Couple of Questions After Replacing Front Brakes
1998 4Runner Limited 4WD v6.
So yesterday I replaced the front discs and rotors due to warping and warn brakes. And it wasn't too difficult, just a first timer at this. Cleaned & bled, ect. Now it seems my wheel is pulling to the right (passenger side) when applying the brakes somewhat heavily, and doesn't occur when lightly applying (to my knowledge) And also now I hear a thump from underneath the car when reaching the bottom of the brakes and coming to a stop. I read somewhere that the sway bar could possibly be an issue, as my driver side mount has rusted and busted recently. So my questions are: Why the pulling? Why the thump? Is the broken sway bar mount a factor? How to fix? If you need pictures just ask, as I'm sure someone will. Thanks in advance - I'm somewhat a newbie, so go easy on me. |
Quote:
Quote:
Quote:
How is/was the alignment before the brake job?
If it is pulling to the right, then more than likely it is a sticking left brake caliper. If there is a torn seal around the piston, then dirt has gotten in there. Did you notice one? If the piston is not scarred, then a rebuild kit is a good way to go. Just make sure you have the tools to do it. If the fluid was real old, then it could also be a bad left soft brake hose. |
In reply to everyone, it was the broken sway bar mount on the drivers side that made it pull to the right. Replaced both mounts this morning and torqued them down to spec and no more pulling.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
