Rigid UltraSwing for 5th Gen 4Runner - Anyone using it?
I was very interested in purchasing this product as a substitute for a full rear bumper modification. Unfortunately, I didn’t find any reviews on the forum in regards to it. Furthermore, it basically costs as much as a rear bumper! Why would they even price it similarly to it? Oh well, does anyone have this product on their T4R? If so, how do you like it? Is there any way to salvage the use of the backup camera?
Sent from my iPhone using Tapatalk |
@SurgicalApple
I have it and think it's great. Unsure what swing out bumper costs close to $1020; A CBI single arm is $2,675 without shipping. That is the bumper I was considering before buying the UltraSwing.
Here is a link to video showing how it doesn't bounce around: YouTube And here is a link to 10 user reviews (many from this site): UltraSwing Hitch Carrier for 4th and 5th Gen 4Runner - RIGd Supply I haven't relocated my camera yet. I'll likely move it up by the center brake light. I wouldn't mount it on the UltraSwing because then you're giving up the flexibility to remove it any time you want. I just put the front runner table on it as well-it's a nice addition. |
Damn, did it go up in price? I seem to recall them being a lot cheaper when they first started making them.
Talked them at the Overland Expo in Flagstaff AZ this past weekend. Seemed like a solid piece. They were offering a setup too that had some Frontrunner Table/ Rago Panel on it too. Could be interesting for a camping setup where you needed an extra work / prep setup. I think they wanted like 1100ish for that kit.
Wilco Offroad also makes something similar, without any fancy table setup. was like in the $ 800 range I believe. Both seemed solid and looked like it wouldn't wobble around. |
I like the Detours of Maine one better. Does pretty much everything the Ultraswing does, but sits closer to the hatch (its adjustable), tire placement is better IMO, and its half the price ($595+shipping). No table or hi lift option, but I'm planning on making my own mounts for them once mine arrives; shouldn't be very hard.
Quote:
3 Attachment(s)
I have it and absolutely love mine. Its a really solid piece. Had a minor issue with the latch due to design flaw but customer service was top notch and they overnighted me a new one.
I use it as a spare tire carrier, mount my rotopax, as well as have the drop down front runner table and rago plate, and its relatively compact compared to other stuff out there. And love that I can take it off if I want to drop weight or cruising around in the city. Back up camera definitely gets blocked when its on but then again its not a permanent piece like a full bumper. I just leave lots of space when backing up. Only cons I didn't like was the design of the rago plate that mounts to the swing out. The hole spacing makes it difficult to access nuts/bolts and attach the table or other accessories. Thought there could have been more thought put into that part. |
I have the Ultraswing with the table and the hi lift mount. It is honestly such a great purchase! The extra table alone makes it worth it. The build quality is excellent and I have not had any issues with it and it does not wobble at all. The latch problem the other guy had I saw in this is the company they use has a defect in them where a pin drops out sometimes but if you put some loctite on the pin its good to go! Overall the thing is great and it is way cheaper than a full rear bumper but this thing can hold just as much stuff on it if you want it to. You can see some pictures of mine on instagram @kophoto4x4
Quote:
5 Attachment(s)
I have the Rigd Ultraswing along with Rago plate and Front Runner table. I got in on the pre-production run when it was $825 shipped. It arrived a little scuffed up so a quick email to Luke and they quickly took care of me.
I wasn't sure if I was ready for a full rear bumper replacement so I went with the Rigd Ultraswing. Yes there are pro's and con's to each but ultimately a hitch mounted tire swing would accomplish what I wanted, bring the spare tire out from the bottom and provide a mounting system for accessories (in this case a drop down table). And if I decided that either I didn't like it and wanted to go back to stock or go full rear bumper then it's as simple as removing it and selling it. It's easy to reverse whereas if you go full rear bumper then that's more of a permanent decision. A few impressions on the Rigd Ultraswing itself. Very high quality part. The overall construction is excellent, the hinge mechanism is nice and strong and the same as what rear bumper replacements use, overall it's a well thought out and designed hitch mounted tire solution. I like the fact that it has two hitches on the unit itself, one as an extension to the oem part and one on the swing out itself. The hitch is two rated at 10,000lbs so more than what our 4Runners can even tow and the second swing out allows you to mount a bike rack and swing out a bike without having to take your bike off or fold down the rack. I took it off-roading on corrugated wash boards with whoops and dips and it hardly moves. There is a tiny bit of wobble and vibration but nothing bad. The Rago panel was sort of PTIA to install and my least favorite part of it. Although I suppose this is more of an indictment on Rago than Rigd. But once it's installed it's done. I added the Front Runner fold down table and used the heck out of it this week while camping. One of my favorite parts about the way they designed the Ultraswing, the ability to basically add any accessory once you get the Rago panel. Overall I like it a lot for what it is. It does block the rear view camera and I won't be doing a camera relocation until I decide I'll keep it for good, go full replacement, or go back to stock. For now it stays and I enjoy the fact that I simply added it on as accessory without gaining the weight of a full bumper, needing to add stronger rear springs, re-gear, or hack up the truck. If all you need is a spare tire carrier than I'd look at the Detours of Maine one. It's cheaper, looks very high quality, and has better departure angle. If you want accessories and a swing out hitch then Ridg is the way to go. I wouldn't consider a Wilco at this point until they update their design or drop the price. |
Quote:
Quote:
To weigh in on the comment about comparing the UltraSwing to a replacement bumper for anyone else looking to make a decision on a rear swing out: We never had any intention of making a product that competes with someone needing additional rear end protection. When we designed it the goal was to make an alternative that better met our personal priorities: 1. Carry a spare tire and bikes (and swing them both out of the way) 2. Lighter weight 3. Removable 4. Options for other accessories like a camp table or fuel For us, it wasn't about trying to make something less expensive, we just didn't need a rear bumper. And adding 250+ lbs of steel to the rear of the 4Runner made no sense for our personal needs. Turns out there are a lot of 4Runner owners out there with similar priorities. If additional rear-end protection is a major priority than a replacement rear bumper is definitely the way to go. We personally are fans of C4 Fab |
Quote:
The UltraSwing can swing out a spare tire, and bike rack, and mount a camp table, Rotopax, Hi-Lift, etc. As well as giving you the option to run it with our without the tire mounting plate if you ever have a need to swap the functionality for mounting a Waterport or another Rotopax to the front of the carrier. For anyone reading this I would highly encourage watching our feature and accessory breakdown video breaking down specific features and functions we built into the UltraSwing in order to make an informed decision of what carrier is best for you. |
Quote:
But yeah, if you're not into DIY and just want a carrier with readily available accessories, the ultraswing is probably the way to go. Can't go wrong with either! https://i.imgur.com/md3I2vK.jpg https://i.imgur.com/n072lYK.jpg |
Quote:
Looks clean man [emoji106] Nice ladder too https://uploads.tapatalk-cdn.com/201...879f9acefc.jpg Sent from my iPhone using Tapatalk |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
