Charlotte NC ICON 2003 4Runner MetalTech Long Travel Rear Shocks 2.5" w/ Remote Resei
These are up for sale, completely rebuilt a year ago but one needs a rebuild. It is emulsified. I have the rebuild kit and a new bushing for that shock and will include it with the sale.
Get the most flex possible out of your 4Runner without having to fab anything up. Brand new these run $1,120.00 , will sell for $575.00 as is or $650 rebuilt , flat rate of $30 shipped from Charlotte, NC or free local pick up. These are Long Travel Rear shocks and you will need Long Travel Springs, extended brake lines and bump stops. PM me if interested. Product Description ICON FJ Cruiser/03+ 4Runner 2.5" Remote Reservoir rear shocks designed specifically to work with Metal Tech Progressive Rate Spring. These are Vehicle Specific Remote Reservoir shocks that are valved and sized for optimal performance with ICON Vehicle Dynamics suspension systems. These shocks are constructed from the same high quality components as our coil-over shock line. OVERVIEW: ICON Vehicle Specific (V.S.) 2.5 Series shocks are designed and built to give your vehicle outstanding performance off-road and a smooth ride on the street. These shocks are configured specifically for each application in both length and damping tune. Like all ICON shock absorbers, V.S. 2.5 Series shocks are 100% rebuildable and 100% revalveable. For piggyback and specific remote reservoir applications; ICON’s unique use of a 6061 billet aluminum manifold a few inches below the top cap of the shock creates an internal “Bump Zone” that when used creates an additional 20% of damping force. This additional force helps prevent harsh bottom outs and controls the suspension when compressing at high velocity. If you are looking for a more user defined tune, consider looking into the Compression Damping Control Valve (CDCV) or the OMEGA Series bypass shocks. KEY FEATURES: • ICON’s internal “Bump Zone” increases damping by 20% to provide more control as the shock approaches full compression • Remote reservoir design improves heat dissipation to reduce shock fade during prolonged use • Premium grade 5WT shock oil for consistent suspension damping along a wide temperature range • One piece digressive piston design with vehicle specific valving for unsurpassed performance and ride quality on and off-road • 7/8” diameter induction hardened, chrome plated shock shaft • Polyurethane bushings and forged steel mounting stems for OE factory type fitment • PTFE lined spherical bearings and application specific mounting hardware • 6061 aircraft grade aluminum CNC machined components • CAD plated, precision machined 1026 DOM steel shock body for maximum durability and corrosion resistance • 100% Rebuildable • 100% Revalveable • Made in the U.S.A. Picture of them from when they were new for reference compared to a regular extended Icon VS 2.0 shock. https://live.staticflickr.com/7862/4...abe5faba_b.jpg and flexed out :) https://live.staticflickr.com/4322/3...635b3afc_b.jpg |
These are SOLD
Thanks for looking Bobby |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
