Considering putting 2019 TRD Pro Fox 2.5 suspension on a 2015 SR5
As the price of a set of 2019 TRD Pro suspension is similar pricing to a comparable set of Fox 2.5..... I am considering putting that onto a 2015 SR5
Now, what rear spring should I use? Any info on what rear spring a 2019 TRD Pro comes with? (Are they just STOCK?) So, the new TRD Pro don't have much "lift" as it come stock? Can it be adjusted? |
The Pros rear spring is stock. Eibach,Bilstein and Dobinsons all make rear springs in the 1” range but you’re still going to have more rake than you do now because the trd Fox is lifting only .85” to 1” max in the front
Quote:
As already mentioned the rear TRD Pro spring are the same. You are only going to get about .8" of lift with the Pro front coilovers do you probably wouldn't want to add back lift springs with just that. They are not adjustable. You could get the Toytec 1 or 2" spacers and add to the Pro kit to get more lift. At that point depending on what kind of price you are getting on them you might want to look into the Bilstein 6112 kit that would be adjustable. Good luck. Sent from my iPhone using Tapatalk |
TRD Fox Compatibility
I tried to buy a used pair of the TRD Fox Shocks from someone who purchased them from a dealer who stripped them off a pro at the Factory to lift it.
They told me that they are not compatible with the TRD Off Road with KDSS because “KDSS has trac control sensors that cannot be disconnected.“ I was confused by this as the Bilstein pro suspension is compatible. Is this true? Is this something that Toyota is telling people? |
They guy had the suspension removed at the factory? In Japan?
That's news to me. |
Quote:
Sounds like something that one person is telling people, that is garbage. |
Quote:
Quote:
One way to verify is to search whether any such shocks are offered with a range for lift (like 1-3 or 0-1.5 for regular shocks) or with just a fixed lift. |
Quote:
In the front I'd think a spacer lift on top of the shock would be the best option so the shock remains in the right base position. |
Quote:
Quote:
Which kinda makes getting a TRD pro in any other color than the special color kinda silly, (especially with the early offerings) if you paid MSRP or more for it. They may be slightly more differentiated from the factory for 2020 (like if Dual Zone AC and a few other major features aren't also on the TRD offroad Premium trim), but we won't know completely until they're out. If you go back and read some of the TRD Pro threads from the early years, all the "hate" for people paying over MSRP for it will make a little more sense. |
Quote:
I'll see if I can see any again when I drive by. |
Quote:
Saved you the trouble: Notice anything missing... fresh off the boat. Just arrived at the Ports of Los Angeles - Toyota 4Runner Forum - Largest 4Runner Forum https://www.toyota-4runner.org/5th-g...ml#post2775531 https://www.toyota-4runner.org/1793325-post1103.html Theres also a TSB floating around showing how to modify the bumper and fender liner to fit the TRD Pro wheel and tire combo if it's rubbing after install of the shocks. T-SB-0009-15 TRD Pro Bumper/Fender Interference |
Makes sense.
Wonder what they do with all the steel wheels after. |
Quote:
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
