ground connection in good shape? Nice and clean at both ends, no corrosion?
Hi humidity under the hood, like when the car is covered in snow, can corrode all sorts of connections. All the involved connections should be checked, ensure they're all clean.
Finally, is the alternator drive belt in good shape? Nice and tight, no cracks, etc?
All just the few thoughts I had...
Pat☺
3ToyGuy is offline   Reply With QuoteReply With Quote
Old 02-03-2024, 05:21 PM #47
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Alternator replacement in the Accord is finally done. Out came the OEM unit and in went a remanufactured Denso unit. The car runs and sounds significantly smoother than before, so that’s a huge plus. No more battery light on thankfully!
Mileage: 134,497
Old 02-15-2024, 12:12 PM #48
JoeT4R's Avatar
JoeT4R's Avatar
The Honda has been running flawlessly. Gassed up at Costco this morning and calculated my mileage, 21 miles per gallon for a tank that lasted me 12 days.
Old 03-30-2024, 08:12 PM #49
JoeT4R's Avatar
JoeT4R's Avatar
Today’s endeavors included an engine oil change, transmission fluid flush and fill and a brake fluid bleed.
My bestie works at the Honda dealer so after closing time today I was able to go up there and have him throw it on the lift. Oil change was a quick and easy process. The transmission fluid though was in rough shape. I’m pretty sure it had never been serviced before, the fluid was dark dark dark when it first drained and the metal flakes on the drain plug magnet were not pretty.
We did the drain and fill of the transmission three separate times and in between we would get the car up to speed and shift through the gears to cycle the fluid throughout the torque converter. By the third drain the fluid was looking cherry red. It also shifts noticeably smoother but nothing significant though.
When it came to bleeding the brakes the process was easy enough and straightforward. Gravity bleeding with a vacuum pump. The fluid in the master cylinder was black and when it was bleeding through the valve you could see all the dirty particles going through clear hose. All four corners were bled without issue. No noticeable change in braking performance though. Which I guess is good?
All in all the Honda is doing alright. There are certain things that need to get done in the not so distant future like rear brake pads and rotors, power steering pump, engine oil pump and very possibly a steering rack if it begins to seep bad enough. Otherwise the car is in great driving condition and “passes the multipoint vehicle inspection” that techs perform at the dealer. So I’m happy with that.
Old 04-05-2024, 04:58 AM #50
JoeT4R's Avatar
JoeT4R's Avatar
Some Skyline Drive action 2007 Honda Accord 3.0L V6
Old 05-04-2024, 08:59 PM #51
JoeT4R's Avatar
JoeT4R's Avatar
I’ve been trying to think of ways I can continue modifying the Accord without breaking the bank. I’ve had an okay experience in the past with LED headlights but figured I would give it ago one more time…
A few intricacies but nothing major. The connector that plugs into the bulb doesn’t “click” into place, which makes me wonder if it’ll wiggle loose over time. It very well may. But all I’ll need to do is snug it back up to the bulb and keep driving. Other than that no issues to be reported.
Also I didn’t know I had a DRL light on my dash and apparently it’s supposed to be functional! Had no idea! But evidently it works now, so that’s a huge plus. I had to get separate bulbs for the low and high beams but no big deal. $55 out the door on Amazon from a company I’m familiar with and I’m happy with my purchase.
It’s all about the smiles per gallon, baby.
Low beams
High beams
Daytime running lights
DRL’s in action
Old 05-10-2024, 04:53 AM #52
gomiami's Avatar
gomiami gomiami is offline
Real Name: Jay
gomiami has a spectacular aura about gomiami has a spectacular aura about
gomiami's Avatar
Real Name: Jay
My 2000 Civic SI just topped 242k and still works flawlessly. Your Accord with around 140k is just finishing the break in period.
You'll be driving her for a long time as long as you replace that timing belt on schedule.
2000 Honda Civic SI (EM1) Electron Blue Pearl - original owner, 242,800k and completely stock.
2023 Lexus GX460 Premium Nightfall Mica - original owner, 1,580 miles.
gomiami is offline   Reply With QuoteReply With Quote
Old 05-10-2024, 11:06 AM #53
JoeT4R's Avatar
JoeT4R's Avatar
That’s awesome to hear. Honda is a different world for me since I’ve been driving a Toyota the last 11 years. It’s funny you mention that because I was just looking at the Aisin timing belt & water pump kit just a few days ago. It’s definitely on the to-do list as it’s never been done on this car before. Ideally I’d like to get it done before the end of the summer.
I’m beginning to catch up on all the standard maintenance it needs so it’s a slow work in progress. Did a full brake job yesterday as a matter of fact.
Old 05-10-2024, 11:27 AM #54
JoeT4R's Avatar
JoeT4R's Avatar
The brakes were fine minus the passenger rear. One of the pads was almost completely gone. So I took the opportunity to knock out a full brake job front and rear just to get everything on the same page.
Took me a few hours to do and I ended up having to rent a piston compression tool from Advance but thankfully they had it. I had to remind myself that I’m not a professional mechanic, I’m an “enthusiast” who does this as a hobby and as an effort to learn new things and ultimately save myself money.
Wagner rotors, Akebono pads all around. They brake nicely. Nothing extreme and the initial grab is barely noticeable.
Old 05-10-2024, 12:55 PM #55
gomiami's Avatar
Real Name: Jay
gomiami's Avatar
Real Name: Jay
It has never been done? I'm not sure about your specific car but most Honda timing belt/water pump service intervals are 105,000 miles. If that belt breaks, your engine is gone...so don't put it off too long.
Old 05-10-2024, 02:20 PM #56
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I agree on getting that timing belt done ASAP!!
I can't say I have ever seen a rotor break like that!!
Is that what prompted you to do the brakes?
2004 Limited V8
Old 05-10-2024, 03:26 PM #57
JoeT4R's Avatar
JoeT4R's Avatar
@gomiami Nope, never been done. And yup, I’m on it. With it being an interference engine that’s definitely a concern for me.
@AuSeeker Lol, no, I broke the rotor trying to remove the screws in it by whacking it with a hammer. I had success doing that with the front rotors and then I was able to unscrew them. The rears I had to drill the screws out, so no biggie.
Old 05-12-2024, 03:39 PM #58
JoeT4R's Avatar
JoeT4R's Avatar
First & foremost, Happy Mother’s Day to all the Moms out there…
Finally fixed my storage compartment that wasn’t staying shut. Just like on YouTube, the clip/spring mechanism wasn’t seated properly. Removed trim pieces, unscrewed screws, pull things out, move things around, reinstall and bam, back in business baby.
I also removed my grille today and properly dipped it. I think it looks half decent at least.
Old 05-12-2024, 05:39 PM #59
JoeT4R's Avatar
JoeT4R's Avatar
When I have parts lying around, free time to install them, things get done. And things got done today. Out came the original Denso plugs and in went NGK Iridiums. The Denso plugs had 137,232 miles on them and actually didn’t look terrible.
As I’m continuing to work on the Accord, it really makes me grateful for all the experience I gained from learning how to do anything car related when I did it first on my 4Runner. It was actually quite pleasing to do this job on the Accord. The rears presented the most difficulty but all I had to do was find the right angles (twss)
Yes I know VCG’s are in my foreseeable future, lol. In time they will get done. For reference, the last picture shows all 6 Denso plugs. The top 3 are from the rear and the bottom 3 are from the front.
Old 05-16-2024, 08:57 PM #60
gomiami's Avatar
Real Name: Jay
gomiami's Avatar
Real Name: Jay
Did the plugs come out easy enough? I'll be replacing the plugs on my SI soon and I always do a little prayer that they won't seize.
4runner , head , honda , thing , things
Mats Honda Accord, CRV and Crosstour ochoa1801 For Sale: Non-T4R Items 0 07-28-2016 01:34 PM
Honda accord seats papawhellie Classic T4Rs 3 08-01-2013 09:28 PM
Crap Brakes (Honda Accord) Bigrupp General Discussions 3 11-10-2010 10:28 PM
'98-'02 Honda Accord 2-dr accessories MikesToy Classifieds - buy & sell (no commercial ads please) 1 10-20-2009 08:01 PM
2008 Honda Accord peter78 Off Topic 4 08-26-2007 11:19 AM
