Toyota 4Runner Forum - Largest 4Runner Forum
Toyota 4Runner Forum - Largest 4Runner Forum (https://www.toyota-4runner.org/)
-   3rd gen T4Rs (https://www.toyota-4runner.org/3rd-gen-t4rs/)
-   -   Bilstein Lift (https://www.toyota-4runner.org/3rd-gen-t4rs/129573-bilstein-lift.html)
TRDteen 11-27-2012 01:39 AM
Bilstein Lift
Man, after many attempts of trying to get this lift on my rig, I did a little more research (which i should have done BEFORE buying it and trying to install it :redbrick:). I found out that since I am running complete stock suspension, I needed to get the Bilstein 4600 series. Instead, I bought the 5100 series. What i need to know is, if i get a 1" body lift, will i be able to fit the 5100 series on? If not, looks like I'll have to sell 5100's and purchase the 4600 series. Also, if I do have to get the 4600's can I still run OME 883 coils with it?
PitbullRescuer 11-27-2012 01:56 AM
???? You can run the 5100's. what's makes you think you can't?
TRDteen 11-27-2012 01:57 AM
Quote:
Originally Posted by PitbullRescuer (Post 1231329)
???? You can run the 5100's. what's les you think you can't?
Well, I've tried 4 times. 3 times in my auto class, and once with my old man yesterday. We tried everything to get the damn thing in. Unbolted the swaybar end links and even used a pry bar to pull the LCA down and it still would not fit in. Unless I'm doing this wrong, it will not go in.
TRDteen 11-27-2012 01:59 AM
I also looked up on the bilstein website what i can run with my car. 1999 4Runner, 3.4L, Limited, and it came up with the 4600 series. If i could run the 5100's don't you think it would also give me that option?
Dezert4Runner 11-27-2012 02:03 AM
5100's fit all 3rd gens. 883's are roughly a 3" lift coil if you have a stock bumper, so anything above the bottom perch & I'd be surprised if you said you mounted it successfully. Did you try using the stock bottle jack upside down on the upper control arm too?
TRDteen 11-27-2012 02:05 AM
Quote:
No, but I have heard about using that method. Maybe I'll try that and see if it will fit in. But i don't want this thing to be at max extension and and hit a bump and blow my bj bearings...
Dezert4Runner 11-27-2012 02:10 AM
Extend your shocks by using a 3" top plate spacer and you will effectively be using your LBJ as the bumpstop, a longer spring just uses more of your down travel at ride height.
PitbullRescuer 11-27-2012 02:11 AM
I think you're getting yourself a little confused. 4600 is a stock replacement shock. You can run the 5100's but I'd put them on the lowest perch. A body lift won't help your problem one bit. And there is no such thing as a BJ bearing.
Try putting the compressor back on the spring, wind it down a bit, install and then take the spring compressor off.
Dezert4Runner 11-27-2012 02:13 AM
Let's see a pic of your springs mounted on the shock.
TRDteen 11-27-2012 02:14 AM
Quote:
Originally Posted by PitbullRescuer (Post 1231344)
I think you're getting yourself a little confused. 4600 is a stock replacement shock. You can run the 5100's but is put them on the lowest perch. A body lift won't help your problem one bit. And there is no such thing as a BJ bearing.
I bought the lift used. So they way they came, are the way they came. Is there any other way I can "wind it down"?
TRDteen 11-27-2012 02:15 AM
http://img.tapatalk.com/d/12/11/27/2ure6ega.jpg
Dezert4Runner 11-27-2012 02:20 AM
Can't tell from that pic, but is is seated on the lowest groove of the shock?
TRDteen 11-27-2012 02:23 AM
http://img.tapatalk.com/d/12/11/27/ta6yra4y.jpghttp://img.tapatalk.com/d/12/11/27/ypy8ejaq.jpg
Dezert4Runner 11-27-2012 02:44 AM
Looks like you have the Tacoma version. Is yours on the bottom notch? Hard to tell. This should help. You want yours on the "stock height" groove.
http://downsouthmotorsports.com/images/F2055118.jpg
TRDteen 11-27-2012 02:47 AM
Quote:
That helps alot. But i think im on the 0.85" notch. How can change it?
Copyright ©2000 - 2026, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
