Toyota 4Runner Forum - Largest 4Runner Forum
Toyota 4Runner Forum - Largest 4Runner Forum (https://www.toyota-4runner.org/)
-   5th gen T4Rs (https://www.toyota-4runner.org/5th-gen-t4rs/)
-   -   cbielat's 2011 SR5 Build Thread (https://www.toyota-4runner.org/5th-gen-t4rs/195701-cbielats-2011-sr5-build-thread.html)
cbielat 05-03-2015 10:01 AM
COUPON CODE: CBIELAT
RECEIVE 5% OFF BLACK OAK LED LIGHT ORDER
USE COUPON CODE CBIELAT AT TIME OF CHECKOUT
BlackOakLED Lights - LED Light Bars, Mounts & Accessories – BLACK OAK LED
Instagram: cbielat
I'm computer illiterate so I copy and pasted my Excel sheet. Doesn't exactly match up well but you get the idea.
4Runner Build Revamp Spread Sheet
Other Manufacturer Name/Size/Dimensions Part Number Price Website Status Notes
FRONT SUSPENSION
Shocks Radflo 2.0" shock body/600# spring $853.00 Overland Warehouse (no longer) Removed Sold
Upper Control Arms SPC Light Racing $528.00 Overland Warehouse (no longer) Removed
CURRENT SET UP
Long Travel
Total Chaos 2" Long Travel Suspension Kit Race Series $3,500.00 offroadwarehouse.com Installed
Axle Shafts Total Chaos 2" $603.98 offroadwarehouse.com Removed
Total Chaos 2" Spare $306.00 Total Chaos Installed
Removal Pipe 16" X 1 1/4 CV Shaft Removal Tool $7.00 Home Depot Installed
Axles RCV Performance Long Travel Spec $3,000.00 rcvperformance.com Installed
Shocks
King 2.5" w/ Remove Reservoir $1,600.00 Installed
Upper Control Arms Total Chaos Included In Long Travel Kit
Lower Control Arms Total Chaos Included In Long Travel Kit
Spindle Gussets Total Chaos Weld On Spindle Gussets $60.00 chaosfab.com Installed
Cam Gussets Total Chaos Weld On Cam Tab Gussets $89.00 offroadwarehouse.com Installed
REAR SUSPENSION
First Set Up Radflo 2.0" bodies $456.00 Overland Warehouse (no Longer) Removed
Eibach 2" Lift Springs $220.00 Overland Warehouse (no longer) Removed
Daystar Rear Coil Spring Spacer $20.00 T4R.Org Member Removed
CURRENT SET UP
Long Travel
Shocks Radflo 2.5" bodies -28" extended $630.00 Off Road Parts & Accessories | Metal Tech 4x4 Installed
Springs Metal Tech Dual Rate 3" Lift Springs - Heavy $230.00 Off Road Parts & Accessories | Metal Tech 4x4 Installed
Bump Stops Metal Tech Extended $69.95 Off Road Parts & Accessories | Metal Tech 4x4 Installed
Upper Links Metal Tech $250.00 Off Road Parts & Accessories | Metal Tech 4x4 Installed
Lower Links Metal Tech Offset $325.00 Off Road Parts & Accessories | Metal Tech 4x4 Installed
Brake Lines Metal Tech Extended $60.00 Off Road Parts & Accessories | Metal Tech 4x4 Installed
Sway Bar Custom Double Disconnect $125.00 T4R.Org Forum Member Installed
Track Bar Rokmen Adjustable Track Bar $400.00 rokmenoffroad.com Installed
TIRES Good Year 285/70/17 Duratrac $1,400.00 Sears Store Installed Set 1
Good Year 285/70/17 Duratrac $1,400.00 Good Year Store Installed Set 2
Mickey Thompson 315/70/17 - 34.6" (35") Baja MTZ P3 $1,250.00 ATD Tire Distributors Installed Sponsorship Pricing
37/12.50/17 Used $60.00 Facebook Market Place Installed
Maxxis 37/12.50/17 Razr $1,300.00 www.simpletire.com Installed
WHEELS FN Wheels Countersteer Type X - 17" $900.00 http://www.fnwheels.com Installed Matte Black
Toyota Toyota Second Spare Wheel $100.00 Toyota Installed
Battle Born Wheels Bootlegger 17/9.5/17 Beadlocks $1,500.00 www.battlebornwheels.com Installed
FN Wheels Countersteer Type X - 17" Second Set $400.00 fnwheels.com Installed Gunmetal Grey - Sponsorship Pricing
BRAKES EBC Ultra Slotted Rotors $360.00 buybrakes.com Installed
EBC Green Stuff Pads $360.00 buybrakes.com Installed
Power Stop Brake Kit Second Kit $380.00 rockauto.com Installed
LOCKERS ARB Air Locker (T4R Group Buy) RD193 (Rear Only) $1,021.16 T4R.Org (Group Buy) ECGS Installed
Air Locker Front $1,040.86 eastcoastgearsupply.com
AIR ARB Onboard Compressor CKMA12 $275.24 T4R.Org (Group Buy) ECGS Installed
Viair Portable Compressor 450P $299.00 amazon.com Installed
LOCKER AIR LINES Rocky Road Front Locker 7' Stainless steel http://www.rocky-road.com/toyota-arb.html
Rocky Road Rear Locker 13' http://www.rocky-road.com/toyota-arb.html
GEARS Rear Diff Nitro four.fiftysix $299.99 T4R.Org (Group Buy) ECGS Installed
Front Front Diff Nitro four.fiftysix $285.00 T4R.Org (Group Buy) ECGS Installed
Front Diff (Driver Side) ECGS CV Input Spacer 8" Clamshell $45.00 eastcoastgearsupply.com Installed
ECGS Spacer Tool $60 eastcoastgearsupply.com
Rear Diff ECGS Master Rebuild Kit 8.2" $290.00 eastcoastgearsupply.com Installed
Front Diff ECGS Master Rebuild Kit 8" Clamshell $300 eastcoastgearsupply.com Instaled
SKIDS RCI Front Engine $220.00 http://www.rcimetalworks.com Installed
RCI Transmission $165.00 http://www.rcimetalworks.com Installed
RCI Transfer Case $220.00 http://www.rcimetalworks.com Installed
RCI 2nd Transfer Case Skid $270.00 www.rcimetaworks.com Instaed Set 2
RCI Gas Tank Skid - Aluminum $350.00 www.rcimetalworks.com Installed
Custom UHMW Sheet $201.56 www.piedmontplastics.com Instaled 1/2" thick
UHMW parts $100.00 Fastenal Instaled Bolts/bits
Toyota-Trail Edition Gas Tank No Charge Installed
Rear lower link
Rear Shocks FJTOYMAN Rear Shocks $150.00 Installed
RCI Rear Differential $250.00 rcimetalworks.com Removed Sold
Front Lower Control Arm
SLIDERS OPOR/Metal Tech $650.00 metaltech4x4.com Removed
Custom Built Myself Sliders $200.00 Grant Steele Installed $100 Steele cost / $100 Grinding/Cutting discs
BUMPER Front CBI Steel $1,700 cbioffroadfab.com Installed
Rear CBI Steel $1,400.00 http://cbioffroadfab.com Installed
CB RADIO Cobra 75 WS XT $100 amazon.com Installed
Antenna Fire Stick 3' Whip $25 amazon.com Installed
Mount Diamond K400 $40.00 amazon.com Installed
Handheld Baofeng Handheld $30.00 amazon.com Installed
FENDERS Front Fenders $88.00 http://www.partstrain.com
LIGHTING Rear Bumper Extreme LED Solutions 2x2 Pod LED (2) Installed
Front Bumper Black Oak LED 2x2 Pod 10W Cree (2) $159.94 blackoakled.com Installed
Black Oak LED 2x2 Amber Pod Covers (2) $17.94 blackoakled.com Installed
Ditch Light Brackets CBI Ditch Light Brackets $55.00 cbioffroadfab.com Installed
Black Oak LED 2x2 Pod 10W Cree (2) $156.00 blackoakled.com Installed Sponsorship Pricing
WINCH Superwinch Talon 12.5 SR $900 Superwinch.com
Superwinch Solenoid Relocation Kit $100 Superwinch.com
RECOVERY
Winch Shacke Mount Winch Line Factor 55 Flatlink E $145.00 Southeast Overland
Tire Deflation ARB 505 EZ Deflator $42.00 amazon.com Installed
Snatch Strap Warn Recovery Strap $90.00 amazon.com Installed
Tire Repair Kit ARB $42.00 amazon.com Installed
D Ring Shackles N/A $20.00 Installed Stolen
Hitch Insert N/A $25.00 Installed
MISCELLANEOUS
Paint Protection 3M Front Bumper/Head Lights/Grill $350 http://www.invisiblemask.com Installed
Breather Custom Rear Diff Breather Mod $20.00 Installed
Antenna Custom Stock Antenna Block Off $5.00 Installed
Plastidip Custom Plastidip Chrome Accents $30.00 Installed
Paint Custom Spray Paint Sliders/Skids $40.00 Installed
Powertank Powertank Powertank (Air) $550.00 Installed Won in Raffle @FJ Northeasters Run
Fire Extinguisher $40.00 Installed
Roof Basket Rola Roof Basket $171.00 Amazon.com
Hi-Lift Jack Hi-Lift Jack $112.00 Amazon.com
Compressor Mount Mount Compressor Mount $86.00 Leroy from FJNE(Bandiworld)
Ladder Gobi Ladder $120.00 Private Seller
Soft Shackles Soft Shackles Southeast Overland $60.00 Installed
LCA Cam Bolts/Sleeves Toyota Cam Bolts/Sleeves $127.00 Toyota Installed
Tie Rod Ends
Outer Tie Rod Ends Toyota $93.00 Cost +10% Installed Set Three
Inner Tie Rods Toyota Installed Set Two
CV Axles Toyota CV Axles for TC Replacement Shafts Qty. 2 $640.00 Installed
Transfer Case Toyota Transfer Case Switch $56.00 Installed
Wheel Bearings & Hubs Toyota Wheel Bearings & Hubs $700.00 Toyota Installed Set One
Wheel Bearings & Hubs $220.00 rockauto.com Installed Set Three
Steering Rack Toyota $720.00 Cost +10% Installed Set Two
Bushings Lower Control Arms Total Chaos Total Chaos LC Bushings $115.54 chaosfab.com Installed Set Three
Uniballs Lower Control Arms Total Chaos Total Chaos LC Uniballs $180.00 chaosfab.com Installed Set Two
Body Lift Leroy Horwedel Bandiworld 1" Body Lift $75.00 Private Seller Installed
Skid Front Engine Skid Front Skid Bolt Spacers $2.50 homedepot.com Installed Set Two
Rod Ends Metal Tech LT End Links Currie Enterprises Johnny Joints $232.81 currieenterprise.com Installed Set Two (4)
Bushings Metal Tech LT End Links Metal Tech Bushings $39.00 metaltech4x4.com Installed Set Two
Bushings Steering Rack Bushings Whiteline Poly Bushings $53.00 energysuspension.com Installed
Bushings Rear Shock Pin Mount Radflo Rear Shock Pin Mount Bushings $43.00 radflo.com Installed First Replacement Set
Tail Light Driver Side Rear Tail Light Toyota Driver Side Rear Tail Light $137.00 Toyota Installed On Second Replacement
Storage Box Custom Myself Rear Storage Box $250.00 Home Depot Installed
LABOR
Gears/Locker ECGS/ARB $1,600.00 T Jays Transmission Installed
Long Travel Kit Total Chaos $1,520.00 RMS Off Road Installed
Cam Gussets Total Chaos $395.00 Eastern Welding Installed
Blown Needle Bearing Front Diff ECGS Bushing Replacement Front Diff $60.00 BDR Automotive Installed Set Two- Tjays Transmission never installed the part to begin with.
Steering Rack Replaced Steering Rack $1,200.00 BDR Automotive Installed
850lifeguard 05-03-2015 10:09 AM
That Sir is an impressive list. Can't wait to see some photos. Sub'd
cbielat 05-03-2015 10:11 AM
Stock Photos
3 Attachment(s)
Bought the truck brand new at the end of November 2011. Started the bolt on build almost immediately and has been a work in progress ever since.
cbielat 05-03-2015 10:20 AM
5 Attachment(s)
Shortly after, I purchased my Radflo 2.0 kit front and rear with SPC's Light Racing UCAs and 2" rear lift springs through Overland Warehouse, 285/70/17 Goodyear Duratracs and 17" Konig Countersteer wheels from FN Wheels.
cbielat 05-03-2015 10:23 AM
5 Attachment(s)
Wheels/Tires/Suspension - First set up.
cbielat 05-03-2015 10:28 AM
2 Attachment(s)
Didn't like the stock antenna so I looked for something to delete it. This is what I came up with and stuck it in the base hole.
cbielat 05-03-2015 10:30 AM
2 Attachment(s)
Of course I had the notorious driver side lean and corrected it with a spacer in the rear.
cbielat 05-03-2015 10:56 AM
7 Attachment(s)
After my first wheeling trip, it was evident that I needed protection. I bought skids from RCI(front engine, transmission and transfer case). I had also acquired an OEM full gas tank skid from a TE to hold me over for a bit. Sliders came from Metal Tech and are the OPOR brand.
cbielat 05-03-2015 11:02 AM
7 Attachment(s)
Sliders
cbielat 05-03-2015 11:09 AM
1 Attachment(s)
Later on down the road, it was time for new brakes. I went with the EBC Ultra Slotted Rotors with EBC Green Stuff pads. Also decided to change my hubs and all as I thought they were worn. Turns out that wasn't the case and learned what it was after much more research. I will touch on that in a later post.
cbielat 05-03-2015 11:24 AM
6 Attachment(s)
After a couple years of driving trails, I've been learning more and more and decided where I wanted to be. I chose to go with Metal Tech's long travel rear set up utilizing Radflo 2.5" shocks. This kit consists of Radflo 2.5" long travel spec shocks, Metal Tech dual rate springs in the heavy version, Metal Tech off set lower links, Metal Tech upper links, Metal Tech extended bump stop brackets and extended stainless steel brake lines. I also bought double disconnect rear sway bar end links(have been more of a pain in the ass than anything).
cbielat 05-03-2015 11:26 AM
4 Attachment(s)
Rear Long Travel Continued
cbielat 05-03-2015 11:30 AM
1 Attachment(s)
Sway bar end links
cbielat 05-03-2015 11:38 AM
5 Attachment(s)
After some trips and banging up my stock rear bumper cover, I decided to go with CBI's rear bumper. Opted not to go with the swing out at the time but now I'm sometimes wishing I had.
cbielat 05-03-2015 11:41 AM
3 Attachment(s)
Bumper pictures
Copyright ©2000 - 2026, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
