Fun with Voltage
Hello all,
Since I breathed life back into my 4runner via some neurosurgery, I have been noticing some odd readings from my torque pro app in regards to voltage. My charging voltage is staying steady at 12.6 volts.........no matter the RPM. 1000, 2000, 3000 all read the same 12.5 to 12.6 voltage range. Im not sure what would cause that. I know there are a million alternator threads, trust me, I read a lots of them. But none mentioned steady voltage at all RPMs. During my 3 month diagnostic process, the 4runner never left its parking spot. I sanded all the grounding point I could find. The battery ground wire was upgraded last year to a much heavier gauge than the stock wire. I also cranked the engine at least 50 times during that 3 month period. I was impressed the battery still had enough charge to start the engine that last time. Could this be a voltage regulator or brush problem? It looks like the Voltage regulator is just $50 shy of the price for a new OEM alternator. Thoughts? Thanks, -Z |
Sounds like it is time to break out the multimeter.
You'll need to figure out where the voltage drop is coming from. Start with the actual battery voltage (ground clipped on battery), then the output of the alternator, then check various spots on the chassis vs. the ground post, etc. If the brushes are bad (in my experience) you will get the 'charge' lights on the dash at least some of the time. -Charlie |
Im getting 12.94 volts with the engine off at the battery. 13.89 volts idling at the battery. Voltage increased to 13.91 at 3000 RPM. So how am I losing an entire volt at the OBDII port?
Well, if you decide to replace the brushes in your alternator,
@infamousRNR
and I have a video for you.
<iframe width="560" height="315" src="https://www.youtube.com/embed/71_kBhg6_-A" frameborder="0" allowfullscreen></iframe> |
Quote:
On a side note, I did @mtbtim brush replacement using his video and I caught mine JUST in time. 182,000 miles. They were completely worn down to where they were just barely riding on the shaft. One of the easier repairs I've done on my Runner. Thank's Tim. I don't think this is your problem though. |
Quote:
Quote:
Torque Pro does not deliver an accurate number for volts but it can still be useful since we know what it reads when the charging system is working appropriately. |
Quote:
Quote:
Sent from my SM-G930T using Tapatalk |
Quote:
-Charlie |
Oh, I always thought it fluctuated with the rpm. Glad to know it's working.
Quote:
Quote:
Quote:
http://www.tekrispower.com/pdfs/xant...20Charging.pdf -Charlie |
| All times are GMT -4. The time now is 05:09 AM. |
Copyright ©2000 - 2026, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by
