3rd gen T4Rs
https://www.toyota-4runner.org/3rd-gen-t4rs/)
| atxrunner |
07-29-2012 06:12 PM |
Help basic maintenance today and runner Wont Start???
Just finished changing my spark plugs and tightening my valve covers while i was at it and now the my 4runner will not start? All accessories turn on but it will not crank. By the way it is a '97 Limited 3.4. Anyone have any clues? It does still have original coil packs and wires from '97. Any help would be great....:ybrick:
| rm2fast |
07-29-2012 06:21 PM |
Quote:
Originally Posted by atxrunner
(Post 1129856)
i would go back and go over everything you did once more! if it ran before plugs and valve cover something must not be hooked back up properly if the only thing you changed was that
| PitbullRescuer |
07-29-2012 06:24 PM |
Did you plug the coil packs back unto the harness?
| jbstrd |
07-29-2012 06:46 PM |
Did you disconnect the MAF Sensor and forget to plug it back in. Your engine will not start with this unplugged.
| atxrunner |
07-29-2012 07:00 PM |
I've triple checked and everything is connected properly. I also should mention while tightening closest valve bolt on driver side something arced (pop) with I assume the wires that are in that harness there covering that bolt. Ha I then disconnected battery and proceeded with the plugs.
| jbstrd |
07-29-2012 07:20 PM |
Time to check your fuses.
| atxrunner |
07-29-2012 07:39 PM |
i checked all the fuses but unsure how to check the relays... maybe ohms test on the relays?? does anyone know?
| TheDurk |
07-29-2012 07:51 PM |
Check the ground by the diagnostic plug. People loosen this to get to driver side plugs and don't retighten and nothing works on the engine without this ground.
| atxrunner |
07-29-2012 08:01 PM |
checked it. Its tight i didnt have to loosen it to get to the plug.
| atxrunner |
07-29-2012 08:17 PM |
no clicking from starter either
| LittleCaesar |
07-29-2012 09:02 PM |
What is the battery voltage?
Headlights and all working?
| atxrunner |
07-29-2012 09:28 PM |
Battery Voltage is 12.8
Update i just noticed when i turn the key to the start position the radio goes out and the clock fades out if that helps diagnose...
| DC runner |
07-29-2012 09:44 PM |
Bad connection somewhere. I had these exact same issues and it came down to a bad connection. Check everything.
| atxrunner |
07-29-2012 09:48 PM |
hmmm checked all the fuses could it be the Starter Relay? I called autozone and it was $43 :wow:
| opie74 |
07-29-2012 09:52 PM |
Did you load test the battery or just check voltage? It may show proper voltage but 1 (or more) of the cells may have gone bad and under load (like when starting) it gives up. I think your battery gave up.
| All times are GMT -4. The time now is 01:29 PM. |
Copyright ©2000 - 2026, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by
