FS: 2005 4Runner SR5 V8, Bilstein, Hawk, RRW, Morimoto,Gibson Richmond,VA $8725
8 Attachment(s)
235k. Former Alabama truck before coming to VA. Wife purchased this April of 2014 @ 147K from Pearson Honda. Enthusiast Owned/Maintained. Runs awesome, No leaks of any sort. Only reason for selling is we have upgraded to something larger. Have over $4,000 in receipts, not including the wheels and tires. Current inspection, Just had an alignment and wheel/tire balance performed @ Dyke tire last week.
Maintenance Items - Timing belt & pump were done @ 200K w/ AISIN Kit - New MAF - New rear coolant bypass joint gaskets, along with new SAI ASV gaskets, new intake manifold gaskets - New fuel pump - Both front wheels bearings have been replaced - Both front calipers have been replaced - Front Hawk LTS pads on Centric Ecoated rotors, Rear wagner pads on generic rotors - Redline fluids in Front, Center, and Rear diffs - New F & R sway bar endlinks - AC Evaporator core has been replaced (common issue on the 4th gens) - Oil services performed every 7k w/ Mobil 5w-30 Synthetic and OE toyota filters - Recently installed brand new Fog lights and Turn signal assemblies Mods - K&N Intake - Gibson Catback - Daystar 2.5/1.5in Spacer lift - Bilstein 5100s at all corners - LED fog bulbs - LED L-plate bulbs - LED parking light bulbs - All LED cabin bulbs - Pioneer AVH-1400NEX (Apple Car play ready) Double Din Head unit, w/ remote (less than 3mos old) - Custom Projector Retrofits (have $400.00 + in parts alone in these). All parts for these minus the HID ballast came from The Retrofit Source. ⦁ Brand New Black housing assemblies ⦁ ACME H1 projectors ⦁ Mini H1 centric rings ⦁ Panamera switchback 2.0 (white/amber) led shrouds ⦁ Morimoto MotoHo1ders ⦁ Morimoto H1 XB 5500k bulbs ⦁ TRS housing caps, TRS 2x4 position Wiring seals ⦁ OPT7 Bullet R HID ballast Factory bumper DRLs have been disabled. the white illumination for the shrouds now act as the DRL(these are now receiving the signal from the BCM for the DRLs). Orange illumination on the shrouds flash with the turn signals. - 17x9 RRW RRV-4s . Matte Black finish w/ silver hardware. 0mm offset, 5in BS. These were also Ceramic coated with Gyeon Q2rim. - 265/70/17 Falken Wildpeak AT3s Wheel/tire setup was bought brand new as a XMAS for my wife December 2018. About 12k mi on setup. Uninstalled/Extra parts - Morimoto HD Relay Harness - LED Flasher relay (require Toyota harness adapter for NON DRL flasher relay) - Set of new KYB front upper strut mounts - New 06+ bumper fillers and harness adapters for the 06+ headlight conversion - Stock front pads, Stock headlights. - RevTek Front 3in spacer lift (just the spacers) - Extra spare K&N filter I have more parts laying around, everything 4R related I have will go with it. Asking $8725.00 OBO. again, PRICE IS OBO. Price can be altered If I keep the RRWs. 18" GX460 wheels w/ New Michelin's would go on it. Matt 804-513-8889. Please text or messege me for more pics, or videos of the DRL/Turn Signal illumination |
Sold!!!! Please remove
Add Sold to the original post's title
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
