2002 Not starting but turns over fine with new battery
Bought a sweet '02 LTD last year. Ran perfectly fine. Battery went dead during winter. Replaced the battery with a $300 Super Start. Lights come on, everything worked, but it just wouldn't start. Noticed my FOB wasn't working. Just replaced the battery in that and works perfectly fine, doors lock and unlock. Same issue. Ran a scanner, only code I got is C1224 (ABS). Swapped the EFI w/ the taillight, same issue. Put them both back, checked the taillights are operating, and yes. A neighbor recommended spraying some brake cleaner into the air box (after removing the air filter of course) to dismiss fuel issues, but I'm not sure that is a good idea. OK I am befuddled... Help please!
Quote:
Quote:
Quote:
Quote:
Quote:
Quote:
Depending on the condition of your engine dumping the adaptive parameters when the battery died may cause a hard start since it needs to relearn its idle parameters.
If you have spark try shooting starter fluid in the intake/throttle body. Sent from my iPhone using Tapatalk |
Quote:
Are you saying , it cranks but does not start?
Maybe the Immobilizer is acting up. |
Quote:
Maybe do a hard reset. Disconnect the positive and negative battery cables and touch them together for a few minutes. Then reconnect battery.
Quote:
Quote:
Quote:
* Edit: OK just tried reprogramming using this method (tried three times, no luck at the first auto-cycle) 1. Start with the following conditions: you are in the vehicle a. Key is out of the ignition b. Drive door is open ( all other doors are closed) c. Driver door is unlocked (other door locks don't matter) 2. Insert the key into the ignition (don't turn it) and pull it out. 3. Perform these steps within 40 seconds: a. Cycle the power locks 5 times. Use an even pace and try to go relatively fast. b. Close, then open the drivers door. 4. Perform these steps within 40 seconds: a. Cycle the power locks 5 times (same as before). b. Turn the ignition to ON then back to OFF. c. Turn the ignition to ON then back to OFF. d. Remove the key from the ignition. 5. Within 3 seconds, the power door locks should cycle (automatically) indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point. 6. Perform these steps within 40 seconds: a. Press the LOCK and UNLOCK buttons on the transmitter simultaneously for 1 second. b. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle ( LOCK then UNLOCK) once-- indicating successful programming. If the door locks don't cycle, or cycle twice. Repeat steps 6a and 6b--this remote has not been accepted. c. Repeat steps 6a and 6b for EACH transmitter that will operate the vehicle. Including any old transmitters. 7. Close the driver door. |
Quote:
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
