T4rchadly's "RADRNR" build thread (IFS wannabe rock crawler on 37s)
CURRENTLY:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/52844650673/in/dateposted-public/" title="IMG_1104"><img src="https://live.staticflickr.com/65535/52844650673_5b14c45998_z.jpg" width="640" height="427" alt="IMG_1104"/></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/53358396708/in/dateposted-public/" title="IMG_8158"><img src="https://live.staticflickr.com/65535/53358396708_6253927c0b_z.jpg" width="640" height="427" alt="IMG_8158"/></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/53358631120/in/dateposted-public/" title="IMG_7563"><img src="https://live.staticflickr.com/65535/53358631120_c372752266_z.jpg" width="640" height="427" alt="IMG_7563"/></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/52941482256/in/dateposted-public/" title="IMG_5901"><img src="https://live.staticflickr.com/65535/52941482256_ba093b6a46_z.jpg" width="640" height="480" alt="IMG_5901"/></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/52844393209/in/dateposted-public/" title="IMG_1840"><img src="https://live.staticflickr.com/65535/52844393209_eed91da712_z.jpg" width="640" height="355" alt="IMG_1840"/></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> welcome to my build thread and see the start of my 1996 toyota 4runner build. im a mercedes benz technician in Anchorage, Alaska, and planning on moving to colorado this fall of 2019. i recently sold my 1989 pickup in search for a stupid clean 4runner, and just so happened to find a mint 1996 runner. manual trans with 202,000 miles. <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47939772702/in/dateposted-public/" title="IMG_2502-Edit"><img src="https://live.staticflickr.com/65535/47939772702_f5798de441_k.jpg" width="2048" height="1365" alt="IMG_2502-Edit"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47939673046/in/dateposted-public/" title="IMG_6478"><img src="https://live.staticflickr.com/65535/47939673046_c3ce6ec6f2_k.jpg" width="2048" height="1365" alt="IMG_6478"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47939672706/in/dateposted-public/" title="IMG_6501"><img src="https://live.staticflickr.com/65535/47939672706_de40e6c393_k.jpg" width="2048" height="1365" alt="IMG_6501"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47939643787/in/dateposted-public/" title="IMG_6526-Edit"><img src="https://live.staticflickr.com/65535/47939643787_4f5dc83d08_k.jpg" width="2048" height="1152" alt="IMG_6526-Edit"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> |
Modifications…
Suspension: - Front: - OME struts/ 881 coils - KINGS extended travel coilovers - SPC control arms - Replaced OEM LCa's (stock bushing) - Toytec 1” diff drop - Front sway bar removed - Durobumps front bumpstops - 333 Fabrication eccentric cam eliminators - Welded cam tabs to prevent from bending - Eimkeith strut tower plate/brace - JD fabrications 3.5 Long Travel kit - Dirt king 8" limit straps with clevis adjuster - King offroad 8" coilovers w/ resi's - Resi mounts - Modified OEM tacoma balljoints - Rear: - OME 891 Coil Springs - OME shocks - LC80 black tokico shocks - LC80 7.5 wrap coils (48131-6A570) - KYB gas-adjust shocks (LC80 SHOCK) - Emkeith PCK w/ gusseted upper panhard bracket - Rear sway bar removed - Durobumps rear 2.5" bumpstops - Energy rear link/panhard bushings - Dobinson c59-210v springs Wheels and Tires: - Method racing MR304 wheels - 35x12.5" Yokohama geolander MT G003 - TRD Pro 17x8 wheels - Milestar Patagonia 285/70/17 M/T tires - Spidertrax 1.25" wheel spacers on rear axle - 37x12.5xr17 Kenda Klever RT Drivetrain/steering: - Replaced OEM steering rack - Wheeler’s Off-Road steering rack bushings - New Toyota OEM inner/outer tie rod ends and lower ball joints - Total Chaos spindle gussets - Extended Breather with filter front/rear - Mobil 1 synth oil - Lce heavyweight flywheel (38lbs) - ARB front air locker with 4.88 gearing (ECGS UNIT) -ARB rear air locker 4.88 gearing (TRAILGEAR UNIT) - Marlin crawler 1200lbs clutch kit - Marlin crawler Stainless Steel clutch line - 2220 lbs pressure plate with semi-metallic disk - 900lbs aisin pressure plate, exedy semi-metallic disk - Upgraded arb compressor to a 120psi pressure switch - Northwest Fabworks Dual transfer case - Northwest Fabworks triple stick setup - Solo motorsports Tie Rod Extensions - OEM tacoma outer tie rods Engine and Performance: - Northstar 27F AGM battery - "O" chaped TB gasket - LCE upgraded CC injectors - Genuine Toyota Block heater - ARB high output compressor - LCE upgraded alternator - "Big 3" wire upgrade (4gau) - CS144 cadillac alternator - Custom cruise control relocation bracket - Cold air intake - Ruffstuff Solid engine mounts Brakes: - Wheeler's Off-Road stainless steel brake lines front/rear - Tundra Brake upgrade Lighting: - Nomad Retrofits projector headlights - Custom baja design squadron headlights - Clear headlight housings - GTR Ultra 2 LED bulbs - Burtman Clear corners w/ LED bulbs - APC clear tail lights W/ all LED bulbs - Vision X light cannon 6.7 spot lights (X2) - Baja design LP9 combo - Baja designs XL80 lights spot/flood combo (X2) - CBI ditch light brackets - VLED interior dome lights, License plate light - VLED dash/cluster bulbs - HIDkitpros rock lights (8 total) Interior/Electrical: - Pioneer AVH-2550DEH headunit - Spod Bantam system - Extra plug in dual USB charging port/ cigarette lighters - Cobra s75 CB with 3' firestik antenna - CBI antenna bracket - Garmin GPS Smartdrive 65 - Husky Floormats front/rear - Sound dampening - Ram mounts on driver A pillar for phones - ARB compressor/rear/front locker switched on center console - Blueridge molle seatback panel w/ multiple attachments (i keep my air-up equipment in) - ARB 50 QT fridge - Vinyl wrapped rear quarter panel windows matte black - Mckinsey craft Co. rear drawer system/sleeping platform - Outbound Nevada storage panels - Rear USB/ cigarette ports with switch - "Lemmie out" rear hatch latch - Paper towel holer (on the sotrage panel) - Rear hatch window switch mod - Rear hatch "kitchen" LED's - Custom rear hatch area ceiling light - Front 6.5" alpine type R coaxial speakers - rear 6.5" alpine type R coaxial speakers (custom modified to fit) - Rockford fosgate 12 inch subwoofer/box - Sound deadened with kilmat + soundskinz - Ol' 1988 camry wagon heater knobs - Custom GPS ram mount - USB outlets installed on top of dashboard - Maxout fire extinguisher w/ quick release Exterior / Accessories: - 20% Tint - 5% ontop of 20% tint (hatch window) - Yakima skybox 18 - Yakima spacebox 11 Sherpa equipment "matterhorn" rack version 2 - Custom traction board mounts - Shovel w/ quickfist mounts - Cut front and rear fenders - Rear fenders welded back together - Tubbed firewall - Tubbed rear wheel well - Raptor liner rocker panels/doors - Windshield washer reservoir relocation - Toytec 1'' bodylift - Trasharoo - ARB 2000x2500 awning - Yakima hangover 4 bike rack - 01-02 Clear headlights - '99-00 grille Armor / Recovery: - ARB Front Bumper (bottom ribs cut off, end caps n for fitment) - Smittybuilt X2O 10,000 winch w/ ORCISH w/8 synthetic line - Custom built Rock sliders - Lil’ Skip gas tank skid plate - Budbuilt front and belly pan - Recovery kit - Custom tube rear bumper - Addicted offroad tube bumper (extremely chopped) ------------------------------------------------------------------------------------------------------------------------------------------------------ main plans/end goals TRD wheels/35s no body lift- - done front/rear ARB - done turbo setup dual case - done spc UCA/king coilovers - done tokico black shocks/ new 891s -plan on different route 12" rear shocks/ dobinson/861 coils installed tokicos/LC 7.5 wraps instead. 220v's next with 12" rear shocks AGM battery - done d44 SAS ford 9"/spidertrax rear end w/ 3 links would like to do list/maintenance needs finish blackouts setup convert to manual speed sensors 86 entire ABS system different coilover top mount |
the first weekend i got it took a 600 mile trip to homer, alaska and went biking/exploring.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947095953/in/dateposted-public/" title="IMG_6804"><img src="https://live.staticflickr.com/65535/47947095953_1da6a97251_k.jpg" width="2048" height="1365" alt="IMG_6804"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947102616/in/dateposted-public/" title="IMG_6670"><img src="https://live.staticflickr.com/65535/47947102616_fed8cdffec_k.jpg" width="2048" height="1365" alt="IMG_6670"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947106851/in/dateposted-public/" title="IMG_6727"><img src="https://live.staticflickr.com/65535/47947106851_0fffc7f9fe_k.jpg" width="2048" height="1365" alt="IMG_6727"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947099518/in/dateposted-public/" title="IMG_6535-Edit"><img src="https://live.staticflickr.com/65535/47947099518_1a4f583d0c_k.jpg" width="2048" height="1365" alt="IMG_6535-Edit"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> i then took it on its first wheeling trip to a trail called kings river. <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947080327/in/dateposted-public/" title="IMG_7133"><img src="https://live.staticflickr.com/65535/47947080327_28d4f2c0a2_k.jpg" width="2048" height="1365" alt="IMG_7133"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947076162/in/dateposted-public/" title="IMG_6956"><img src="https://live.staticflickr.com/65535/47947076162_f9a80f08c4_k.jpg" width="2048" height="1365" alt="IMG_6956"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947123466/in/dateposted-public/" title="IMG_6929"><img src="https://live.staticflickr.com/65535/47947123466_a8401cd571_k.jpg" width="1152" height="2048" alt="IMG_6929"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> |
on a side note, im looking for a set of clear tail lights for the truck. does anyone know SOMEONE or a link to clear tail lights? i know APC's are hard to get ahold of and i have money to buy a set. im not interested in 01-02 crystal clears, euro style, or LED style. im looking for specifiaclly a set of all clears. please let me know if anyone knows something. all the links on other threads are dead or lead me to a euro style.
this is the style i'm talking about <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47947210111/in/dateposted-public/" title="CLEAR LIGHTS"><img src="https://live.staticflickr.com/65535/47947210111_58b9106f5a_b.jpg" width="699" height="699" alt="CLEAR LIGHTS"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> |
nice looking runner. do you have details on the last time the timing belt was changed? along with water pump?
jealous about the move to Colorado. and I have a college buddy who lives in Homer! small world. |
the water pump and belt were changed at 180K. im going to order the kit here in a week or two so i dont get stranded, it has a oroblem with extended crank after being heat soaked, i think it could possibly something with timing belt as the previous owner had a reputable shop change a bunch of fuel system components. going to do and OEM kit mostlikely. homer is awesome! little to small for my taste as im in the big city of anchorage. a lot more to do here
Quote:
thank you!! ordered a set with clear corners, way too stoked. ive been digging for awhile now with nothing but dead links
well, big betsy finally came in after 2 months, ordered even before i had a 3rd gen lined up and bought.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980400161/in/dateposted-public/" title="IMG_7144"><img src="https://live.staticflickr.com/65535/47980400161_83d81aa3de_b.jpg" width="1024" height="683" alt="IMG_7144"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> i will do a small how to but i was not into extreme detail with pictures. i will provide the links i had used to help install the bumper. i started by taking off the bumper. there will be 2 12MM nuts to take of on both left and right fenderwells facing the front of vehicle. after taking those off, i unbolted the 4 17mm bolts connecting the tow hooks on the bottom side of the frame. after that i unbolted the 4 14mm that hold the OEM brushguard to the bumper and had help from another guy remove bumper at my shop i work at. you are left with this. <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980343208/in/dateposted-public/" title="IMG_7146"><img src="https://live.staticflickr.com/65535/47980343208_b59a26d76f_b.jpg" width="1024" height="683" alt="IMG_7146"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> you then need to cut the framehorns at the weld, and then grind smooth the weld splatter and weld itself. ive seen people remove this using a cutoff disk and grinder, a plasma cutter, and i chose to use my milwauke corded bandsaw and went right down the frame with perside accuracy. this took me maybe 3 minutes for both sides. I had used a file to smoothen everything out ensuring it would not be easy to cut my hands. <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980346787/in/dateposted-public/" title="IMG_7151"><img src="https://live.staticflickr.com/65535/47980346787_3694f05244_b.jpg" width="1024" height="683" alt="IMG_7151"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> i had fitment issues with the two front body mounts hitting the bumper support and had to cut a section off the bumper rather than grind more of the frame for better strength. I unfortunately did not capture that but it seems as if sometimes they have clearance issues and sometimes they dont, and i had to. after making necessary fitment modifications, i bolted the frame support using the 4 17mm bolts you use to take off the bumper and tightened snugly. you then have to look on the bottom side of frame . facing up and see that there is a hole you have to drill. this hole needs to be drilled to 1/2" on each side to fit the long bolts with the sleeve. after that this is what i ended up with. <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980405451/in/dateposted-public/" title="IMG_7153"><img src="https://live.staticflickr.com/65535/47980405451_f898f3f192_b.jpg" width="1024" height="683" alt="IMG_7153"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980358967/in/dateposted-public/" title="IMG_7155"><img src="https://live.staticflickr.com/65535/47980358967_85e29d1452_b.jpg" width="1024" height="683" alt="IMG_7155"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> on the last picture i show the gap between the support and frame. from all the videso and threads i have seen people have to fit with a hammer but mine slid in with eas and i have an 1/8th inch gap? i was thinking thats the jigs used to weld the frame could vary and so on so i rolled with it and proceeded. if anyone could shed light i would appreciate it. you then need to put buffer kit on the bumper and in this case i have a brand new smittybuilt x20 10,000 synthetic winch and installed it to the bumper. i assembled the winch and fairlead, bolting it in via the bolts given in the winch kit and fits with ease; i have seen people with other smittybuilts have clearence issues but i had no issues for whatever reason. due to the control box wires being so short i did not want to but the box in a goofy spot, therefore i had made a custom mound by drilling holes and taking measurements to make it all even. i secured the control box wires onto the winch and tested the winch and verified proper working order. you then install the bumper via 6 medium length bolts. this is how it ended up <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980365162/in/dateposted-public/" title="IMG_7159"><img src="https://live.staticflickr.com/65535/47980365162_e2cdc04619_b.jpg" width="1024" height="683" alt="IMG_7159"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980369252/in/dateposted-public/" title="IMG_7158"><img src="https://live.staticflickr.com/65535/47980369252_23a651cc2d_b.jpg" width="1024" height="683" alt="IMG_7158"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47980355733/in/dateposted-public/" title="IMG_7156"><img src="https://live.staticflickr.com/65535/47980355733_9b2d5caf2a_b.jpg" width="1024" height="683" alt="IMG_7156"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> unfortuneatly i had to cut the grill in order to fit the custom box mount :( oh well it looks very clean IMO. i will get pictures later i might go wheeling tomorrow. but anyways let me know what you guys think of the writeup even though it wasnt in crazy step by step detail. these are links i had used to help installation YouTube YouTube |
yes i know the buffer kits are installed incorrectly and already changed them
:lol: |
tested out both the winch and bumper today.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47990702511/in/dateposted-public/" title="IMG_7199"><img src="https://live.staticflickr.com/65535/47990702511_57fa1a8bb4_b.jpg" width="1024" height="683" alt="IMG_7199"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47990650982/in/dateposted-public/" title="IMG_7161"><img src="https://live.staticflickr.com/65535/47990650982_f94d6b2dfd_b.jpg" width="1024" height="683" alt="IMG_7161"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47990651072/in/dateposted-public/" title="IMG_3071"><img src="https://live.staticflickr.com/65535/47990651072_2b6d8ba709_b.jpg" width="1024" height="683" alt="IMG_3071"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47990651908/in/dateposted-public/" title="IMG_7181"><img src="https://live.staticflickr.com/65535/47990651908_0ec4400b3f_b.jpg" width="1024" height="683" alt="IMG_7181"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> |
I still like the look with the factory wheels!!! dope rig
Quote:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/47991315993/in/dateposted-public/" title="trd wheels"><img src="https://live.staticflickr.com/65535/47991315993_7557645b88_b.jpg" width="800" height="600" alt="trd wheels"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> i think i want to run 34s for now so im overgeared a little? im going to be pulling a trailer and theres some pretty fat climbs on the way down. i made the trip in a different vehicle last summer from arizona |
after doing the last trip there was a rock garden i couldnt get passed because i dont have sliders and i was bound to destroy my rockers/body panels. so i stole dirtcos sliders and made a near exact replica with 2/2 3/16" tubing ive already had. im not on a body lift and dont plan on doing one so i had to mound my sliders to the bottom of the frame plate and im going to weld a top gusset for added strength. this is where i'm at with them:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48005863481/in/dateposted-public/" title="IMG_7206"><img src="https://live.staticflickr.com/65535/48005863481_8d71f170c7_b.jpg" width="1024" height="683" alt="IMG_7206"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48005863541/in/dateposted-public/" title="IMG_7209"><img src="https://live.staticflickr.com/65535/48005863541_21d51ff828_b.jpg" width="1024" height="683" alt="IMG_7209"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> i'm also really tired of not having an air compressor anymore since i sold my pickup, so i finally found a spot where i think i wouldn't compromise space with:naughty: <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48005872173/in/dateposted-public/" title="IMG_7213"><img src="https://live.staticflickr.com/65535/48005872173_038a6d1d75_b.jpg" width="1024" height="683" alt="IMG_7213"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48005950042/in/dateposted-public/" title="IMG_7216"><img src="https://live.staticflickr.com/65535/48005950042_dbe173b212_b.jpg" width="1024" height="683" alt="IMG_7216"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> i made a custom bracket but totally spaced the tank and made a use hold for weight savings in CAD. this is useless now and using just for mockup until i make the final bracket. the only thing im worried about is i think the air line going to tank will be interfering with the panel. i have to remove the cubby pocket unfortunately but im willing to take a loss in order for a gain on a clean install and using good space. let me know what you guys think. |
well i finished up my rock sliders using the ideas of Dirtco's using 2x2" 3/16. this is how they turned out and im in love.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035191131/in/dateposted-public/" title="IMG_7220"><img src="https://live.staticflickr.com/65535/48035191131_b60ff67201_b.jpg" width="1024" height="683" alt="IMG_7220"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> went wheeling to test out how they work. got to test out the new winch on a steeper section i couldnt get up that had a few gnarly ruts. <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035233953/in/dateposted-public/" title="IMG_7289"><img src="https://live.staticflickr.com/65535/48035233953_8dce2945c3_b.jpg" width="1024" height="683" alt="IMG_7289"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> finally made it to Eska Falls, Alaska. <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035190706/in/dateposted-public/" title="IMG_7340"><img src="https://live.staticflickr.com/65535/48035190706_c076193718_b.jpg" width="1024" height="683" alt="IMG_7340"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035298027/in/dateposted-public/" title="IMG_7345"><img src="https://live.staticflickr.com/65535/48035298027_65bcceb9a2_b.jpg" width="1024" height="683" alt="IMG_7345"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> "WIDE fU***** OPEN TOYOTA" <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035189156/in/dateposted-public/" title="IMG_7375"><img src="https://live.staticflickr.com/65535/48035189156_e2367d6afc_b.jpg" width="1024" height="683" alt="IMG_7375"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035232323/in/dateposted-public/" title="IMG_7470"><img src="https://live.staticflickr.com/65535/48035232323_efab057b2f_b.jpg" width="1024" height="683" alt="IMG_7470"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035289958/in/dateposted-public/" title="IMG_7379"><img src="https://live.staticflickr.com/65535/48035289958_5e3d3f297e_b.jpg" width="819" height="1024" alt="IMG_7379"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> on the way up was fairly difficult with no lockers a bunch of bogs. on the way down was steady up until i hit 2 swamps using a different trail down, and got my world rocked with hidden boulders under the mud/water. didnt get pictures as i was too busy getting winched out from my buddy with the new can-am mavrick. <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035332532/in/dateposted-public/" title="IMG_7459"><img src="https://live.staticflickr.com/65535/48035332532_3519f3af02_b.jpg" width="1024" height="683" alt="IMG_7459"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> but eventually made it to the bottom of the parking lot. i hate mud....... this will be fun cleaning. <a data-flickr-embed="true" href="https://www.flickr.com/photos/181664286@N04/48035231718/in/dateposted-public/" title="IMG_7484"><img src="https://live.staticflickr.com/65535/48035231718_4ea1abcb40_b.jpg" width="1024" height="683" alt="IMG_7484"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script> |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
