Off Road Shop in PA
I am looking for an off-roading shop in eastern PA…more specifically the suburbs north of philly near princeton
It might also be worth looking at this place, located in NJ
OK Auto, 4WD & Tire ? OE, 4x4, and Performance Specialist for Cars, Jeeps, Trucks, and SUV?s! |
Quote:
Quote:
Quote:
Kudos for Mainline Overland as well
what are you looking for specifically?
You may want to ask
@Alex T4R
about ok4wd.
OP, it is all depends what you are installing, OK4WD do quality work on jeeps and apparently some employes have Toyota and as mention before some people were satisfied with them. I was recommended this shop by SPC and I didn't not have a good experience like other people. So you might be more fortunate and have good experience with them. What I did like about them is they called the shop who fixed everything for me and ask what they did wrong, that means they care and they want to improve.
Quote:
Quote:
Quote:
http://www.toyota-4runner.org/5th-ge...ml#post1585231 |
OK4WD did a lot of work on my JKUR & I'm totally satisfied & can recommend them.
I haven't had Main Line work on anything but I can vouch for the guys. Got to know them through the VT Overland rallies etc. The quality of their work based on the builds has been great (JKs, FJs, Cruisers, etc). I'm in Princeton too (for work), live in Lambertville. |
Quote:
Quote:
I can proudly say that Mainline Overland is a great shop! Friendliest guys I've talked to in a while at a shop. Pete was really helpful and they have earned my business for every 4runner i own.
:thumb3: |
Im watching the guys at mainline overland reboot my CV's and good news they're torquing every bolt to toyota specs…good to see
:trophy: |
Quote:
The saddest thing about your post... We consider torquing bolts "good to see", when it should be what every shop does. Too many shops are trying to "short cut" everything for profitability. |
Quote:
Main Line
Quote:
As A lot of you know Main Line Overland worked on my 5th Gen. What you don't know is the frustration I had with the work after the fact. I must give credit to Pete for his efforts to rectify wrongs but the number of wrongs became to great. This summer I took a three month cross country trip out west. My trip was delayed by 3 weeks trying to work bugs out in my Dual Battery and sPods install. After my second sPod I had problems with my lights even turning on. My Dual Battery install wiring was not crimped properly causing the battery cables to fall out of the terminals. This lead to an abort while driving the White rim trail in UT and a new battery. My Schrockworks rear bumper was hard to fit and it turned out two bolts had been left in causing the bumper to fit improperly. The bumper was not bolted in correctly, as a result, on the trail the bumper flexed and folded my lift gate corner in. I also found a wrench still attached to one of the bumper bolts. They did give me refunds for some mistakes. UCA ball joints had to be turned and a realignment was needed. Discount on Paint do to rust after two days. Pete did bring my truck from PA to NH after a repaint. I still have to redo work I payed for and that just isn't right when you pay money to have things done right the first time. Good luck with Main Line guys. |
Quote:
Quote:
How long ago did you get your work done? |
Quote:
Pete told me they've been open for just about 3 years so they may have had just a rough beginning. I was nothing but pleased with my experience but thats too bad that you didnt have the same experience. Pete was super knowledgable and friendly and very professional to me...maybe it was just a fluke or due to their young life as a shop
Quote:
Quote:
Quote:
This has happened to me at High Tech as well. And unfortunately there's nothing you can do to salvage the relationship with the customer if the damage as already been done. All a shop can take from this is a learning experience. I'm extremely impressed that @Lebengeek hasn't completely destroyed MLO's reputation on this forum. That just shows me that he has class and that Pete really did his best to rectify the situation as much as he could. Quote:
Quote:
Quote:
I do understand what you mean, and i am only a college student on a college budget so i can usually only afford to get one thing done at a time. Usually no more then 4-500$ in labor. I do plan on using them again for UCA's and my front and rear bumpers as well as sliders so i will update the thread as time goes on. Also @zopperman seems to have a plan to try them out to do some custom fab on his skids so he may be able to put some input in as well |
Quote:
Based on others' experiences I am not certain I would use them for a larger job, but then again I do most of my work myself and when the time comes if I can't get my T belt squared away, I will probably take it to high tech (since I'll be in VA anyway). Though it does seem, like @Ducmonsta said, they did do their best to rectify the situation which is about the best one can ask for after a mistake has been made, unlike the shop I dealt with back in NJ as some of you may recall that nightmare. :doh: (speaking of which, once I get my hands on a spring compressor I'll post up pictures of their butchered coil over assemblies) anyway sorry for the off topic stuff, but that's my opinion fwiw |
| All times are GMT -4. The time now is 04:16 AM. |
Copyright ©2000 - 2026, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by
