'05 V8 Throttle Position Sensor Codes - Won't Start?
A couple of weeks ago I was in a bind and had a shop replace my starter. They snapped the wires at the connector for one of my knock sensors so I went under and repaired that myself. So after that job I thought damn, I need to clean this engine bay up. Well, I did, and now I can't get to start. Been digging on the forums all day and can't find anything so I'd appreciate y'alls input.
Symptoms:
Additional info/things I've tried:
Update: still troubleshooting. I've replaced the throttle body (for new throttle position sensor) as well as MAF, still same symptoms. Turns over just won't start. It has been 1 week and though it is winter we have had a few days hit highs of mid 50's and sunny. So I think there would have been ample time to dry out any connectors that may have gotten soaked. I now think I have fried my ECU. I have a new ECU on order thru ebay but I want to try to track down where the short was created before installing the new ECU and potentially frying it all over again.
FYI for future reference: just stay away from water hose in the engine bay. I know some of you are rolling your eyes, I get it. I was just trying to take care of my stuff so don't bust my balls. I did some searching here about others using pressure washers with no issue, so I thought I'd be safe. I did a procedure similar to ChrisFix on youtube. I have done that procedure twice between my old 2012 FJ Cruiser and my wife's car. During my research here, I've learned about how sensitive these 4th gens are to water. Too many threads from creek crossers frying ECU's. I'll keep this thread updated as I go. But I sure would take any input from anyone who has had or heard of similar situations. |
Did you ever figure this out? I've been fighting 0121 and 0123 codes for like three years now.. Dealership hasn't even been able to figure it out.
Quote:
Quote:
By my quoting and mentioning both of you, you both will get 2 notifications directing y'all to my post/reply. |
Forgot to update.
Short story: my timing belt slipped which is why I couldn't get a start. Not sure why that threw so many codes. Long story: after 2 weeks of banging my head I called up a mechanic to come take a look. They had a nicer code reader and picked up codes that I wasn't getting on my cheaper model. They tested air, spark, fuel for me which was all OK. Still couldn't get a start though. Before I swapped in a new ECU I wanted the dealership to hook their reader up so I towed up there. After 2 weeks they still couldn't figure it out or get it to start. Then I had an epiphany - it was cold the morning I washed my engine bay and there was some freezing going on. When I tried to start it up that first time I wondered if the timing belt pulley was slick and slipped. Long shot but was out of ideas. Called the dealership and 2 hours later they called back saying it was out of time. Ran like normal after a retime. They didn't tell me anything about the codes, but i assume they cleared the codes from their reader and I haven't had one pop up since. |
Quote:
My timing belt had slipped, so my fix in this case was to correct the timing.
Quote:
Quote:
Quote:
Quote:
Agreed on the TB, never heard of one slipping a tooth or two and don't see how it happens unless the tensioner is junk. Lucky I guess. |
Been two youtube videos recently on 4.7L V8 timing belt failures and no engine damage, new timing belt installed and all is good.
Quote:
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
