Pre-Purchase Info, Modifications, Write-Ups, Quick Links, and FAQ's
New and prospective new owners
I just purchased an 04 Sr5, following is information I found before and after my purchase. I am posting this here because this forum had by far the most information I was interested in. Not having owned a 4Runner since my 88 years ago I wanted to know what these things were about and what could be done to them. I see many other people asking the same questions I was looking for answers to. Primarily this means mods, and that's why so many links below are to mods. I didn't want to ask a question that had been asked a hundred time so I searched the hell out of the forum, finding and reading tons of info. This isn't all inclusive, just the links I saved while researching and thought it might help others. Feel free to PM me if you have corrections or things I should add. #1 Read this post or go directly to #2. My info is laid out Info, mods, retail sources. #2 As on any forum, please use the search feature at the top of the page, or when you are on the main "4th Gen T4Rs" page use the "Search this forum" link just above the first post. The same questions get asked many times and people occasionally get irate about questions that can easily be answered by searching. Chances are someone has experienced your problem or done the mod you are contemplating. #3 If you have searched and can't find your answer create a post and ask a question, there are a lot of knowledgeable people here. http://im.toyota-4runner.org/images/...2/firstnew.gif FYI, this icon next to a post take you to your first unread post in that thread. Let's get started... :) Start here... Toyota service records - sign up, enter VIN Toyota owners manuals Official 4Runner Brochure Topic - toyotareference Info on changes every year of the 4th Gen 4Runner 4Runner history Wikipedia 4th Gen Suspension Options/FAQ - ARK_SWAMP_RIDER 4th gen 4Runner Secrets? must read - supraman215 4X4NOW 4-Wheeling "How-To" (good info) Parts cross reference find out what other Toyota and Lexus cars use a particular part number. This link is the light sensor used in the auto headlight mod, which you should be able to pull from a Carolla or Camry and any junkyard. Stickys, your forum friend In case you missed the stickies on the most commonly asked about information 4th Gen Suspension Options/FAQ - ARK_SWAMP_RIDER 4th Gen Armor Thread - Sliders/Skids/Bumpers - Dusty Driftwood ...Lift and Tire central... (If you're thinking about it it's probably been done and is in this thread) - hammersc 4th Gen Build Thread (see what other have already done) - gaterose Basic 4th Gen 4Runner information 4th generation 4Runners include model years 2003-2009. There are 3 basic models, SR5 (base), Sport Edition (has hood scoop) and Limited (more luxury oriented). There was a Urban Runner package available on the 2008-2009 Sport Edition v6. In 2009 a Trail Edition package was available, this was the only 4th ten with a factory locking rear differential. There are 2 engines, v8, it has timing belt that needs to be replaced at regular intervals and a v6 with a timing chain. All 4Runners feature a locking center differential. From what I have seen, silver is by far the most common color. And yes, if you maintain them they should go for over 300 thousand miles. 2005-2009 are equipped with VVT-I (variable valve timing) and have a 5 speed automatic instead of 4 speed. No manual transmissions are available in any 4th gen. The v6 gets around 20 mpg highway, the v8s slightly less. The 5 speed slightly better mileage that the 4 speed. This can go do with Mods of course. The v8 is full time all wheel drive while the v6 is selectable 4 wheel drive. The X-REAS suspension standard on the Sport and optional on the Limited offers significantly better road handling, however may limit lift options. The X-REAS system links diagonal shocks to limit body roll during cornering. Side air bags were an option from 2003-2007 and standard in 2008-2009. All years received safety ratings. Tire pressure monitoring was standard in 2004. In 2007 rollover sensor side curtain airbags were added as well as side torso air bags. Third row seating was available as an option on SR5 and Limited beginning in 2004. From what I have read it is not feasible to add 3rd row seats to a 4Runner that did not come with them. 2006 brought projector headlights and LED tail lights. The tail lights are a direct swap to 03-05 4Runners. The headlights will swap, you will need to buy the pre-painted trim pieces that fit under the projector headlights. There will also be a small gap between the lower corner of the headlight and the grill due to changes made from 05-06. The 06 grill is not a direct swap to earlier year vehicles. If you are buying a 4th generation 4Runner try to obtain service records from the previous owner. Any maintenance and repairs done at a Toyota dealership can be looked up online, see link in previous post under New and prospective owners. You simply create an account on the website and enter the VIN number for any Toyota. You do not have to be the owner of the vehicle to do this. You can find the VIN on the tailgate, doors, etc, see boondoggle's post below. A guide to the V6 vs V8 debate by rcebowl Maintenance Parts cross reference (Toyota and Lexus vehicles by part number) 07 V8 4x4 Zerk Fitting Pics UPDATED with all 6 - Buckfever 2007 4Runner SR5 V6 Front Brake Job (youtube) - JASON16V My 4th Gen Front Brakes walkthrough - Ducman Front brake caliper & pad replacement - Kmvreter http://www.toyota-4runner.org/4th-ge...c-read-me.html - @BlackWorksInc Good build threads - not all inclusive, no favoritism, just some I liked blk-4runner's build thread - blk-4runner DawgRunner's Build - DawgRunner daPitbull's 4Runner build - daPitbull gaterose build thread - gaterose Lighting - Interior Take apart the A/C controls - A/V1 Footwell Led Lighting Mod LED lighting on door locks....!!!! for Taco, might work on T4R DIY: Interior LED swap (cluster, HVAC, switches, window, *steering wheel) - darkie3495 Detailed how-to to swap Steering wheel control LEDs Lighting-Exterior OEM Automatic Headlight Install - Asmara Daytime running lights - sharp4runr LED Courtesy Lights Write up - 2007toyota4runners Running Boards - Painting / Lighting DIY - Pennywise 2010 4Runner Mirrors Worked! - Blacked Out TRD Auto Dimming Mirror Install w/pictures - 4RunnERD 06 Headlight wiring - mario552k projector head lamps - mlopez61 using fog lights as daytime running lights - wasc007 [pictures]...TSX Retrofit On Lexus SC300 - icantsee Tail Lights LED Project - AlexJet Headlight Projector Mod vs. Buying OEM 2006+ Headlight Assembly - triguy74 Independent use of Fog Light Mod Rear Foglight mod (bumper reflectors) bryancos Rear foglight Mod - My LED Bumper Light conversion - cdoyle LED Tail Lights installed - cdoyle LED 3rd Brake Light DIY - 004Gunner LED 3rd Brake Light DIY (Taco) Exterior LED Lighting:- exterior lights to LED aftermarket Projector Housings for 03-05s basic info - lovemybadkitty Morimoto xb led angel eyes - 2007toyota4runners Auxiliary Reverse Light Question: What do you recommend? - jbmccul another blacked out headlight thread...DIY lots of pics. - leftyguns21 Blacked out Headlights 06' Sport DIY - magert54 OEM LED tail light Install w/ pics (06-09 to 03-05) - CookieRoe projector head lamps - (06-09 to 03-05) - mlopez61 30" LED Bar Behind Lower Grill - ARK_SWAMP_RIDER bulbs.com - Find out what bulbs go in your truck. Electrical 4Runner Homelink Garage Opener - add it to your T4R - DOORZ Full Time 115V Power Outlet Mod Installed a simple 375wt Power Inverter *PICS* Dual Batteries on the Cheap - Titanpat57 "VSC OFF" mod for 4th gen 4Runner Back Window Up Hack with Factory Key Fob - dpodo DIY Built-in iPod Charging USB Port (Lots of pictures and detail) From a BMW forum, but good write-up http://www.toyota-4runner.org/4th-gen-t4rs/157159-diy-mod-how-add-rear-heated-seats.html DIY MOD: How to add rear heated seats - gshadow35 - Great idea! Audio/Video/Navigation Remove head unit from 2003 T4R best way to hook up ipod to stereo? - ALHazlewood Ultimate Scion Headunit (stereo) thread - drbiii Wheels/Tires/Suspension 4th Gen Suspension Options/FAQ - ARK_SWAMP_RIDER The Hot Sheet: 33 Off-Road Tires Tested - Jeep Magazine Plasti Dip Rims w/ lots o' pics - A_HuL Painting stock wheels. Plastidip?? - STRRAYNGE BFG T/A KO vs Goodyear Wrangler DuraTrac link providede by 03_4x4Runner Duratracs, BFG All Terrains, or your input link providede by 03_4x4Runner DuraTracs vs. All Terrain's link providede by 03_4x4Runner Blacking out FJ Wheels (Lots of Pics) - BlairB Swaybar Bushing Upgrade - CJ3Flyr Tire Tech Information/Light Truck Tire Information - Tire Rack Armor (sliders, bumpers, skids, etc) 4th Gen Armor Thread - Sliders/Skids/Bumpers - Dusty Driftwood Sliders - Emman Winch/Recovery BillaVista's Recovery Bible - good info Four Wheeler Magazine - Winch Shootout Cheapest winch options - spnce Interior Leather install - macoyle Satoshi Grilles http://www.toyota-4runner.org/4th-ge...re-thread.html Body/Paint Mytoy4 Satoshi Grille Mod -) Mytoy4 '03 & '06 Retrofit Satoshi Grille Writeup (Picture Heavy) - gaterose 4th Gen: How did you plug the holes in the wheel well? (great idea) - yabedude Engine/Powertrain Tailpipe Mod Complete! (4th gen) - CJ3Flyr Internal Snorkel Mod 4th gen - aha2988 Misc How to make spare chipped keys - nicolachel Keyless Entry Programming ... (key fob remote) - LBC99 Driver door autolocks when in drive? (change auto locking options) - mattstuder1 Door Locks (auto relock) - rnjoe1 Remote control doorlock reprograming guide, I have it - rdrunner Onboard Air - 2000 T4R air compressor installed - zimm J.A.'s Toyota 4Runners Info on nearly every topic DIY Mods: Post Write-ups HERE (links to many MODs) - AlphaQup How did you plug the holes in the wheel well? Keep your engine compartment cleaner, yabedude. http://www.toyota-4runner.org/4th-ge...iy-videos.html 4th Gen Helpful DIY Videos - Stuck CAPS http://www.toyota-4runner.org/4th-ge...d-threads.html My collection of DIY and MOD threads - gshadow325 Retail - Toyota parts 1aauto.com rockauto.com villagetoyotaparts.com - with parts diagrams toyotapartsoverstock.com - with parts diagrams Auto salvage search - Car-Part.com--Used Auto Parts Market Retail - Accessories autoanything.com Variety od offroad gear - TJMUSA You can save a lot on Husky floor liners at Advance Auto using coupon codes, usually 30 or 40%. Liners are expensive, about $115 for the cargo and $75 for each front and rear. This is how to save, find the best coupon deal, often it is at the $100 spend level. In this case make one order for the cargo liner and another order for the from and rear liners. This should save you $60-80. Sometimes adding a small filler item can get you a better discount. This also works well for batteries. Retail - Armor/Winches/Bumpers/Skids Sonoran Steel Budbuilt Shrockworks DeMello Offroad Engo winches Amsteel Synthetic winch line Viking Off-Road Synthetic winch line Marlin Crawler CBI Offroad Fab Trail-Gear Inc 4x Innovations WabFab Offroad Retail - Lighting Angel Eyes LED - and other truck and outdoor gear LED - Vleds LED - Superbright LEDs - Superbright LEDs replacement bulb guide - JustSomeName TheRetrofitsource Xenon/lighting, see 2007toyota4runners's post below. DDM Tuning LED HID and LED by Vehicle - Toyota 4Runner Master List of LEDs Bulb Sizes & DIY/Tutorials for Interior/Exterior Lights Bean LED Industries - Good selection of lighting products Retail - Misc OEM type switches DEI 530T window control module (Amazon) DEI 545T Nite Lite Nite-Lite System |
4r
Yuuuuuuuuuuuuuup !!
Why isn't this a sticky yet?
Very nice list, props to you for putting in the work and searching so much. Enjoy the new truck! :whoo:
Thats is a great post!!!!! Please add TheRetrofitsource for Xenons I support them 100% over DDM There quality is jaw droppping but just a suggestion
Quote:
Quote:
Thank god someone finally did this.
I've only been a member of the site for about 10 months and have thought about writing up something like this because you're right. Everyone always has the same questions and the answers are always the same. Something else that might be worth mentioning for a prospective buyer is to check the VIN stickers on all the fenders/doors/liftgate to make sure they match up. If not, there may have been an unreported accident. The laser etching in the door windows should match up too. Every other vehicle I've been a forum member for, the forums always have something like this. Make it a sticky mods! :) Now if there were some way to help people pick which tires they should get…. ;) |
lots of people always seem to forget with forums that if all answers were in stickies and no need to post new threads. Why would anyone return?
This REALLY needed to be done...Excellent job sir.
Just bookmarked. Thanks for your effort.
Great post. You might want to add BFG all terrain vs. Duratrac. This gets asked about once a week.
Quote:
Personally, I think there are plenty of things to talk about besides seeing a couple of new 'pre purchase' questions popping up every few days. I know after about the fourth time I quite even replying. It will probably be more helpful to people to have all of their answers in one place, than one or two half-assed answers (because people are sick of answering the same questions over and over). Also nice that iBison posted links to a lot of common maintenance FAQs. Always good to have those easily referenced. |
So.... you've done some research....
Amazing post!
Here's the first correction though: Side curtain airbags were available in 04 (I have 'em in mine!); not sure about 03. |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
