4th Gen T4Rs
https://www.toyota-4runner.org/4th-gen-t4rs/)
gookies |
08-13-2019 10:05 PM |
Which way does the transmission plug gasket go?
UrbanRunner651 |
08-14-2019 08:05 AM |
You are correct. You should be able to see the way the old one sits when you pull it. I believe the Haynes says something in the 15-20lb range. I have done a couple drain/refills re-using the same gasket despite having a new one and just snugging it up by hand. No issues with leaks.
gookies |
08-14-2019 09:04 AM |
Quote:
Originally Posted by UrbanRunner651
(Post 3338539)
Yeah, I did a drain and fill and noticed the other day there's a slight leak now, I am thinking I might've placed the gasket the wrong way or just need a new one, also did not over-torque it, just made it snug. Thank you for confirming.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
