Need new rear springs that work with Bilstein HD's. Stock springs isn't doing it
Hi,
I have a 2001 4Runner Limited and a year ago, I got Bilstein HD's all around and replaced the stock coils/springs with stock. While it did make a difference, I still think the rear is really easy to bounce, like there's no resistance. I apply a little downward pressure in the bumper and it barely resists. I would like to know my options for the rear springs. I've heard good things about OME 906's but I don't know the exact part number and where to buy. I'm not even sure if those will fit as is when I give them to my mechanic to install. Please let me know, when you suggest something, if there's anything extra to be done. All I know for sure is that I'm not replacing them with stock springs again. I bought MOOG stock springs a year ago and I don't think it was worth it. Also I did some measurements from the center of the wheel to the wheel well. Front: ~20.5-21" Rear: ~20" The rear definitely sits lower :/ I'm ok if the springs will lift the rear up to 2-3 inches max. I'm sure it'll settle down anyways. I don't tow or offroad. But I load a lot of computers in my trunk because I work as an IT field tech. |
OME 906 coils
http://wheelersoffroad.com/product/o...rear-coil-set/ 906s are your best bet for the money. Ride great, and will look good with your setup. |
Thanks man!
Yea I had my mechanic check if those Daystar 1.5" spacers would do any good and he said no. I've already bought em for $35 in Amazon lol. |
OME 906 will be the best coil that will provide the least amount of lift. If you have stock 01 coils on the front though, it will gave you a lot of rake with the rear being taller.
Quote:
What are the downsides of having the rear taller? More momentum? |
Quote:
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
