SDHQ's 2010+ 4Runner Switch Pros Under The Hood Module Mount
PRODUCT OVERVIEW:
-Mounting Plate mounts to existing factory mounting point in the '10-Current 4Runner -Hardware is provided -Simple and clean solution for mounting the switch-pro WHAT'S INCLUDED: - SDHQ Power Module Mount Plate - Mounting plate hardware package (3) Push In Zip Ties (2) M8 1.25x20mm S.S. Button Head Bolts (2) 5/16” S.S. Washers (2) #8-32 x 1/2” S.S. Button Head Bolts (2) .304 x .169 x .032 Small Diameter Washers (2) 8-32 Flush Mount Press In Nuts http://store.sdhqoffroad.com/images/...endering.1.JPG http://sdhqoffroad.com/wp-content/up...5412492261.jpg '10-Current 4runner Switch Pros Under the Hood Power Module Mount Optional Upgrade Sealed Relay Pack Upgrade (As seen above) PRODUCT OVERVIEW: Ability to add two 30 amp circuits on switches 1 through 7 Incorporates two micro relays and two 30 amp fuses. Sealed unit with all necessary connectors and seals. Mounts cleanly with easy access for service. WHAT'S INCLUDED: (1)Power Module Base (1)Power Module Cover (1)Power Module Rubber Seal (1)Power Module Metal Bracket (2)#10-32 x 1/2“ S.S Button Head Bolts (4)#10 S.S. Washers (2)#10-32 Nylock Nuts (2)ISO 280 Micro Relay SPST (3)30 A Mini Fuses (3)Blue mini sealed Terminal Position Assurance (12)Green Cavity Plugs (14)Metri Pack 280 Female Terminal 14 Gauge w/ Tang (14)Grey Terminal Seals http://store.sdhqoffroad.com/images/...cture1.1.1.png Sealed Relay Pack Pack Upgrade For Switch Pros Power Module Mount |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
