What is everyone using for the 199 brake upgrade?
I've had a set of 199 calipers/rotors from Napa for a couple of years and both fronts are nearly frozen. With the tire off the ground I can barely turn one by hand, the other I cannot.
I'm thinking of just throwing them in the trash and going with a power stop kit, but wanted to see what everyone else is using? I don't have time to rummage through a junk yard and want brakes that just work. Thanks! |
I went with the 199 power stop kit. Ordered from RockAuto and sent them my old original calipers as a core.
They have been great for me and everything seemed high quality. Only issue I had was the pad retaining clip broke on the driver side causing the pad to rattle. Replaced it and haven't had the problem again. You could rebuild the ones you have if youre looking for a little project. Might be worth it if they are OEM. |
I didn't want red calipers, so I bought Cardone Ultra Premium calipers from RockAuto (powder coated in gray), and the Power Stop rotors and Z36 pads, also from RockAuto. I'm happy with the setup so far.
Interesting factoid is that it was significantly cheaper to order Power Stop calipers, rotors, and pads from RockAuto separately than as one complete kit, at least at that time. |
Quote:
Quote:
I ended up ordering a Power Stop 231 kit today and will be tossing my NAPA garbage in the the... well... garbage.
Quote:
Thanks bud. |
Quote:
https://www.rockauto.com/en/catalog/...+pad+kit,14204 3 options right there from basic to heavy duty, these kits include calipers too if yours are gargage rn |
Quote:
Offer them up for free on the forums. I have the 231 napa's and while I haven't checked if I can freely spin them with my hands. My mileage has been the same over the 30k + miles I've had them. |
Quote:
That's a link to regular 4Runner brake parts, just FYI. The OP (and others) are interested in the Tundra upgrade parts. |
Quote:
2001 TOYOTA TUNDRA 4.7L V8 Caliper, Rotor & Brake Pad Kit | RockAuto |
Quote:
Quote:
I have the 199 calipers. OEM. Got them used from a forum member a while back. I rebuilt them with OEM seal kits and new OEM pistons. I ran them for a while then one of them started to hang up. Took the suspect one apart and found it to be rusty right on the edge underneath the dust seal. Cleaned it up. Lightly honed the bore edge. Painted the metal right to the edge. Again used new OEM seals. Had the same problem about 6 months later. I'm willing to bet that most of the people who have this problem are in "rusty" environments or are fording a lot of water with their trucks. I just replaced that caliper last month. I forget the brand but it had all the same exact casting marks as my OEM caliper. I would think that most of the calipers out there are OEM castings probably with AM pistons and seals of varying quality. We'll see how these hold up.
I must ask.
What is the rotor size and brake pad size difference between the factory 3gen and the smaller 199 braking system? Also what is the caliper piston diameter of the OEM 3rd gen, the 199 (45mm I think), and the 231mm? Sent from my iPhone using Tapatalk |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
