3rd gen T4Rs
https://www.toyota-4runner.org/3rd-gen-t4rs/)
Check Engine Light
https://www.toyota-4runner.org/3rd-gen-t4rs/23375-check-engine-light.html)
| volvodriver |
10-23-2006 03:06 PM |
Check Engine Light
The CEL on my '99 4Runner 3.4 L 5 speed came on the other day. I read the codes with my OBD II reader. They are: P0125, P1135, P1133,P1135. I couldn't find a listing of these to describe what they mean. I was hoping that someone on here could help.
Thanks in advance.
Dave
| Elton |
10-23-2006 04:42 PM |
| volvodriver |
10-23-2006 11:59 PM |
Thanks for the code lists, guys. I think it needs a new O2 sensor, but am unsure of which one. Also, I don't understand why it would be giving a coolant temp sensor and pedal position sensor code.
Thanks,
Dave
| Elton |
10-24-2006 12:02 AM |
| volvodriver |
10-24-2006 06:43 PM |
Thanks for the link for new O2 sensors. That's the best price that I've seen. Has anyone else got the same code when the O2 sensor goes out? I'm sort of confused as to why the other codes are showing up. ' Just wanted to make sure something else isn't wrong with it.
Thanks,
Dave
| el_chapu-bling |
10-24-2006 10:23 PM |
Quote:
Originally posted by Elton
o2 sensors click
Word of advice:
If your car must meet California Emissions standards, the O2 Sensor is called the "Air-Fuel Ratio Sensor" (or simply A/F Sensor).
I made the mistake of replacing mine with an Autozone O2 sensor, but still failed the Smog test. I went and bought the A/F Sensor from a Toyota dealer (the only place where you will find that piece) and it passed Smog with no problems.
| volvodriver |
10-26-2006 12:16 PM |
I live in WV, so I guess the replacement Denso O2 sensor should work fine. I might do both of them since they're $79 each. Can these sensors be tested by using an DMM with the car running? I wasn't sure if the harness could be unplugged and a meter used to check for fluctuating voltage readings.
Thanks,
Dave
| All times are GMT -4. The time now is 07:46 AM. |
Copyright ©2000 - 2026, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by
