NEW Expedition Series Lower Control Arms from TOTAL CHAOS
https://gallery.mailchimp.com/c84848...ab7ba5d411.jpg
https://gallery.mailchimp.com/c84848...4842f814da.jpg TOTAL CHAOS is proud to announce the release of the all-new EXPEDITION SERIES lower control arms. The Expedition Series is an evolution of the original Race Series which increases ground clearance and adds component strength. With strategic additions and subtle enhancements, the Expedition Series lower control arms will improve on and off road handling on a wide range of suspension configurations. https://gallery.mailchimp.com/c84848...f7218e592b.jpghttps://gallery.mailchimp.com/c84848...a3927e2667.jpg One of the main features of the Expedition Series lower arms are newly integrated steering stop tabs which retain factory turning angle with no modification necessary to the OEM ball joint cradles. Put that grinder away for this install, these are 100% bolt-on. https://gallery.mailchimp.com/c84848...a39ad8240b.jpg Only found on Expedition Series lowers, strategically placed pockets have been added at the coilover shock tabs to increase clearances allowing for a wider range of shocks to be used (up to 3.0"). https://gallery.mailchimp.com/c84848...7a6b91f5c8.jpg Uniball cups on the Expedition Series lowers are part of a stout one-piece billet design that increases strength and provides more turning clearance. 1" 100% stainless steel uniballs are included which replace the factory ball joints. https://gallery.mailchimp.com/c84848...a57b15c30a.jpg As with all TOTAL CHAOS lower control arms, replaceable polyurethane pivot bushings and zerk fittings are included for easy maintenance. As always, don't forget to prep your sh*t! https://gallery.mailchimp.com/c84848...8f7804e6dd.jpg TOTAL CHAOS Expedition Series lower control arms consist of laser cut 4130 chromoly throughout and are 100% MADE IN THE USA. Currently the Expedition Series is available as a stock length replacement. Single or dual shock variants are also available for vehicles with or without KDSS. Note: for dual shock applications, a 1.25" wheel spacer is required to keep the tire from hitting the second shock at full steering lock. https://gallery.mailchimp.com/c84848...35caa9fc94.jpg 05+ Tacoma | 03+ 4Runner | 07+ FJ | GX470 & GX460 | Prado 120 & 150 SHOP EXPEDITION SERIES LOWER CONTROL ARMS Looking for KDSS options? Click the links below Expedition Series - KDSS Lower Control Arm - Single Shock https://www.chaosfab.com/images/acce...J-KDSS-NSS.jpg Expedition Series - KDSS Lower Control Arm - Dual Shock https://www.chaosfab.com/images/acce...-10FJ-KDSS.jpg TOTAL CHAOS WWW.CHAOSFAB.COM |
Great product!
Are these compatible with shocks that have a rubber bushing at the lower rod end?
Quote:
Strategically placed pockets have been added at the coilover shock tabs to increase clearances allowing for a wider range of shocks to be used (up to 3.0") This allows customers to run a rubber bushing rod end shock (Factory, Billstein, Old Man Emu, Etc.) as well as a larger 3.0 shock like what King offers. TOTAL CHAOS TOTAL CHAOS FABRICATION |
https://www.chaosfab.com/images/acce...S_Detail01.jpg
Only found on Expedition Series lowers, strategically placed pockets have been added at the coilover shock tabs to increase clearances allowing for a wider range of shocks to be used (up to 3.0") This means you can NOW install a bushing lower rod end shock or a 3.0! Click the link below to find Expedition Series Lower Control Arms for your ride! TOTAL CHAOS | Expedition Series LCA TOTAL CHAOS WWW.CHAOSFAB.COM |
@TOTAL CHAOS
just to clarify, with the addition of your UCA and Expedition LCA I can order the Tundra 3.0 Kings and it would work fine with the 5th gen?
edit: I wonder if having KDSS wouldnt allow me to use the 3.0 Kings. Assuming since Kings have specific coilovers for 5th gens with kdss. |
I got a silly question.
Can I run a single shock on a dual shock LCA with no problems? |
Quote:
Correct! 3.0s will work with the Expedition Series. We offer both KDSS and non-KDSS models. You can run the larger diameter shock with either TOTAL CHAOS TOTAL CHAOS FABRICATION |
Really wish this would have been offered a month ago before I spent money on the race series. Literally one month.
Anyway...I run them without wheel spacers just fine. Turning radius suffers though. I’m running after market wheels though. |
I doubt I could even scratch the surface on what these were designed to do.
Overland Expo West is coming up!
We'll be in booths P11 / P21 near Baja Designs and SDHQ. Come check out our new project build with Expedition Series Lowers ;) https://live.staticflickr.com/65535/...1e39fac8_b.jpg See you there!!! Ways to Attend WEST — Overland Expo TOTAL CHAOS TOTAL CHAOS FABRICATION |
Does this use the same size uniball that you use in your upper control arms?
Quote:
it's just money |
well these need regreasing every 10-15k miles like the upper control arms?
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
