Lasfit Heavy-Duty Dual-Cylinders Inflator: Product Overview and Usage Guidelines
5 Attachment(s)
Lasfit's latest product release has arrived, and it's here to revolutionize your car maintenance routine - introducing our new inflator pump!
Designed for convenience, this compact inflator is a game-changer for truck owners. Whether you're faced with a flat tire during a cross-country road trip or need to inflate sports equipment on the go, our inflator has got your back. Its small size fits perfectly in any trunk, making it an essential tool for you. Say goodbye to the hassle of tire inflation with Lasfit - keeping you on the road and ready for any adventure. Product Overview: Exterior Design: With a unique aesthetic and a sense of power, this product boasts a distinctive look. The backlit LED display screen provides clear numerical readings. It is an upgraded heavy-duty inflator designed for larger vehicles such as off-roaders and pickup. Powerful Inflation: Featuring an innovative dual-cylinder design, it achieves an impressive inflation rate of up to 50L/MIN, with a maximum pressure of 150PSI, inflate off-road tires in just 3 minutes. 4+N preset mode: SUVs, motorcycles, bikes, balls and custom mode(0~120PSI) Dual Charging Methods: Equipped with a huge 12000mAh battery, comes with a 12V DC power cord, allowing inflation on-the-go. Auto-Stop Function: Once the preset pressure value is reached, the inflator automatically stops. This eliminates the need to constantly monitor tire pressure. LED Light and Power Bank Function: Lasfit's inflator features a flashlight, making nighttime operations hassle-free. It can also be used as an emergency power source for charging your phone. Comprehensive Accessory Set: Considering various inflation needs, the accessories include 2 extended 27.6-inch air hoses with an innovative quick connector, 1 *12V DC power cord, 1 *2.0Ah USB-C fast charging cable, 1 *nozzle cone, 1 *needle adapter, 1 *Presta adapter, 1 *portable carrying case, and 1 *user manual. Usage Guidelines Usage Scope: Suitable for larger vehicles such as off-roaders and pickup truck, motorcycles, bicycles and all riding tools, as well as inflating sports balls and inflatable toys. Note: For a better user experience, it is not recommended to inflate larger tires like Trucks, motorhomes, large size tires for agriculture. Special Reminder: It is necessary to set the preset value under the specific scenario mode. For example, when inflating a car, do not set it to the motorcycle mode. The measurement method of the pressure gauge inside the inflator varies for different objects, and the inflation rate differs in different modes, which may lead to inaccurate readings. Note: If you don't have a need for large vehicle tires like off-road, you can consider Lasfit's flagship portable inflator, which is suitable for household sedans: LAP-CR1 |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
