FS: 2002 4Runner SR5 - 292k - 4500 - Salt Lake City, UT
1 Attachment(s)
MORE PHOTOS HERE: https://cars.ksl.com/listing/9057217
2002 3rd gen Toyota 4Runner for sale. Full list of modifications and maintenance during my ownership is listed below. Was an Arizona car up until a few years ago, only some mild surface rust and nothing structural. Highlights include a locking rear differential swapped in, 3in lift kit all around with brand new front struts, 33” Falken Wildpeaks (~20k miles), CarPlay/Bluetooth stereo, fully sound deadened cab with upgraded speakers, and Corbeau Suspension Seats. Mechanically, the truck runs but needs some work. A suspected head gasket/cylinder head failure has led to a misfire check engine code and roughness on cold start and at speed. Drives just fine around town but around 60mph it develops a vibration due to this misfire. Can be driven on the freeway but is not idea, and I don't have the free time or energy to deal with fixing it. Besides the engine issue, it is in excellent condition. Just had a major overhaul done at Mark Miller Toyota in SLC. Exterior is a 7/10, see photos. Some small rust spots and chips in paint. Happy to include the roof box if buyer desires. It is not in great shape but I have no use for it any more. SOLD AS IS Motor/Drivetrain B&M Transmission Cooler 4.30 E-Locker Swap (2/5/20) (240k) New 4.30 Front Diff (2/5/20) (240k) Armor 4xInnovations DOM Sliders (4/6/19) Hitch Flip (2/1/21) Lighting Clear Corner Lights (13/5/19) CBI Ditch Light Brackets (12/14/21) Suspension Bilstein 5100 Shocks (3” Lift Springs) Toytec 9602RC-P 3” Lift Springs (2/7/21) Durobumps Bump Stops (19/7/19) SPC UCAs (7/9/20)* Sonoran Steel Lower Links w/Strongflex Poly Bushings (2/1/21) Spidertrax 1.25’ Wheel Spacers (2/1/21) Electrical AndyMod 2.0 (8/8/2019) Wired for CB Radio Sony XAV-AX1000 Head Unit (7/24/21) Harmon Kardon Infinity Kappa Front Speakers (8/10/21) LED Dash/Climate Lights Swap (8/11/21) Other AVS Rain Guards/Hood Deflector 16in Konig Countersteers Ultragauge w/Spiker Engineering Mount (8/16/19) Corbeau Baja XRS Seats (9/15/19) 1in Toytec Body Lift (1/11/20) 285/75/16 Falken Wildpeak AT3W (9/19/22) (270k) 46” Sherpa Load Bar System (23/7/21) Fully Sound Deadened (8/10/21) Maintenance New OEM Spark Plugs (12/06/23) (290k) New OEM Spark Plug Wires (12/06/23) (290k) New OEM Ignition Coil (12/06/23) (290k) New OEM Intermediate Steering Shaft (12/06/23) (290k) Oil Changed (12/06/23) (290k) Oil Filter Changed (12/06/23) (290k) Transmission Fluid Flushed and Changed (12/06/23) (290k) Power Steering Fluid Flushed and Changed (12/06/23) (290k) Fuel Injectors Cleaned (12/06/23) (290k) Throttle Body Cleaned (12/06/23) (290k) New OEM Heater Control Valve (12/06/23) (290k) New OEM Upper and Lower Radiator Hose (12/06/23) (290k) New OEM Front Right Wheel Bearing (12/06/23) (290k) Alignment Performed (12/06/23) (290k) New OEM Alternator Belt (8/4/23) (284k) New Headlight Bulbs (8/9/23) (283k) Oil Changed (7/3/23) (278k) Oil Filter Changed (7/3/23) (278k) Oil Changed (12/2/22) (272k) Oil Filter Changed (12/2/22) (272k) Oil Changed (6/25/22) (265k) Oil Filter Changed (6/25/22) (265k) Oil Changed (3/4/22) (262k) Oil Filter Changed (3/4/22) (262k) Fresh Gear Oil in Front Diff (1/21/22) (261k)* New Pinion Seal (1/21/22) (261k)* New Front Axle Seals (1/21/22) (261k)* New T-Case Output Shaft Seal (1/21/22) (261k)* New T-Case Actuator (1/21/22) (261k)* New Transfer Case Assembly (1/21/22) (261k)* New Rear Driveshaft (11/9/21) (258k)* New Fuel Hanger (11/9/21) (258k)* New Fuel Tank Gasket (11/9/21) (258k)* New Fuel Pump (11/9/21) (258k)* New Fuel Strainer (11/9/21) (258k)* New Fuel Filter (11/9/21) (258k)* New O2 Sensor (11/9/21) (258k)* New E-Brake Cable (11/9/21) (258k)* New Windshield (8/11/21) (255k) New OEM Timing Belt (8/6/21) (255k)* New Aisin Timing Belt Tensioner (8/6/21) (255k)* New OEM Accessory Belts (8/6/21) (255k)* New OEM Water Pump (8/6/21) (255k)* New Valve Cover Gaskets (8/6/21) (255k)* New Denso Spark Plugs (8/6/21) (255k)* New Spark Plug Wires (8/6/21) (255k)* New Poly UCA Bushings (8/6/21) (255k)* Oil Changed (7/25/21) (255k) Oil Filter Changed (7/25/21) (255k) New Battery (7/25/21) (255k) New Air Filter (7/25/21) (255k) New Wipers (7/24/21) (255k) New VSV Valve (2/2/21)* Oil Changed (11/3/20) (249k) Alignment (7/10/20) (245k) New SPC UCAs (7/9/20) (245k)* New Lower Ball Joints (7/9/20) (245k)* New Poly LCA Bushings (7/9/20) (245k)* New Tie Rods (7/9/20) (245k) New Steering Rack (7/9/20) (245k)* Oil Changed (7/5/20) (244k) Oil Filter Changed (7/5/20) (244k) Oil Changed (1/7/20) (239k) Oil Filter Changed (1/7/20) (239k) New Battery (9/17/19) (235k) Oil Changed (8/8/19) (234k) Oil Filter Changed (8/8/19) (234k) New Starter (8/5/19) (234k) New Air Filter (7/4/19) (232k) |
Sold
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
