Head gasket replacement parts recommendation
Hey guys,
I'm getting both head gaskets done at my local shop. It's a 2005 Sport V6. They gave me a quote with non OEM head gaskets and I'd rather get Toyota parts since it is a big deal. I was wondering if somebody would have a list of all the things they replaced on the engine with part numbers? They apparently called Toyota and were told it would cost about $2000 for all the parts (timing chains, sprockets, guides, etc.).. Thanks in advance! |
I guess if you are paying someone, it doesn't hurt to replace it all. Personally, I wouldn't replace sprockets. I didn't even replace my chain, guides or tensioner assembly, which is oil actuated I believe. Everything looked new and was lined up perfectly with the timing marks.
I did do the valve stem seals which were all pretty gross at 160k. |
It Would really depend..if your doing head gaskets cuz it was blown/ leaking then yes replace with Toyota gaskets.
Was there also a timing chain related issue or trouble codes that would prompt the mechanic to call for chain sprockets guides? |
Did you ever get the parts list from anyone? I'm in the same boat and I need to start getting the parts together.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
