Can you recommend a good mechanic in Northern NJ that knows 4Runners well?
Looking for a good mechanic in Northern NJ that someone here can highly recommend.
Someone that knows and works well on 3rd gen 4Runners, preferably a dealer tech. If you know, please point me to that person or point that person to this thread. Few things I need to take care of on my 4Runner... - New Timing Belt and Water Pump kit. (Currently I have 82K miles on the truck) - TRD S/C install. - UGR 7th ingector kit install - UGR 2.2 pulley install - TRD Exhaust install - Doug Thorley Headers (I have a 1" body lift on the truck. Would they work? Reason I ask is because the DT website says that it won't with a body lift." - ABS light keeps popping up... Had code 49, Changed and adjusted the brake switch and that wasn't it. LED tailights wasn't the problem either, changed to the stock taillights and nothing. Put the LEDs back on and added resistors just in case. I was told is a green/yellow wire that goes from the brake switch to the ABS ECU...? ABS relay is not clicking. Haven't look at it again yet. If I can't get to fix this by this weekend, this is part of the list too. - Change all fluids, including T-Case and tranny. Thanks in advance for your help. |
:bump:
No one in Northern NJ knows a good mechanic that knows how to work on these trucks...? :snacker: |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
