Leaking fuel line. Anyone ever order from Linestogo.com?
Looks like a fuel line is leaking on my 99. Coming from the middle of the truck. It’s a return line otherwise the gas would be pumping out a lot. I’m just getting a small puddle. Anyways I’m looking at doing a full replacement and debating on buying a kit from linestogo.com or if I should make my own. I made my own brake lines using polyarmor brake line and I’m thinking making the fuel lines wouldn’t be that bad. The issue that I might face is having to find the correct fittings. I’m sure the ones on the truck are unusable as they are probably rusted. This kit from linestogo is premade lines with fittings and all. Just wondering if anyone had bought from them before or if people want me to be a guinea pig.
Quote:
So if you like you make your own. That might be your ticket. As you can put in the line material you want with the exact flare fitting that matches the original. :] Sent from my SM-J337V using Tapatalk |
Quote:
Quote:
got them from the rudy luther toyota, they are not that expensive. huge pain to get them back into the correct location. Part No.: 77252-35350 TUBE, FUEL MAIN, RR $23.97 Part No.: 77251-3D140 TUBE, FUEL MAIN, FR $36.68 Part No.: 77255-35740 TUBE, FUEL RETURN $36.94 Part No.: 77261-35520 TUBE, FUEL TANK TO C $37.22 there is no connection other than hose/spring clamps on the vent and return. when was the last time you changed fuel filter? clogged? the send line is the only one with connections and filter. I can't believe it's the return/vent leaking but maybe, if one of those is leaking it's damaged or rusted thru? here is a shot of the tank... not the best maybe for the lines but if your main send is leaking you would need to drop/tank pull sending unit maybe to fix a bad tube nut. https://www.toyota-4runner.org/3346142-post111.html |
@sleepydad
I did the fuel filter 3 years ago. I haven’t crawled under and looked yet to see which line it really is. I’m just guessing it’s a return line since it’s a very small puddle(silver dollar size). Pricing it out it looks like it’ll be quite a bit cheaper for oem lines than getting them from that website. I should just go that route.
Getting those lines in from the fuel filter area or the corner of a gas tank to the engine compartment can be fun. I changed the one from the fuel filter to the fender well about 1 year ago on my 97 5 speed. They will go in just may take a little time. So make sure you give yourself time to change them. As you may have to wiggle and jiggle for a while. The back brake line from the center union to the ABS was quite interesting (96-98). Most of the others lines aren't too bad. :-)
Quote:
Quote:
@sleepydad
thanks for posting those part numbers I ordered them up from walser toyota
Quote:
My son helped me get the rest of my sketchy beater project back together, just waiting on the brake bleeder tool from amazon. |
Yes changed things mid gen. 96-98 mostly the same 99-02 . The pressure line hookup is different from early to late. So are the rear brake lines setup and the gasoline evap systems.
I agree 100% with Sleepy dad always double check part numbers to match your year and vin. :] Soon your gas leak will be gone and your be cruising again. Sent from my SM-J337V using Tapatalk |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
