5th Gen 4Runner Brakes Upgrade (for 4th Gen 4Runner)
I have looked across the internet and found a lot of information spread throughout but nothing that was easy to follow.
THIS THREAD was the most helpful. (51 pages of information) I am only trying to compile all necessary information to make the upgrade easier for everyone. UPDATE: Some people are still having issues with the calipers still seizing. This seems highly situational and I haven't taken the time to look for a pattern of causation.This is a very easy upgrade caliper swap. The mounts are identical and line up perfectly. 4th Gen Sport models (Sport Brakes Package optional on the Limited) have larger front calipers (13WH) and rotors than the SR5 models (13WG) so no modifications are necessary. The rear calipers/rotors are the same for all 4th Gens. Yes, this upgrade DOES work on SR5 but the dust shield/covers need to be modified/cut or upgraded. (Just like the 3rd gen 4Runner -> Tundra caliper upgrade) SR5 owners have the option of "upgrading" their brakes to the Sport brakes but these still have the seizing issues. The 5th Gen calipers have shown less issues with seizing than the 4th gen calipers have. (my front left caliper seized which prompted this thread) The 5th Gen front and rear caliper pistons are (2.5mm-3mm) larger than the 4th gens (not sure if this is compared to 13WH, 13WG or both) The 5th Gen front rotors are 4mm thicker than the 4th Gen rotors. (this extra thickness helps with heat dissipation and warping) The 5th Gen front rotors are the same diameter as the 4th Gen Sport (338mm or 13.307") (SR5 has 319.024mm or 12.56") 5th Gen Front Rotors: Nominal Thickness: 31.8mm (1.25") Minimum Thickness: 29mm (1.14") 4th Gen Front Rotors: Nominal Rotor Thickness: 27.94mm (1.1") Minimum Rotor Thickness: 25.908mm (1.02") It is possible to use the larger (Sport) 4th Gen rotors with 5th Gen calipers... The pistons in the calipers will over extend when the pads get warn down if you use the 4th Gen front rotors with the 5th Gen calipers. It is highly recommended to upgrade the rotors too It is even less recommended to use the SR5 rotors with the 5th Gen calipers because of the smaller rotor diameter in addition to them being thinner. 5th Gen Rear Rotors: Nominal Thickness: 18.034mm (0.71") Minimum Thickness: 16.002mm (0.63") Outside Diameter: 312.166mm (12.29") 4th Gen Rear Rotors: Nominal Rotor Thickness: 18.034mm (0.71") Minimum Rotor Thickness: 16.002mm (0.63") Outside Diameter: 311.912mm (12.28") Both 4th and 5th Gen rear rotors seem to work. Proofs: 5th: BlackWorksInc and measurements, Runn4est, JeffMerr, verman84 4th: 084RUNNAH, The argument of why it might better to use 4th gen rotors: pjbrownva ACDELCO 18A2735 (5th Gens) Center Hole Diameter 107.95 MM ACDELCO 18A1227 (4th Gens) Center Hole Diameter 106.17 MM That is the section of the rotor the emergency/parking brake uses like a drum brake (brake shoes press against the inside of the rotor) Here are the other vehicles with the calipers we're after. Front Calipers: 14WA
Rear Calipers: F14 and braket 14B?
When buying calipers, you'll usually have these options (source):
JeffMerr and pjbrownva (with pictures) Brake Pads: 4th Gen (Sport and Limited models) Have the same pads as the 5th Gen 4Runners (source1)(source2) Wheels: 17" wheel recommended. Some aftermarket 16" work (like the FJ Cruiser TRD Pro 16s) but stock 4Runner 16" wheels will not. (source) Brake Bleeding: (See Post #2 in this thread) Brake Bleeding section of 4Runner repair manual. Link to PDF I can't find any Speed Bleeders that claim to work on the 5th gen calipers. They may be different based on the (re)manufacturer. Centric Front (141.44287 and 141.44288) Bleeder is 7mm x 1mm Centric Rear (141.44587 and 141.44588) Bleeder is 10mm x 1mm Duralast Front D6278 and Rear 19-B2737 calipers: 10mm x 1mm Cardone(Wearever) Rear caliper Bleeder is 10mm x 1mm Speed Bleeder(brand) (their website): pjbrownva here ordered Front: SB7100-SS Rear: SB1010-SS Order Total: $70.00 DoctorMegaly uploaded a video on YouTube. He also used SB7100-SS for his front calipers (7mm x 1mm) 3/16" hose recommended for most nipples My personal installation guide... (didn't have time to document, bought PWR-KC138-36 and stainless braided Front and Rear lines) Let me know if I left out any helpful information and I'll add it to the original post. USEFUL LINKS/THREADS 5th Gen Calipers by 084RUNNAH Rockauto is a good place to order parts (everyone has been able to get a refund for their core charge even though they returned a different model caliper) proof1 proof2 proof3 $15 return shipping? Centric Calipers: (Cart Pic) Total [Before Core Fees: $188] [With Core Fees: $467.16] Centric Rotors: (All Prices Pic) [Daily Driver Total: $186] [Heavy Duty Total: $298] Eye candy (pictures) and part numbers from GLW68 5th Gen Caliper Install Gone Wrong? by fdbyrne 4th Gen Brake Upgrade Glock_19 by Ducmonsta Rotors and brake pads recommendations? by Keyen702 Brakes need pumped twice to work correctly by buck_sez Long but extremely educational video: Brake Replacement - A Focus on Brake Hardware |
How to fix spongy brakes:
Quote:
Parts 084RUNNAH Ordered: Quote:
Quote:
Quote:
great documentation. This should be a sticky!
This is a great consolidation!
I'm glad you made mention of Blackworks post on the rotor bore size. I've seen a lot of skepticism lately on the rear 5th gen rotors being used. People have claimed to me (even after I successfully installed the brakes) the e-brake wont work properly...I can confirm that I am successfully using 5th gen rears with no issue and the e-brake works as intended. |
One correction though. The larger brakes on the Limited were an option. I had to bend back the dust shield on mine (03 V8 Limited)
Also, i believe you need 17" rims to clear the caliper, so with the SR5 it can be an issue.
Awesome job.
Everything you wrote is a great summary of the process. My suggestion is to go with the 4th gen rear rotors. I went with the 5th gen and the access holes to the parking brake tensioner star nut don't line up entirely correctly. Go with 4th gen rear rotors. Also, I would make this super bold and large. Paint your calipers or buy them already painted. These things rust ridiculously fast. Mine turned orange in a few months tops and I don't even live in the rust belt. Really wish I had painted them. |
Quote:
Quote:
Quote:
I just did this upgrade. What a difference in braking. The installation is straight forward. The Gen 5 rotors and calipers go right on.
I have the parts lists in another thread. I purchased everything from Rock Auto. BPOWER STOP S2736 Performance Red Powder Coated; Includes: Caliper, Hardware, and Bracket; Includes: Caliper, Hardware, and Bracket Info Rear x2 $155.58 Remove BPOWER STOP S6278 Performance Red Powder Coated; Includes: Caliper, Hardware, and Bracket; Includes: Caliper, Hardware, and Bracket (where applicable) Info Front (Only 2 Remaining) x2 $233.58 Remove Brake & Wheel Hub : Rotor Related Parts CCENTRIC 12644175SL StopTech Sport Slotted Info Rear Left $67.89 $0.00 1 $67.89 Remove CCENTRIC 12644175SR StopTech Sport Slotted Info Rear Right $67.89 $0.00 1 $67.89 Remove CCENTRIC 12644174SL StopTech Sport Slotted Info Front Left Previous Image Next Image $82.79 $0.00 1 $82.79 Remove CCENTRIC 12644174SR StopTech Sport Slotted Info Front Right Previous Image Next Image $87.79 $0.00 1 $87.79 Remove Brake & Wheel Hub : Brake Pad Related Parts AAKEBONO ACT606 {Click Info Button for Alternate/OEM Part Numbers} ProACT Ultra Premium Ceramic Pad Info Rear; OE Pad Material Is Ceramic $39.79 $0.00 1 $39.79 Remove AAKEBONO ACT976 {Click Info Button for Alternate/OEM Part Numbers} ProACT Ultra Premium Ceramic Pad; Includes Shims Info Front; OE Pad Material Is Ceramic $44.79 $0.00 1 $44.79 Remove Subtotal $780.10 |
Great summary! Should be a sticky!!
Nice the video by DoctorMegaly is actually my former roomate. I was up there visiting when I picked up my 4th gen and drove it back here. Small world! I saw there was another video of someone else doing the 5th gen swap that was a bit longer too.
If I want to change out my SR5 dust shields to accomodate the 5th gen brake mod, should I get the 4th gen Sport dust shields or can I just get the 5th gen dust shields. I'm assuming 5th gen dust shields will fit, is it identical to the 4th gen Sport dust shields?
I know most with SR5s just bend them, but I don't mind doing a little extra work to put the bigger shields on. |
5th gen to 4th gen brakes
I swapped my 2008 SR5 over to 5th gen brakes (rotors and calibers) almost 1.5 years ago without any issues. It bolted right up without any adjustments. I just bent my dust shield out of the way and haven't had any issues with it since.
I used Speed bleeders SB 7100-SS M7x1.0 and SB 1010-SS M10x1.0 to bleed the system afterwards. I didn't have any problems using the 5th gen rears and aligning up the hole to adjust the e brake. It really significantly improved the braking on my 4th gen. It was well worth it. W |
Quote:
I used a Dremel when I upgraded my 3rd gen 4R to Tundra calipers. |
Quote:
A good friend is in the final stages of dying from asbestos dust. It freaking sucks bad. I want you to be healthy man. |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
