3rd gen T4Rs
https://www.toyota-4runner.org/3rd-gen-t4rs/)
alternator
https://www.toyota-4runner.org/3rd-gen-t4rs/217837-alternator.html)
| 01thunder |
04-11-2016 01:58 PM |
alternator
is there a higher output denso out there?
| LittleCaesar |
04-11-2016 04:16 PM |
80A is the highest one I know of (stock).
| KidVermicious |
04-11-2016 04:24 PM |
Take yours to a shop and have it rewound for a higher output.
| 01thunder |
04-11-2016 04:59 PM |
No shops where I am.
| AZPartsGuy |
04-11-2016 07:23 PM |
| amalik |
04-11-2016 07:30 PM |
Denso is basically the OEM and not going to give you more than stock
#livewithit
| Stick Figure |
04-11-2016 07:54 PM |
2nd Gen MR2's had a 90 or 100 amp Denso option (looking for ones with the electric power steering assist). I don't know off the top of my head what it would take to fit it mechanically or electrically though. Most of my experience with Toyota's has been that similar years are pretty easily interchangeable.
| gmv4k |
04-11-2016 08:06 PM |
| bambi_runner6 |
04-11-2016 08:47 PM |
https://www.dcpowerinc.com/vafproduc...3.4L+V6+5VZ-FE
I went with this alternator. Direct plug in. No splicing, no adapters, nothing special about the install. They use Denso parts. They've raised the prices quite a bit since I purchased mine though. It's worth the price, even though it's pretty steep.
| calimobber |
04-11-2016 10:20 PM |
Just stick with the cs-144, its fairly cheap and puts out 150amps if needed. only modification is 4 washers and a cheap adaptor. Takes 30 min or less to install, I even used the stock belt.
| Bry838 |
04-12-2016 04:31 AM |
http://www.tacomaworld.com/forum/mar...m-upgrade.html
Personally id go with one of these three alternators! He is a member on here to under a different user name. His wiring kit "big 3" is pretty sweet too and very reasonably priced! If youre getting a higher amp alt you should really consider his kit with yhe alt and big 3 wiring upgrade.
| All times are GMT -4. The time now is 01:33 PM. |
Copyright ©2000 - 2026, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by
